Voici ce que j’ai trouvé mais je ne comprends rien, comme d’habitude :
[code]cat /etc/php5/conf.d/suhosin.ini
; configuration for php suhosin module
extension=suhosin.so
; Module Settings ;
; the following values are the internal default settings and set implicit
; feel free to modify to your needs
; documentation can be found at:
; http://www.hardened-php.net/suhosin/configuration.html
; or have a look into /usr/share/doc/php5-suhosin/examples/suhosin.ini.gz
[suhosin]
; Logging Configuration
;suhosin.log.syslog =
;suhosin.log.syslog.facility = 9
;suhosin.log.syslog.priority = 1
;suhosin.log.sapi =
;suhosin.log.script = 0
;suhosin.log.phpscript = 0
;suhosin.log.script.name =
;suhosin.log.phpscript.name =
;suhosin.log.use-x-forwarded-for = off
; Executor Options
;suhosin.executor.max_depth = 0
;suhosin.executor.include.max_traversal = 0
;suhosin.executor.include.whitelist =
;suhosin.executor.include.blacklist =
;suhosin.executor.include.allow_writable_files = on
;suhosin.executor.func.whitelist =
;suhosin.executor.func.blacklist =
;suhosin.executor.eval.whitelist =
;suhosin.executor.eval.blacklist =
;suhosin.executor.disable_eval = off
;suhosin.executor.disable_emodifier = off
;suhosin.executor.allow_symlink = off
; Misc Options
;suhosin.simulation = off
;suhosin.apc_bug_workaround = off
;suhosin.sql.bailout_on_error = off
;suhosin.sql.user_prefix =
;suhosin.sql.user_postfix =
;suhosin.multiheader = off
;suhosin.mail.protect = 0
;suhosin.memory_limit = 0
; Transparent Encryption Options
;suhosin.session.encrypt = on
;suhosin.session.cryptkey =
;suhosin.session.cryptua = on
;suhosin.session.cryptdocroot = on
;suhosin.session.cryptraddr = 0
;suhosin.session.checkraddr = 0
;suhosin.cookie.encrypt = on
;suhosin.cookie.cryptkey =
;suhosin.cookie.cryptua = on
;suhosin.cookie.cryptdocroot = on
;suhosin.cookie.cryptraddr = 0
;suhosin.cookie.checkraddr = 0
;suhosin.cookie.cryptlist =
;suhosin.cookie.plainlist =
; Randomness
;suhosin.srand.ignore = on
;suhosin.mt_srand.ignore = on
; Filtering Options
;suhosin.filter.action =
;suhosin.cookie.max_array_depth = 100
;suhosin.cookie.max_array_index_length = 64
;suhosin.cookie.max_name_length = 64
;suhosin.cookie.max_totalname_length = 256
;suhosin.cookie.max_value_length = 10000
;suhosin.cookie.max_vars = 100
;suhosin.cookie.disallow_nul = on
;suhosin.get.max_array_depth = 50
;suhosin.get.max_array_index_length = 64
;suhosin.get.max_name_length = 64
;suhosin.get.max_totalname_length = 256
;suhosin.get.max_value_length = 512
;suhosin.get.max_vars = 100
;suhosin.get.disallow_nul = on
;suhosin.post.max_array_depth = 100
;suhosin.post.max_array_index_length = 64
;suhosin.post.max_name_length = 64
;suhosin.post.max_totalname_length = 256
;suhosin.post.max_value_length = 1000000
;suhosin.post.max_vars = 1000
;suhosin.post.disallow_nul = on
;suhosin.request.max_array_depth = 100
;suhosin.request.max_array_index_length = 64
;suhosin.request.max_totalname_length = 256
;suhosin.request.max_value_length = 1000000
;suhosin.request.max_vars = 1000
;suhosin.request.max_varname_length = 64
;suhosin.request.disallow_nul = on
;suhosin.server.encode = on
;suhosin.server.strip = on
;suhosin.upload.max_uploads = 25
;suhosin.upload.disallow_elf = on
;suhosin.upload.disallow_binary = off
;suhosin.upload.remove_binary = off
;suhosin.upload.verification_script =
;suhosin.session.max_id_length = 128
;suhosin.coredump = off
;suhosin.protectkey = 1
;suhosin.stealth = 1
;suhosin.perdir = “0”
