Envoi de messages impossible Maarch LetterBox
Avec Maarch Letterbox, après avoir “uploadé” des fichiers, impossible de les envoyer à un destinataire:
Warning: scandir(/home/ged/var/www/LetterBox/docserver/) [function.scandir]: failed to open dir: No such file or directory in /var/www/LetterBox/class_docserver.php on line 39
Warning: scandir() [function.scandir]: (errno 2): No such file or directory in /var/www/LetterBox/class_docserver.php on line 39
Warning: array_shift() [function.array-shift]: The argument should be an array in /var/www/LetterBox/class_docserver.php on line 41
Warning: array_shift() [function.array-shift]: The argument should be an array in /var/www/LetterBox/class_docserver.php on line 42
Warning: scandir(/home/ged/var/www/LetterBox/docserver/1) [function.scandir]: failed to open dir: No such file or directory in /var/www/LetterBox/class_docserver.php on line 69
Warning: scandir() [function.scandir]: (errno 2): No such file or directory in /var/www/LetterBox/class_docserver.php on line 69
Warning: array_shift() [function.array-shift]: The argument should be an array in /var/www/LetterBox/class_docserver.php on line 71
Warning: array_shift() [function.array-shift]: The argument should be an array in /var/www/LetterBox/class_docserver.php on line 72
Warning: copy(/home/ged/var/www/LetterBox/ftp/tmp_file_demo.odt) [function.copy]: failed to open stream: No such file or directory in /var/www/LetterBox/file_index.php on line 431
DE quoi ca vient s’il vous plaît?
hello,
Existe t’il ce rép ?
Si oui y a t’il des fichiers etc…, comment as tu installé ce soft ?
