Bonsoir,
J’ai besoin d’un petit coup de main sur une erreur de compil :
[code]cat /var/log/vbox-install.log
/usr/share/virtualbox/src/vboxhost/build_in_tmp: line 62: make: command not found
Makefile:186: Warning: using /usr/src/linux as the source directory of your Linux kernel. If this is not correct, specify KERN_DIR= and run Make again.
make KBUILD_VERBOSE=1 SUBDIRS=/tmp/vbox.0 SRCROOT=/tmp/vbox.0 CONFIG_MODULE_SIG= -C /usr/src/linux modules
test -e include/generated/autoconf.h -a -e include/config/auto.conf || ( \
echo >&2; \
echo >&2 " ERROR: Kernel configuration is invalid."; \
echo >&2 " include/generated/autoconf.h or include/config/auto.conf are missing.";\
echo >&2 " Run ‘make oldconfig && make prepare’ on kernel src to fix it."; \
echo >&2 ; \
/bin/false)
mkdir -p /tmp/vbox.0/.tmp_versions ; rm -f /tmp/vbox.0/.tmp_versions/*
compilation terminated.
make[2]: *** [/tmp/vbox.0/linux/SUPDrv-linux.o] Erreur 1
make[1]: *** [module/tmp/vbox.0] Error 2
make: *** [vboxdrv] Error 2
Kernel | devel | source | header sont installés
make est installé
autoconf est installé
gcc est installé
Et la soluce de faire :
make oldconfig && make prepare me répond que " Aucune règles pour fabriquer la cible “oldconfig”
Merci de votre aide…
