Salut à tous,
Un compte configuré en IMAP sur Icedove a cessé d’un jour à l’autre de fonctionner correctement. Lors d’une tentative de “Relever les messages”, Icedove reste bloqué sur “Connected to XXXX.fr” (j’ai remplacé partout le nom de domaine par XXXX.fr)
J’ai donc activé le log du traffic IMAP de Icedove, et voici sa sortie :
-834668800[7f8cd65e3ac0]: ImapThreadMainLoop entering [this=cf932000]
-217573600[7f8cf1e59260]: cf932000:XXXX.fr:NA:SetupWithUrl: clearing IMAP_CONNECTION_IS_OPEN
-834668800[7f8cd65e3ac0]: cf932000:XXXX.fr:NA:ProcessCurrentURL: entering
-834668800[7f8cd65e3ac0]: cf932000:XXXX.fr:NA:ProcessCurrentURL:imap://mon%2Enom@XXXX.fr:993/select%3E%5EINBOX: = currentUrl
-834668800[7f8cd65e3ac0]: ReadNextLine [stream=c9415a10 nb=0 needmore=1]
-834668800[7f8cd65e3ac0]: cf932000:XXXX.fr:NA:CreateNewLineFromSocket: clearing IMAP_CONNECTION_IS_OPEN - rv = 805a1f50
-834668800[7f8cd65e3ac0]: cf932000:XXXX.fr:NA:TellThreadToDie: close socket connection
-834668800[7f8cd65e3ac0]: cf932000:XXXX.fr:NA:CreateNewLineFromSocket: (null)
-834668800[7f8cd65e3ac0]: cf932000:XXXX.fr:NA:ProcessCurrentURL: aborting queued urls
-834668800[7f8cd65e3ac0]: ImapThreadMainLoop leaving [this=cf932000]
-834668800[7f8cd65e3ac0]: ImapThreadMainLoop entering [this=c2e07000]
-217573600[7f8cf1e59260]: c2e07000:XXXX.fr:NA:SetupWithUrl: clearing IMAP_CONNECTION_IS_OPEN
-834668800[7f8cd65e3ac0]: c2e07000:XXXX.fr:NA:ProcessCurrentURL: entering
-834668800[7f8cd65e3ac0]: c2e07000:XXxx.fr:NA:ProcessCurrentURL:imap://mon%2Enom@XXXX.fr:993/select%3E%5EINBOX: = currentUrl
-834668800[7f8cd65e3ac0]: c2e07000:XXXX.fr:NA:CreateNewLineFromSocket: clearing IMAP_CONNECTION_IS_OPEN - rv = 805a1f50
-834668800[7f8cd65e3ac0]: c2e07000:XXXX.fr:NA:TellThreadToDie: close socket connection
-834668800[7f8cd65e3ac0]: c2e07000:XXXX.fr:NA:CreateNewLineFromSocket: (null)
-834668800[7f8cd65e3ac0]: c2e07000:XXXX.fr:NA:ProcessCurrentURL: aborting queued urls
-834668800[7f8cd65e3ac0]: ImapThreadMainLoop leaving [this=c2e07000]
J’ai tenté de comparer avec un compte IMAP fonctionnel, mais les différences sont tellement immenses que je n’arrive pas à voir ce qui est normal ou non.
Je ne sais même pas dans ce log ce qui peut être une erreur. Je suis donc preneur de toute aide quant à l’interprétation de ces messages et à la solution de mon problème.
Les autres personnes qui ont eu ce même problème avant moi l’ont eu en 2006, et l’ont résolu avec une simple mise à jour.
Duna
je ne voi pas trop ce qui cloche
