bonjour,
comme dit dans le titre,
j’ai une erreur de compilation de john
je n’utilise pas le paquet tout fait car je souhaite pouvoir utiliser rar2john
j’ai donc telecharge l’archive John the Ripper 1.7.9-jumbo-7 (Unix - sources, tar.bz2, 1559 KB)
mais lors de la compilation j’ai 2 erreurs:
cri@debian:~/Téléchargements/john-1.7.9-jumbo-7/src$ make clean linux-x86-native
rm -f ../run/john ../run/unshadow ../run/unafs ../run/unique ../run/undrop ../run/ssh2john ../run/pdf2john ../run/rar2john ../run/zip2john ../run/genmkvpwd ../run/mkvcalcproba ../run/calc_stat ../run/tgtsnarf ../run/racf2john ../run/mozilla2john ../run/hccap2john ../run/pwsafe2john ../run/raw2dyna ../run/keepass2john ../run/keychain2john john.local.conf ../run/john.bin ../run/john.com ../run/unshadow.com ../run/unafs.com ../run/unique.com ../run/undrop.com ../run/ssh2john.com ../run/pdf2john.com ../run/rar2john.com ../run/zip2john ../run/racf2john.com ../run/mozilla2john.com ../run/hccap2john.com ../run/pwsafe2john.com ../run/keepass2john.com ../run/keychain2john.com john.local.conf ../run/john.exe ../run/unshadow.exe ../run/unafs.exe ../run/unique.exe ../run/undrop.exe ../run/ssh2john.exe ../run/pdf2john.exe ../run/rar2john.exe ../run/zip2john.exe ../run/genmkvpwd.exe ../run/mkvcalcproba.exe ../run/calc_stat.exe ../run/racf2john.exe ../run/mozilla2john.exe ../run/hccap2john.exe ../run/pwsafe2john.exe ../run/raw2dyna.exe ../run/keepass2john.exe ../run/keychain2john.exe john.local.conf ../run/john-mingw.exe ../run/unshadow.exe ../run/unafs.exe ../run/unique.exe ../run/undrop.exe ../run/ssh2john.exe ../run/pdf2john.exe ../run/rar2john.exe ../run/zip2john.exe ../run/genmkvpwd.exe ../run/mkvcalcproba.exe ../run/calc_stat.exe ../run/racf2john.exe ../run/mozilla2john.exe ../run/hccap2john.exe ../run/pwsafe2john.exe ../run/raw2dyna.exe ../run/keepass2john.exe ../run/keychain2john.exe john.local.conf
rm -f ../run/john.exe john-macosx-* *.o *.bak core
rm -f ../run/*.cl ../run/*.h ../run/office2john ../run/vncpcap2john
rm -f detect bench para-bench generic.h arch.h tmp.s
rm -f cuda/*.o cuda/*~ *~ ../run/SIPdump
rm -f fmt_registers.h fmt_externs.h john_build_rule.h
cp /dev/null Makefile.dep
ln -f -s x86-sse.h arch.h
make ../run/john ../run/unshadow ../run/unafs ../run/unique ../run/undrop ../run/ssh2john ../run/pdf2john ../run/rar2john ../run/zip2john ../run/genmkvpwd ../run/mkvcalcproba ../run/calc_stat ../run/tgtsnarf ../run/racf2john ../run/mozilla2john ../run/hccap2john ../run/pwsafe2john ../run/raw2dyna ../run/keepass2john ../run/keychain2john john.local.conf \
JOHN_OBJS=" DES_fmt.o DES_std.o DES_bs.o DES_bs_b.o BSDI_fmt.o MD5_fmt.o MD5_std.o BF_fmt.o BF_std.o AFS_fmt.o LM_fmt.o trip_fmt.o timer.o md5_go.o md5_eq.o md5.o rc4.o hmacmd5.o base64.o md4.o dynamic_fmt.o dynamic_parser.o dynamic_preloads.o dynamic_utils.o rawSHA224_fmt.o rawSHA256_fmt.o rawSHA384_fmt.o rawSHA512_fmt.o hmacMD5_fmt.o hmacSHA1_fmt.o hmacSHA224_fmt.o hmacSHA256_fmt.o hmacSHA384_fmt.o hmacSHA512_fmt.o episerver_fmt.o keepass_fmt.o pwsafe_fmt.o XSHA512_fmt.o hmailserver_fmt.o dragonfly3_fmt.o dragonfly4_fmt.o drupal7_fmt.o django_fmt.o cryptsha256_fmt.o cryptsha512_fmt.o SybaseASE_fmt.o SKEY_fmt.o ssh_fmt.o ssh2john.o pdf_fmt.o pdf2john.o pdfcrack_common.o pdfcrack_md5.o pdfparser.o pdfcrack.o pdfcrack_rc4.o unrarcmd.o unrarfilter.o unrarhlp.o unrar.o unrarppm.o unrarvm.o rar_fmt.o rar2john.o rawSHA0_fmt.o zip_fmt.o zip2john.o gladman_hmac.o gladman_pwd2key.o racf2john.o pwsafe2john.o keepass2john.o keychain2john.o wpapsk_fmt.o hccap2john.o mozilla_fmt.o KeyDBCracker.o mozilla_des.o lowpbe.o mozilla2john.o BFEgg_fmt_plug.o crc32_fmt_plug.o DMD5_fmt_plug.o DOMINOSEC_fmt_plug.o EPI_fmt_plug.o gost_fmt_plug.o gost_plug.o HDAA_fmt_plug.o IPB2_fmt_plug.o keychain_fmt_plug.o KRB4_fmt_plug.o KRB4_std_plug.o KRB5_fmt_plug.o KRB5_std_plug.o lotus5_fmt_plug.o md4_gen_fmt_plug.o mediawiki_fmt_plug.o mscash1_fmt_plug.o mscash2_fmt_plug.o MSCHAPv2_fmt_plug.o mskrb5_fmt_plug.o mssql05_fmt_plug.o mssql-old_fmt_plug.o mysql_fmt_plug.o mysqlSHA1_fmt_plug.o NETLM_fmt_plug.o NETLMv2_fmt_plug.o NETNTLM_fmt_plug.o NETNTLMv2_fmt_plug.o NETSPLITLM_fmt_plug.o NS_fmt_plug.o nsldap_fmt_plug.o nt2_fmt_plug.o NT_fmt_plug.o odf_fmt_plug.o office_fmt_plug.o oracle11_fmt_plug.o oracle_fmt_plug.o osc_fmt_plug.o phpassMD5_fmt_plug.o PHPS_fmt_plug.o pixMD5_fmt_plug.o pkzip_fmt_plug.o PO_fmt_plug.o racf_fmt_plug.o rawMD4_fmt_plug.o rawMD5_fmt_plug.o rawmd5u_fmt_plug.o rawSHA1_fmt_plug.o rawSHA1_linkedIn_fmt_plug.o salted_sha1_fmt_plug.o sapB_fmt_plug.o sapG_fmt_plug.o sha1_gen_fmt_plug.o sip_fmt_plug.o vnc_fmt_plug.o wbb3_fmt_plug.o XSHA_fmt_plug.o rawSHA1_ng_fmt.o plugin.o dummy.o batch.o bench.o charset.o common.o compiler.o config.o cracker.o crc32.o external.o formats.o getopt.o idle.o inc.o john.o list.o loader.o logger.o math.o memory.o misc.o options.o params.o path.o recovery.o rpp.o rules.o signals.o single.o status.o tty.o wordlist.o mkv.o mkvlib.o fake_salts.o win32_memmap.o unicode.o unshadow.o unafs.o undrop.o unique.o c3_fmt.o x86.o x86-sse.o sha1-mmx.o md4-mmx.o md5-mmx.o sse-intrinsics.o" \
CFLAGS="-c -Wall -O2 -fomit-frame-pointer -Wdeclaration-after-statement -I/usr/local/include -DHAVE_CRYPT -DHAVE_DL -march=native" \
ASFLAGS="-c -march=native" \
LDFLAGS="-s -L/usr/local/lib -L/usr/local/ssl/lib -lssl -lcrypto -lm -lz -lcrypt -ldl -march=native"
make[1]: entrant dans le répertoire « /home/cri/Téléchargements/john-1.7.9-jumbo-7/src »
gcc -c -Wall -O2 -fomit-frame-pointer -Wdeclaration-after-statement -I/usr/local/include -DHAVE_CRYPT -DHAVE_DL -march=native -funroll-loops DES_fmt.c
gcc -c -Wall -O2 -fomit-frame-pointer -Wdeclaration-after-statement -I/usr/local/include -DHAVE_CRYPT -DHAVE_DL -march=native -funroll-loops DES_std.c
gcc -c -Wall -O2 -fomit-frame-pointer -Wdeclaration-after-statement -I/usr/local/include -DHAVE_CRYPT -DHAVE_DL -march=native -funroll-loops DES_bs.c
DES_bs.c:310:25: warning: always_inline function might not be inlinable [-Wattributes]
gcc -c -Wall -O2 -fomit-frame-pointer -Wdeclaration-after-statement -I/usr/local/include -DHAVE_CRYPT -DHAVE_DL -march=native -Os -funroll-loops -finline-functions DES_bs_b.c
DES_bs_b.c:1415:26: warning: always_inline function might not be inlinable [-Wattributes]
In file included from DES_bs_b.c:1087:0:
nonstd.c:2754:1: warning: always_inline function might not be inlinable [-Wattributes]
nonstd.c:2677:1: warning: always_inline function might not be inlinable [-Wattributes]
nonstd.c:1483:1: warning: always_inline function might not be inlinable [-Wattributes]
nonstd.c:1327:1: warning: always_inline function might not be inlinable [-Wattributes]
nonstd.c:1115:1: warning: always_inline function might not be inlinable [-Wattributes]
nonstd.c:669:1: warning: always_inline function might not be inlinable [-Wattributes]
nonstd.c:592:1: warning: always_inline function might not be inlinable [-Wattributes]
nonstd.c:136:1: warning: always_inline function might not be inlinable [-Wattributes]
DES_bs_b.c:1000:26: warning: always_inline function might not be inlinable [-Wattributes]
gcc -c -Wall -O2 -fomit-frame-pointer -Wdeclaration-after-statement -I/usr/local/include -DHAVE_CRYPT -DHAVE_DL -march=native -funroll-loops BSDI_fmt.c
gcc -c -Wall -O2 -fomit-frame-pointer -Wdeclaration-after-statement -I/usr/local/include -DHAVE_CRYPT -DHAVE_DL -march=native -funroll-loops MD5_fmt.c
gcc -c -Wall -O2 -fomit-frame-pointer -Wdeclaration-after-statement -I/usr/local/include -DHAVE_CRYPT -DHAVE_DL -march=native -funroll-loops MD5_std.c
gcc -c -Wall -O2 -fomit-frame-pointer -Wdeclaration-after-statement -I/usr/local/include -DHAVE_CRYPT -DHAVE_DL -march=native -funroll-loops BF_fmt.c
gcc -c -Wall -O2 -fomit-frame-pointer -Wdeclaration-after-statement -I/usr/local/include -DHAVE_CRYPT -DHAVE_DL -march=native -funroll-loops BF_std.c
gcc -c -Wall -O2 -fomit-frame-pointer -Wdeclaration-after-statement -I/usr/local/include -DHAVE_CRYPT -DHAVE_DL -march=native -funroll-loops AFS_fmt.c
gcc -c -Wall -O2 -fomit-frame-pointer -Wdeclaration-after-statement -I/usr/local/include -DHAVE_CRYPT -DHAVE_DL -march=native -funroll-loops LM_fmt.c
gcc -c -Wall -O2 -fomit-frame-pointer -Wdeclaration-after-statement -I/usr/local/include -DHAVE_CRYPT -DHAVE_DL -march=native -funroll-loops trip_fmt.c
trip_fmt.c:341:26: warning: always_inline function might not be inlinable [-Wattributes]
trip_fmt.c:294:26: warning: always_inline function might not be inlinable [-Wattributes]
gcc -c -Wall -O2 -fomit-frame-pointer -Wdeclaration-after-statement -I/usr/local/include -DHAVE_CRYPT -DHAVE_DL -march=native -funroll-loops timer.c
gcc -c -Wall -O2 -fomit-frame-pointer -Wdeclaration-after-statement -I/usr/local/include -DHAVE_CRYPT -DHAVE_DL -march=native -funroll-loops md5_go.c
gcc -c -Wall -O2 -fomit-frame-pointer -Wdeclaration-after-statement -I/usr/local/include -DHAVE_CRYPT -DHAVE_DL -march=native -funroll-loops md5_eq.c
gcc -c -Wall -O2 -fomit-frame-pointer -Wdeclaration-after-statement -I/usr/local/include -DHAVE_CRYPT -DHAVE_DL -march=native -funroll-loops md5.c
gcc -c -Wall -O2 -fomit-frame-pointer -Wdeclaration-after-statement -I/usr/local/include -DHAVE_CRYPT -DHAVE_DL -march=native -funroll-loops rc4.c
gcc -c -Wall -O2 -fomit-frame-pointer -Wdeclaration-after-statement -I/usr/local/include -DHAVE_CRYPT -DHAVE_DL -march=native -funroll-loops hmacmd5.c
gcc -c -Wall -O2 -fomit-frame-pointer -Wdeclaration-after-statement -I/usr/local/include -DHAVE_CRYPT -DHAVE_DL -march=native -funroll-loops base64.c
gcc -c -Wall -O2 -fomit-frame-pointer -Wdeclaration-after-statement -I/usr/local/include -DHAVE_CRYPT -DHAVE_DL -march=native -funroll-loops md4.c
gcc -c -Wall -O2 -fomit-frame-pointer -Wdeclaration-after-statement -I/usr/local/include -DHAVE_CRYPT -DHAVE_DL -march=native -funroll-loops dynamic_fmt.c
In file included from dynamic_fmt.c:69:0:
sha.h:4:25: fatal error: openssl/sha.h: Aucun fichier ou dossier de ce type
compilation terminated.
make[1]: *** [dynamic_fmt.o] Erreur 1
make[1]: quittant le répertoire « /home/cri/Téléchargements/john-1.7.9-jumbo-7/src »
make: *** [linux-x86-native] Erreur 2
des idées?
