J’ai cette erreur lors d’un apt :
[quote]Paramétrage de samba (2:4.5.5+dfsg-1) …
Failed to preset unit: Unit file /etc/systemd/system/samba-ad-dc.service is masked.
/usr/bin/deb-systemd-helper: error: systemctl preset failed on samba-ad-dc.service: No such file or directory
Job for smbd.service failed because the control process exited with error code.
See “systemctl status smbd.service” and “journalctl -xe” for details.
invoke-rc.d: initscript smbd, action “start” failed.
● smbd.service - Samba SMB Daemon
Loaded: loaded (/lib/systemd/system/smbd.service; enabled; vendor preset: enabled)
Active: failed (Result: exit-code) since Sat 2017-03-11 14:05:37 CET; 67ms ago
Docs: man:smbd(8)
man:samba(7)
man:smb.conf(5)
Process: 1740 ExecStart=/usr/sbin/smbd $SMBDOPTIONS (code=exited, status=1/FAILURE)
Main PID: 1740 (code=exited, status=1/FAILURE)
mars 11 14:05:37 netbook systemd[1]: Starting Samba SMB Daemon…
mars 11 14:05:37 netbook systemd[1]: smbd.service: Main process exited, cod…LURE
mars 11 14:05:37 netbook systemd[1]: Failed to start Samba SMB Daemon.
mars 11 14:05:37 netbook systemd[1]: smbd.service: Unit entered failed state.
mars 11 14:05:37 netbook systemd[1]: smbd.service: Failed with result ‘exit…de’.
Hint: Some lines were ellipsized, use -l to show in full.
dpkg: erreur de traitement du paquet samba (–configure) :
le sous-processus script post-installation installé a retourné une erreur de sortie d’état 1
Traitement des actions différées (« triggers ») pour libc-bin (2.24-9) …
samba
E: Sub-process /usr/bin/dpkg returned an error code (1)[/quote]
