Ecran noir avec LightDM
J’ai un écran noir au démarrage de LightDM.
/var/log/lightdm/lightdm.log contient :
[+0.00s] DEBUG: Logging to /var/log/lightdm/lightdm.log [+0.00s] DEBUG: Starting Light Display Manager 1.0.11, UID=0 PID=1942 [+0.00s] DEBUG: Loaded configuration from /etc/lightdm/lightdm.conf [+0.00s] DEBUG: Using D-Bus name org.freedesktop.DisplayManager [+0.00s] DEBUG: Registered seat module xlocal [+0.00s] DEBUG: Registered seat module xremote [+0.00s] DEBUG: Adding default seat [+0.00s] DEBUG: Starting seat [+0.00s] DEBUG: Starting new display for greeter [+0.00s] DEBUG: Starting local X display [+0.00s] DEBUG: Could not run plymouth --ping: Failed to execute child process "plymouth" (No such file or directory) [+0.00s] DEBUG: Using VT 7 [+0.00s] DEBUG: Activating VT 7 [+0.00s] DEBUG: Logging to /var/log/lightdm/x-0.log [+0.00s] DEBUG: Writing X server authority to /var/run/lightdm/root/:0 [+0.00s] DEBUG: Launching X Server [+0.00s] DEBUG: Launching process 1972: /usr/bin/X :0 -auth /var/run/lightdm/root/:0 -nolisten tcp vt7 -novtswitch [+0.00s] DEBUG: Waiting for ready signal from X server :0 [+0.00s] DEBUG: Acquired bus name org.freedesktop.DisplayManager [+0.01s] DEBUG: Registering seat with bus path /org/freedesktop/DisplayManager/Seat0 [+2.45s] DEBUG: Got signal 10 from process 1972 [+2.45s] DEBUG: Got signal from X server :0 [+2.45s] DEBUG: Connecting to XServer :0 [+2.45s] DEBUG: Starting greeter session [+2.45s] DEBUG: org.freedesktop.Accounts does not exist, falling back to passwd file [+2.73s] DEBUG: pam_start("lightdm", "lightdm") -> (0xf8c36510, 0) [+2.73s] DEBUG: Starting session lightdm-greeter as user lightdm [+2.79s] DEBUG: Logging to /var/log/lightdm/x-0-greeter.log [+2.79s] DEBUG: Launching session [+2.79s] DEBUG: pam_set_item(0xf8c36510, 3, ":0") -> 0 (Success) [+2.91s] DEBUG: pam_open_session(0xf8c36510, 0) -> 0 (Success) [+3.62s] DEBUG: Opened ConsoleKit session 564700ea6a2179cb01a6258200000a23-1335093400.618118-1616994634 [+3.62s] DEBUG: Dropping privileges to uid 106 [+3.62s] DEBUG: Adding session authority to /var/lib/lightdm/.Xauthority [+3.62s] DEBUG: Restoring privileges [+3.62s] WARNING: Failed to write authority: Error opening file '/var/lib/lightdm/.Xauthority': No such file or directory [+3.62s] DEBUG: Failed to start greeter [+3.62s] DEBUG: Failed to start greeter [+3.62s] DEBUG: Stopping display [+3.62s] DEBUG: Sending signal 15 to process 1972 [+3.62s] DEBUG: Dropping privileges to uid 106 [+3.62s] DEBUG: Removing session authority from /var/lib/lightdm/.Xauthority [+3.62s] DEBUG: Restoring privileges [+3.62s] DEBUG: Greeter closed communication channel [+3.88s] DEBUG: Process 1972 exited with return value 0 [+3.88s] DEBUG: X server stopped [+3.88s] DEBUG: Removing X server authority /var/run/lightdm/root/:0 [+3.88s] DEBUG: Releasing VT 7 [+3.88s] DEBUG: Display server stopped [+3.88s] DEBUG: Display stopped [+3.88s] DEBUG: Stopping X local seat, failed to start a display [+3.88s] DEBUG: Stopping seat [+3.88s] DEBUG: Seat stopped [+3.88s] DEBUG: Required seat has stopped [+3.88s] DEBUG: Stopping display manager [+3.88s] DEBUG: Display manager stopped [+3.88s] DEBUG: Stopping daemon [+3.88s] DEBUG: Exiting with return value 1
