Bonjour tout le monde, j’ai comme un petit problème au niveau de l’installation. Il se trouve que j’ai trouvé un script parmi tant d’autres: easy_e17.sh. Je fais un “sh easy_e17.sh -i”, il fait un ./autogen make make install a chaque librairie puis un ldconfig.
J’ai d’abord eu un problème avec evas au niveau de l’automake qui était un 1.4, j’ai donc mis automake 1.7 et ca a fonctionné.
Maintenant, la librairie “ecore” refuse de “maker” correctement aussi bien manuellement que par le script auto, et voici son message d’erreur:
[quote]LIB-COMPILATION AND INSTALLATION:
- imlib2 … previous installed
- edb … previous installed
- eet … previous installed
- evas … previous installed
- ecore … ERROR!
LAST LOGLINES FROM /tmp/easy_e17/install_logs/ecore.log:
ecore_directfb_keys.h:175: error: initializer element is not constant
ecore_directfb_keys.h:175: error: (near initialization for _ecore_directfb_key_symbols[142]') ecore_directfb_keys.h:176: error: initializer element is not constant ecore_directfb_keys.h:176: error: (near initialization for_ecore_directfb_key_symbols[143]’)
ecore_directfb_keys.h:177: error: initializer element is not constant
ecore_directfb_keys.h:177: error: (near initialization for _ecore_directfb_key_symbols[144]') ecore_directfb_keys.h:180: error: initializer element is not constant ecore_directfb_keys.h:180: error: (near initialization for_ecore_directfb_key_symbols[145]’)
ecore_directfb.c: In function ecore_directfb_window_cursor_show': ecore_directfb.c:588: error:DSPF_A1’ undeclared (first use in this function)
ecore_directfb.c:588: error: (Each undeclared identifier is reported only once
ecore_directfb.c:588: error: for each function it appears in.)
ecore_directfb.c: In function ecore_directfb_window_fullscreen_set': ecore_directfb.c:638: error: structure has no member namedCreateFileDescriptor’
ecore_directfb.c: In function ecore_directfb_init': ecore_directfb.c:680: error: structure has no member namedCreateFileDescriptor’
make[4]: *** [ecore_directfb.lo] Erreur 1
make[4]: Leaving directory /root/e17_cvs/e17/libs/ecore/src/lib/ecore_directfb' make[3]: *** [all-recursive] Erreur 1 make[3]: Leaving directory/root/e17_cvs/e17/libs/ecore/src/lib’
make[2]: *** [all-recursive] Erreur 1
make[2]: Leaving directory /root/e17_cvs/e17/libs/ecore/src' make[1]: *** [all-recursive] Erreur 1 make[1]: Leaving directory/root/e17_cvs/e17/libs/ecore’
make: *** [all] Erreur 2
-----------------------------------------------------------------------------[/quote]
Malheuresement en cherchant sur google je n’ai pas saisi le peu de réponse que j’ai trouvé. Si vous avez une idée du problème je suis preneur, merci d’avance, a+.
Mugiwara
puisqu’il s’agit d’une version encore en developpement.
