Je viens d’installer une squeeze avec xfce et je rencontre un problème : je n’arrive pas à monter de disque ou de clé usb…
J’ai essayé avec un disque dur usb formaté en ntfs et avec une clé usb formatée en fat, à chaque fois j’ai cette erreur :
Impossible de monter "cle_usb".
mount: wrong fs type, bad option, bad superblock on /dev/sdb1,
missing codepage or helper program, or other error
In some cases useful info is found in syslog - try
dmesg | tail or so.
j’ai fait un dmesg | tail qui donne ceci :
[18680.422198] scsi 10:0:0:0: Direct-Access I-Stick2 IntelligentStick 2.00 PQ: 0 ANSI: 2
[18681.560472] ready
[18681.561016] sd 10:0:0:0: [sdb] 511488 512-byte logical blocks: (261 MB/249 MiB)
[18681.561681] sd 10:0:0:0: [sdb] Write Protect is off
[18681.561690] sd 10:0:0:0: [sdb] Mode Sense: 03 00 00 00
[18681.561695] sd 10:0:0:0: [sdb] Assuming drive cache: write through
[18681.566420] sd 10:0:0:0: [sdb] Assuming drive cache: write through
[18681.566429] sdb: sdb1
[18681.570420] sd 10:0:0:0: [sdb] Assuming drive cache: write through
[18681.570429] sd 10:0:0:0: [sdb] Attached SCSI removable disk
Et dans syslog :
Jul 10 11:15:48 dotmu-fr20 kernel: [19382.580134] usb 2-2: new high speed USB device using ehci_hcd and address 8
Jul 10 11:15:48 dotmu-fr20 kernel: [19382.717527] usb 2-2: New USB device found, idVendor=0ea0, idProduct=2168
Jul 10 11:15:48 dotmu-fr20 kernel: [19382.717536] usb 2-2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
Jul 10 11:15:48 dotmu-fr20 kernel: [19382.717543] usb 2-2: Product: Flash Disk
Jul 10 11:15:48 dotmu-fr20 kernel: [19382.717547] usb 2-2: Manufacturer: USB
Jul 10 11:15:48 dotmu-fr20 kernel: [19382.717552] usb 2-2: SerialNumber: 106C114198D5BACE
Jul 10 11:15:48 dotmu-fr20 kernel: [19382.717741] usb 2-2: configuration #1 chosen from 1 choice
Jul 10 11:15:48 dotmu-fr20 kernel: [19382.720658] scsi11 : SCSI emulation for USB Mass Storage devices
Jul 10 11:15:48 dotmu-fr20 kernel: [19382.736663] usb-storage: device found at 8
Jul 10 11:15:48 dotmu-fr20 kernel: [19382.736666] usb-storage: waiting for device to settle before scanning
Jul 10 11:15:49 dotmu-fr20 kernel: [19384.293745] usb 2-2: USB disconnect, address 8
Jul 10 11:15:50 dotmu-fr20 kernel: [19384.564134] usb 2-2: new high speed USB device using ehci_hcd and address 9
Jul 10 11:15:50 dotmu-fr20 kernel: [19384.701348] usb 2-2: New USB device found, idVendor=0ea0, idProduct=2168
Jul 10 11:15:50 dotmu-fr20 kernel: [19384.701356] usb 2-2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
Jul 10 11:15:50 dotmu-fr20 kernel: [19384.701363] usb 2-2: Product: Flash Disk
Jul 10 11:15:50 dotmu-fr20 kernel: [19384.701368] usb 2-2: Manufacturer: USB
Jul 10 11:15:50 dotmu-fr20 kernel: [19384.701372] usb 2-2: SerialNumber: 106C114198D5BACE
Jul 10 11:15:50 dotmu-fr20 kernel: [19384.701578] usb 2-2: configuration #1 chosen from 1 choice
Jul 10 11:15:50 dotmu-fr20 kernel: [19384.708833] scsi12 : SCSI emulation for USB Mass Storage devices
Jul 10 11:15:50 dotmu-fr20 kernel: [19384.719962] usb-storage: device found at 9
Jul 10 11:15:50 dotmu-fr20 kernel: [19384.719966] usb-storage: waiting for device to settle before scanning
Jul 10 11:15:55 dotmu-fr20 kernel: [19389.716827] usb-storage: device scan complete
Jul 10 11:15:55 dotmu-fr20 kernel: [19389.718537] scsi 12:0:0:0: Direct-Access I-Stick2 IntelligentStick 2.00 PQ: 0 ANSI: 2
Jul 10 11:15:56 dotmu-fr20 kernel: [19390.784292] ready
Jul 10 11:15:56 dotmu-fr20 kernel: [19390.784953] sd 12:0:0:0: [sdb] 511488 512-byte logical blocks: (261 MB/249 MiB)
Jul 10 11:15:56 dotmu-fr20 kernel: [19390.785783] sd 12:0:0:0: [sdb] Write Protect is off
Jul 10 11:15:56 dotmu-fr20 kernel: [19390.785792] sd 12:0:0:0: [sdb] Mode Sense: 03 00 00 00
Jul 10 11:15:56 dotmu-fr20 kernel: [19390.785798] sd 12:0:0:0: [sdb] Assuming drive cache: write through
Jul 10 11:15:56 dotmu-fr20 kernel: [19390.793574] sd 12:0:0:0: [sdb] Assuming drive cache: write through
Jul 10 11:15:56 dotmu-fr20 kernel: [19390.793584] sdb: sdb1
Jul 10 11:15:56 dotmu-fr20 kernel: [19390.798266] sd 12:0:0:0: [sdb] Assuming drive cache: write through
Jul 10 11:15:56 dotmu-fr20 kernel: [19390.798276] sd 12:0:0:0: [sdb] Attached SCSI removable disk
Jul 10 11:15:56 dotmu-fr20 kernel: [19391.191756] UDF-fs: No anchor found
Jul 10 11:15:56 dotmu-fr20 kernel: [19391.191761] UDF-fs: Rescanning with blocksize 2048
Jul 10 11:15:56 dotmu-fr20 kernel: [19391.212519] UDF-fs: No anchor found
Jul 10 11:15:56 dotmu-fr20 kernel: [19391.212526] UDF-fs: No partition found (1)
Jul 10 11:15:56 dotmu-fr20 kernel: [19391.260890] ISOFS: Unable to identify CD-ROM format.
Jul 10 11:15:57 dotmu-fr20 dhclient: DHCPREQUEST on eth0 to 192.168.1.1 port 67
Les deux périphériques fonctionnent sur d’autres systèmes.
J’avais déjà rencontré (il y a quelques années) des problèmes pour monter un stockage usb sur xfce, mais je pensais que c’était réglé depuis bien longtemps !
Avez-vous une idée ?
ps : mon matériel est un ultra-portable packard-bell dot/mu fr020 (sans lecteur cd, en version 32bit).
