Bonsoir tout le monde
Je suis en traain de galérer avec xcompmgr, quand je tape
xcompmgr -c -f
le terminal clignote de partout et c’est completement inutilisable
pourtant je pense avoir tout ceux qu’il faut
glxinfo | grep 's3tc\|direct'
direct rendering: Yes
reynald@debian:~$ dmesg | grep radeon
[ 18.611253] radeonfb: Retrieved PLL infos from BIOS
[ 18.611267] radeonfb: Reference=14.32 MHz (RefDiv=31) Memory=183.00 Mhz, System=133.00 MHz
[ 18.611272] radeonfb: PLL min 12000 max 35000
[ 20.492057] radeonfb: Monitor 1 type LCD found
[ 20.492062] radeonfb: Monitor 2 type no found
[ 20.492068] radeonfb: panel ID string: 1024x768
[ 20.492072] radeonfb: detected LVDS panel size from BIOS: 1024x768
[ 20.492077] radeondb: BIOS provided dividers will be used
[ 20.728052] radeonfb: Dynamic Clock Power Management enabled
[ 20.904329] radeonfb (0000:01:05.0): ATI Radeon 4337 "C7"
[ 20.981021] [drm] Initialized radeon 1.29.0 20080528 on minor 0
reynald@debian:~$ lspci | grep VGA
01:05.0 VGA compatible controller: ATI Technologies Inc Radeon IGP 330M/340M/350M
j’ai bidouillé un peu un xorg.conf
Section "Module"
Load "i2c"
Load "bitmap"
Load "dbe"
Load "ddc"
Load "dri"
Load "extmod"
Load "freetype"
Load "glx"
Load "int10"
Load "record"
Load "type1"
Load "vbe"
# mano
Load "GLcore"
Load "synaptics"
EndSection
Section "InputDevice"
Identifier "Generic Keyboard"
Driver "kbd"
Option "CoreKeyboard"
Option "XkbRules" "xorg"
Option "XkbModel" "pc105"
Option "XkbLayout" "fr" # "fr-oss" pour Feisty et +
Option "XkbVariant" "latin9"
EndSection
Section "Device"
Identifier "ATI Technologies, Inc. Radeon 330M/340M/350M (RS200 IGP)"
Driver "radeon"
# Nauji nustatymai
Option "AccelMethod" "EXA"
Option "AGPMode" "4"
Option "AGPFastWrite" "True"
Option "EnablePageFlip" "True"
Option "UseFBDev" "true"
BusID "PCI:1:5:0"
Option "DPMS"
#Videoram 65536
Option "RenderAccel" "true"
Option "SubPixelOrder" "NONE"
Option "ColorTiling" "false"
Option "XAANoOffscreenPixmaps" "true" # Utile si vous utilisez compiz
Option "RENDER" "enable"
#VideoRam 131072
EndSection
Section "Monitor"
Identifier "Generic Monitor"
Option "DPMS"
EndSection
Section "Screen"
Identifier "Default Screen"
Device "ATI Technologies, Inc. Radeon 330M/340M/350M (RS200 IGP)"
Monitor "Generic Monitor"
DefaultDepth 24
SubSection "Display"
Depth 16
Modes "1024x768"
EndSubSection
Depth 24
Modes "1024x768"
EndSubSection
EndSection
Section "Extensions"
Option "Composite" "Enable"
EndSection
Section "DRI"
Mode 0666
EndSection
Qu’en pensez vous ?
Merci ![]()
edit: j’allais oublié j’ai ajouté des trucs dans /etc/modules
[code] /etc/modules: kernel modules to load at boot time.
This file contains the names of kernel modules that should be loaded
at boot time, one per line. Lines beginning with “#” are ignored.
Parameters can be specified after the module name.
loop
agpgart
ati_agp
radeonfb
radeon
