je suis actuellement sur lenny et suite à une mise à jour, à l’ouverture de la session X, il y a un message d’erreur. Le voici:
[quote]/etc/gdm/Xsession:Beginning session setup
/etc/bash.bashrc: 11: shopt: not found
/etc/bash.bashrc: 46: Syntax error: “}” unexpected (expecting “fi”[/quote]
je vous joins une copie du /etc/bash.bashrc:
[quote]1 # System-wide .bashrc file for interactive bash(1) shells.
2
3 # To enable the settings / commands in this file for login shells as well,
4 # this file has to be sourced in /etc/profile.
5
6 # If not running interactively, don’t do anything
7 [ -z “$PS1” ] && return
8
9 # check the window size after each command and, if necessary,
10 # update the values of LINES and COLUMNS.
11 shopt -s checkwinsize
12
13 # set variable identifying the chroot you work in (used in the prompt below)
14 if [ -z “$debian_chroot” ] && [ -r /etc/debian_chroot ]; then
15 debian_chroot=$(cat /etc/debian_chroot)
16 fi
17
18 # set a fancy prompt (non-color, overwrite the one in /etc/profile)
19 PS1=’${debian_chroot:+($debian_chroot)}\u@\h:\w$ '
20
21 # Commented out, don’t overwrite xterm -T “title” -n “icontitle” by default.
22 # If this is an xterm set the title to user@host:dir
23 #case “$TERM” in
24 #xterm*|rxvt*)
25 # PROMPT_COMMAND='echo -ne “\033]0;${USER}@${HOSTNAME}: ${PWD}\007”'
26 # ;;
27 #*)
28 # ;;
29 #esac
30
31 # enable bash completion in interactive shells
32 #if [ -f /etc/bash_completion ]; then
33 # . /etc/bash_completion
34 #fi
35
36 # if the command-not-found package is installed, use it
37 if [ -x /usr/lib/command-not-found ]; then
38 function command_not_found_handle {
39 # check because c-n-f could’ve been removed in the meantime
40 if [ -x /usr/lib/command-not-found ]; then
41 /usr/bin/python /usr/lib/command-not-found – $1
42 return $?
43 else
44 return 127
45 fi
46 }
47 fi[/quote]
Merci de me dépanner
Varron
