bonjour,
j’ai un projet de piloter 1 centrale audio russound via ma debian.
la centrale est équipée d’un port rs232
mon serveur (dockstar) n’a que du usb.
j’ai donc acheté 1 adaptateur usb / rs232.
je le bracnhe est j’obtiens ceci via dmesg
[818591.694755] usb 1-1.2: USB disconnect, address 3
[818596.030844] usb 1-1.2: new full speed USB device using orion-ehci and address 6
[818596.141619] usb 1-1.2: New USB device found, idVendor=067b, idProduct=2303
[818596.148619] usb 1-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[818596.156069] usb 1-1.2: Product: USB-Serial Controller
[818596.161299] usb 1-1.2: Manufacturer: Prolific Technology Inc.
[818596.173043] usb 1-1.2: configuration #1 chosen from 1 choice
[818596.399878] usbcore: registered new interface driver usbserial
[818596.407337] USB Serial support registered for generic
[818596.415066] usbcore: registered new interface driver usbserial_generic
[818596.421788] usbserial: USB Serial Driver core
[818596.531267] USB Serial support registered for pl2303
[818596.537755] pl2303 1-1.2:1.0: pl2303 converter detected
[818596.545728] usb 1-1.2: pl2303 converter now attached to ttyUSB0
[818596.552674] usbcore: registered new interface driver pl2303
[818596.558361] pl2303: Prolific PL2303 USB to serial adaptor driver
et
[code]
lsusb
Bus 001 Device 006: ID 067b:2303 Prolific Technology, Inc. PL2303 Serial Port
Bus 001 Device 005: ID 135e:0023
Bus 001 Device 004: ID 0bc2:5021 Seagate RSS LLC
Bus 001 Device 002: ID 05e3:0608 Genesys Logic, Inc. USB-2.0 4-Port HUB
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub[/code]
je dois envoyer les codes suivant en hexa :
Zone 1, Volume Up : F0 00 00 7F 00 00 70 05 02 02 00 00 7F 00 00 00 00 00 01 7B F7
Zone 1, ON : F0 00 00 7F 00 00 70 05 02 02 00 00 F1 23 00 01 00 00 00 01 12 F7
Zone 1, OFF : F0 00 00 7F 00 00 70 05 02 02 00 00 F1 23 00 00 00 00 00 01 11 F7
ce ne sont que des exemples
j’ai tenté
echo “F0 00 00 7F 00 00 70 05 02 02 00 00 F1 23 00 01 00 00 00 01 12 F7” >/dev/ttyUSB0
mais ca ne donne rien.
Pourriez vous m’aider a démarrer sur ce nouveau projet ?
Merci d’avance.
Arnaud
