Je suis un nouveau sur debian [etch],j’ai utilisé ubuntu pendant un ans.
J’ai récemment installé débian grace au netinstall et j’essaye d’installer compiz-fusion. J’ai simplement suivit l’explication ici. Tout fonctionne correctement jusqua compiz-manager qui me retourne ceci :
[code]Checking for Xgl: not present.
xset q doesn’t reveal the location of the log file. Using fallback /var/log/Xorg.0.log
Detected PCI ID for VGA: 01:00.0 0300: 10de:05e2 (rev a1) (prog-if 00 [VGA])
Checking for texture_from_pixmap: present.
Checking for non power of two support: present.
Checking for Composite extension: present.
Comparing resolution (1280x1024) to maximum 3D texture size (8192): Passed.
Checking for nVidia: present.
Checking for FBConfig: present.
Starting emerald
(emerald:13581): Wnck-WARNING **: Unhandled action type (nil)
(emerald:13581): Wnck-WARNING **: Unhandled action type (nil)[/code]
donc un petit emerald --replace me donne :
code: Wnck-WARNING **: Unhandled action type (nil)
xorg.conf :
[code]# nvidia-xconfig: X configuration file generated by nvidia-xconfig
nvidia-xconfig: version 1.0 (buildmeister@builder63) Wed Oct 1 15:09:35 PDT 2008
/etc/X11/xorg.conf (xorg X Window System server configuration file)
This file was generated by dexconf, the Debian X Configuration tool, using
values from the debconf database.
Edit this file with caution, and see the /etc/X11/xorg.conf manual page.
(Type “man /etc/X11/xorg.conf” at the shell prompt.)
This file is automatically updated on xserver-xorg package upgrades only
if it has not been modified since the last upgrade of the xserver-xorg
package.
If you have edited this file but would like it to be automatically updated
again, run the following command:
sudo dpkg-reconfigure -phigh xserver-xorg
Section "ServerLayout"
Identifier "Default Layout"
Screen “Default Screen” 0 0
InputDevice "Generic Keyboard"
InputDevice "Configured Mouse"
EndSection
Section “Files”
# path to defoma fonts
FontPath "/usr/share/fonts/X11/misc"
FontPath "/usr/X11R6/lib/X11/fonts/misc"
FontPath "/usr/share/fonts/X11/cyrillic"
FontPath "/usr/X11R6/lib/X11/fonts/cyrillic"
FontPath "/usr/share/fonts/X11/100dpi/:unscaled"
FontPath "/usr/X11R6/lib/X11/fonts/100dpi/:unscaled"
FontPath "/usr/share/fonts/X11/75dpi/:unscaled"
FontPath "/usr/X11R6/lib/X11/fonts/75dpi/:unscaled"
FontPath "/usr/share/fonts/X11/Type1"
FontPath "/usr/X11R6/lib/X11/fonts/Type1"
FontPath "/usr/share/fonts/X11/100dpi"
FontPath "/usr/X11R6/lib/X11/fonts/100dpi"
FontPath "/usr/share/fonts/X11/75dpi"
FontPath "/usr/X11R6/lib/X11/fonts/75dpi"
FontPath "/var/lib/defoma/x-ttcidfont-conf.d/dirs/TrueType"
EndSection
Section "Module"
Load "i2c"
Load "bitmap"
Load "ddc"
Load "extmod"
Load "freetype"
Load "glx"
Load "int10"
Load "vbe"
EndSection
Section "InputDevice"
Identifier "Generic Keyboard"
Driver "kbd"
Option "CoreKeyboard"
Option “XkbRules” "xorg"
Option “XkbModel” "pc105"
Option “XkbLayout” "fr"
Option “XkbVariant” "latin9"
EndSection
Identifier "Configured Mouse"
Driver "mouse"
Option "CorePointer"
Option “Device” "/dev/input/mice"
Option “Protocol” "ExplorerPS/2"
Option “Buttons” "5"
EndSection
Section "Monitor"
Identifier "Écran générique"
HorizSync 28.0 - 64.0
VertRefresh 43.0 - 60.0
Option "DPMS"
EndSection
Section "Device"
Identifier "nVidia Corporation NVIDIA Default Card"
Driver "nvidia"
EndSection
Section "Screen"
Identifier "Default Screen"
Device "nVidia Corporation NVIDIA Default Card"
Monitor "Écran générique"
DefaultDepth 24
Option “RenderAccel” "true"
Option “AllowGLXWithComposite” "true"
SubSection "Display"
Depth 1
Modes “1280x1024” “1024x768” “800x600” "640x480"
EndSubSection
Depth 4
EndSubSection
Depth 8
EndSubSection
Depth 15
EndSubSection
Depth 16
EndSubSection
Depth 24
EndSubSection
EndSection
Section "Extensions"
Option “Composite” "Enable"
EndSection
compiz-check :
[code]Gathering information about your system…
Distribution: Debian GNU/Linux (4.0)
Desktop environment: GNOME
Graphics chip: nVidia Corporation Unknown device 05e2 (rev a1)
Driver in use: nvidia
Rendering method: Nvidia
Checking if it’s possible to run Compiz on your system…
Checking for texture_from_pixmap… [ OK ]
Checking for non power of two support… [ OK ]
Checking for composite extension… [ OK ]
Checking for FBConfig… [ OK ]
Checking for hardware/setup problems… [ OK ]
glxinfo | grep direct :
Ma carte graphique est une nVidia 260 GTX avec les pilotes 177.80 correctment installé.
Merci de votre aide , cordialement deelazy
