[code]seal:/usr/src/linux# make-kpkg --append-to-version “-seal” --initrd modules_image
for module in /usr/src/modules/ndiswrapper ; do
if test -d $module; then
(cd $module;
if ./debian/rules KVERS=“2.6.14-seal” KSRC="/usr/src/linux"
KMAINT=“Unknown Kernel Package Maintainer” KEMAIL=“unknown@unconfigured.in.etc.kernel-pkg.conf”
KPKG_DEST_DIR="/usr/src/linux/…"
KPKG_MAINTAINER=“Unknown Kernel Package Maintainer”
KPKG_EXTRAV_ARG=“EXTRAVERSION=-seal”
ARCH=“i386”
KDREV=“10.00.Custom” kdist_image; then
echo “Module $module processed fine”;
else
echo “Module $module failed.”;
if [ “X” != “X” ]; then
echo “Perhaps $module does not understand --rootcmd?”;
echo “If you see messages that indicate that it is not”;
echo "in fact being built as root, please file a bug ";
echo “against $module.”;
fi;
echo “Hit return to Continue”;
read ans;
fi;
else
echo “Module $module does not exist”;
echo “Hit return to Continue?”;
fi;
done
make[1]: Entering directory /usr/src/modules/ndiswrapper' /usr/bin/make -w -f debian/rules kdist_clean kdist_config binary-modules make[2]: Entering directory/usr/src/modules/ndiswrapper’
/usr/bin/gcc-4.0
for templ in ; do
cp $templ echo $templ | sed -e 's/_KVERS_/2.6.14-seal/g' ;
done
for templ in ls debian/*.modules.in ; do
test -e ${templ%.modules.in}.backup || cp ${templ%.modules.in} ${templ%.modules.in}.backup 2>/dev/null || true;
sed -e ‘s/##KVERS##/2.6.14-seal/g ;s/#KVERS#/2.6.14-seal/g ; s/KVERS/2.6.14-seal/g ; s/##KDREV##/10.00.Custom/g ; s/#KDREV#/10.00.Custom/g ; s/KDREV/10.00.Custom/g’ < $templ > ${templ%.modules.in};
done
dh_clean
/usr/bin/make clean
make[3]: Entering directory /usr/src/modules/ndiswrapper' rm -rf ndiswrapper.ko ndiswrapper.o hal.o iw_ndis.o loader.o misc_funcs.o ndis.o ntoskernel.o pe_linker.o proc.o wrapper.o usb.o divdi3.o usb.o x86_64_stubs.o \ divdi3.o .*.ko.cmd .*.o.cmd ndiswrapper.mod.[oc] *~ .tmp_versions make[3]: Leaving directory/usr/src/modules/ndiswrapper’
make[2]: Rien à faire pour « kdist_config ».
dh_testdir
dh_testroot
dh_clean -k
dh_installdirs lib/modules/2.6.14-seal/misc
build and install the module
/usr/bin/make KPKG_EXTRAV_ARG=EXTRAVERSION=-seal KSRC=/usr/src/linux
KVER=2.6.14-seal
INST_DIR=debian/ndiswrapper-modules-2.6.14-seal/lib/modules/2.6.14-seal/misc/ install
make[3]: Entering directory /usr/src/modules/ndiswrapper' /usr/bin/make -C /usr/src/linux SUBDIRS=/usr/src/modules/ndiswrapper \ NDISWRAPPER_VERSION=1.1 \ EXTRA_VERSION= modules make[4]: Entering directory/usr/src/linux-source-2.6.14’
CC [M] /usr/src/modules/ndiswrapper/hal.o
CC [M] /usr/src/modules/ndiswrapper/iw_ndis.o
CC [M] /usr/src/modules/ndiswrapper/loader.o
/usr/src/modules/ndiswrapper/loader.c: In function ‘register_devices’:
/usr/src/modules/ndiswrapper/loader.c:861: warning: assignment from incompatible pointer type
CC [M] /usr/src/modules/ndiswrapper/misc_funcs.o
CC [M] /usr/src/modules/ndiswrapper/ndis.o
/usr/src/modules/ndiswrapper/ndis.c:1637:5: warning: “LINUX_KERNEL_VERSION” is not defined
CC [M] /usr/src/modules/ndiswrapper/ntoskernel.o
CC [M] /usr/src/modules/ndiswrapper/pe_linker.o
/usr/src/modules/ndiswrapper/pe_linker.c:104:5: warning: “DEBUG” is not defined
CC [M] /usr/src/modules/ndiswrapper/proc.o
CC [M] /usr/src/modules/ndiswrapper/wrapper.o
/usr/src/modules/ndiswrapper/wrapper.c:286:46: error: macro “halt” passed 1 arguments, but takes just 0
/usr/src/modules/ndiswrapper/wrapper.c: In function ‘miniport_halt’:
/usr/src/modules/ndiswrapper/wrapper.c:286: warning: statement with no effect
make[5]: *** [/usr/src/modules/ndiswrapper/wrapper.o] Erreur 1
make[4]: *** [module/usr/src/modules/ndiswrapper] Erreur 2
make[4]: Leaving directory /usr/src/linux-source-2.6.14' make[3]: *** [default] Erreur 2 make[3]: Leaving directory/usr/src/modules/ndiswrapper’
make[2]: *** [binary-modules] Erreur 2
make[2]: Leaving directory /usr/src/modules/ndiswrapper' make[1]: *** [kdist_build] Erreur 2 make[1]: Leaving directory/usr/src/modules/ndiswrapper’
Module /usr/src/modules/ndiswrapper failed.
Je ne sais pas trop quoi mettre d’autre pour les infos que vous avez besoin
