Bonsoir,
Voila, lorsque je veux graver un fichier avec k3b, la gravure s’arrête avec ce message d’erreur :
Lors du show debugging pour en savoir plus sur la cause, j’ai sa :
[code]System
K3b Version: 0.12.17
KDE Version: 3.5.4
QT Version: 3.3.6
Kernel: 2.6.17-2-k7
Devices
SAMSUNG CD-R/RW SW-252F R801 (/dev/hdd, ) at /media/cdrom1 [CD-R; CD-RW; CD-ROM] [CD-ROM; CD-R; CD-RW] [SAO; TAO; RAW; SAO/R96R; RAW/R16; RAW/R96R]
HL-DT-ST DVD-ROM GDR8163B 0L23 (/dev/hdc, ) at /media/cdrom0 [CD-ROM; DVD-ROM] [DVD-ROM; CD-ROM] [None]
K3b
Size of filesystem calculated: 90073
Used versions
cdrecord: 2.1.1a03
cdrecord
/usr/bin/cdrecord: Warning: Running on Linux-2.6.17-2-k7
/usr/bin/cdrecord: There are unsettled issues with Linux-2.5 and newer.
/usr/bin/cdrecord: If you have unexpected problems, please try Linux-2.4 or Solaris.
scsidev: ‹ /dev/hdd ›
devname: ‹ /dev/hdd ›
scsibus: -2 target: -2 lun: -2
Warning: Open by ‹ devname › is unintentional and not supported.
Linux sg driver version: 3.5.27
Error: Cannot gain SYS_RAWIO capability.Is cdrecord installed SUID root?
: Operation not permitted
/usr/bin/cdrecord: Warning: using inofficial version of libscg (debian-0.8debian2 ‹ @(#)scsitransp.c 1.91 04/06/17 Copyright 1988,1995,2000-2004 J. Schilling ›).
SCSI buffer size: 64512
Cdrecord-Clone 2.01.01a03 (i686-pc-linux-gnu) Copyright © 1995-2005 Joerg Schilling
NOTE: this version of cdrecord is an inofficial (modified) release of cdrecord
and thus may have bugs that are not present in the original version.
Please send bug reports and support requests to cdrtools@packages.debian.org.
The original author should not be bothered with problems of this version.
TOC Type: 3 = CD-ROM XA mode 2
Using libscg version ‹ debian-0.8debian2 ›.
Driveropts: ‹ burnfree ›
atapi: 1
Device type : Removable CD-ROM
Version : 0
Response Format: 1
Vendor_info : 'SAMSUNG ’
Identifikation : 'CD-R/RW SW-252F ’
Revision : ‹ R801 ›
Device seems to be: Generic mmc CD-RW.
Current: 0x0009
Profile: 0x000A
Profile: 0x0009 (current)
Profile: 0x0008
Using generic SCSI-3/mmc CD-R/CD-RW driver (mmc_cdr).
Driver flags : MMC-3 SWABAUDIO BURNFREE
Supported modes: TAO PACKET SAO SAO/R96R RAW/R16 RAW/R96R
Drive buf size : 1279488 = 1249 KB
FIFO size : 4194304 = 4096 KB
/usr/bin/cdrecord: Operation not permitted. Cannot send SCSI cmd via ioctl
Track 01: data 175 MB
Total size: 202 MB (20:01.00) = 90075 sectors
Lout start: 202 MB (20:03/00) = 90075 sectors
cdrecord command:
/usr/bin/cdrecord.mmap -v gracetime=2 dev=/dev/hdd speed=52 -tao driveropts=burnfree -eject -multi -xa -tsize=90073s -
mkisofs
90073
INFO: ISO-8859-15 character encoding detected by locale settings.
Assuming ISO-8859-15 encoded filenames on source filesystem,
use -input-charset to override.
mkisofs command:
/usr/bin/mkisofs -gui -graft-points -volid K3b data project -volset -appid K3B THE CD KREATOR © 1998-2005 SEBASTIAN TRUEG AND THE K3B TEAM -publisher -preparer -sysid LINUX -volset-size 1 -volset-seqno 1 -sort /tmp/kde-harosso/k3boj1uob.tmp -rational-rock -hide-list /tmp/kde-harosso/k3bsNQQza.tmp -joliet -hide-joliet-list /tmp/kde-harosso/k3b5qEqna.tmp -full-iso9660-filenames -iso-level 2 -path-list /tmp/kde-harosso/k3bNJlGTa.tmp
Une erreur de permission peut être je sais pas !!
J’ai tester de m’ajouter au groupe cdrom mais j’y suis déjà :
#adduser neness cdrom
L'utilisateur « neness » est déjà membre du groupe « cdrom ».
merci de votre aide !
