Voici le retour :
kresta@Serveur:~/ts$ ./teamspeak2-server_startscript start
starting the teamspeak2 server
./teamspeak2-server_startscript: line 7: 7349 Erreur de segmentation ./server_ linux -PID=tsserver2.pid
kresta@Serveur:~/ts$ strace -ff ./teamspeak2-server_startscript
execve("./teamspeak2-server_startscript", ["./teamspeak2-server_startscript"], [ /* 19 vars */]) = 0
uname({sys="Linux", node="Serveur", ...}) = 0
brk(0) = 0x80f3000
access("/etc/ld.so.nohwcap", F_OK) = -1 ENOENT (No such file or directory)
mmap2(NULL, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0xb7 f65000
access("/etc/ld.so.preload", R_OK) = -1 ENOENT (No such file or directory)
open("/etc/ld.so.cache", O_RDONLY) = 3
fstat64(3, {st_mode=S_IFREG|0644, st_size=52177, ...}) = 0
mmap2(NULL, 52177, PROT_READ, MAP_PRIVATE, 3, 0) = 0xb7f58000
close(3) = 0
open("/lib/libncurses.so.5", O_RDONLY) = 3
read(3, "\177ELF\1\1\1\0\0\0\0\0\0\0\0\0\3\0\3\0\1\0\0\0\200\345"..., 512) = 512
fstat64(3, {st_mode=S_IFREG|0644, st_size=263040, ...}) = 0
mmap2(NULL, 264196, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0xb7 f17000
mmap2(0xb7f4f000, 32768, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRI TE, 3, 0x38) = 0xb7f4f000
mmap2(0xb7f57000, 2052, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_ANONYMOU S, -1, 0) = 0xb7f57000
close(3) = 0
open("/lib/tls/i686/cmov/libdl.so.2", O_RDONLY) = 3
read(3, "\177ELF\1\1\1\0\0\0\0\0\0\0\0\0\3\0\3\0\1\0\0\0\20\f\0"..., 512) = 512
fstat64(3, {st_mode=S_IFREG|0644, st_size=9592, ...}) = 0
mmap2(NULL, 12404, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0xb7f 13000
mmap2(0xb7f15000, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRIT E, 3, 0x1) = 0xb7f15000
close(3) = 0
open("/lib/tls/i686/cmov/libc.so.6", O_RDONLY) = 3
read(3, "\177ELF\1\1\1\0\0\0\0\0\0\0\0\0\3\0\3\0\1\0\0\0\240O\1"..., 512) = 512
fstat64(3, {st_mode=S_IFREG|0644, st_size=1241392, ...}) = 0
mmap2(NULL, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0xb7 f12000
mmap2(NULL, 1247388, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0xb 7de1000
mmap2(0xb7f08000, 28672, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRI TE, 3, 0x127) = 0xb7f08000
mmap2(0xb7f0f000, 10396, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_ANONYMO US, -1, 0) = 0xb7f0f000
close(3) = 0
mmap2(NULL, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0xb7 de0000
mprotect(0xb7f08000, 20480, PROT_READ) = 0
set_thread_area({entry_number:-1 -> 6, base_addr:0xb7de06c0, limit:1048575, seg_ 32bit:1, contents:0, read_exec_only:0, limit_in_pages:1, seg_not_present:0, usea ble:1}) = 0
munmap(0xb7f58000, 52177) = 0
rt_sigprocmask(SIG_BLOCK, NULL, [], 8) = 0
open("/dev/tty", O_RDWR|O_NONBLOCK|O_LARGEFILE) = 3
close(3) = 0
brk(0) = 0x80f3000
brk(0x80f4000) = 0x80f4000
open("/usr/lib/locale/locale-archive", O_RDONLY|O_LARGEFILE) = 3
fstat64(3, {st_mode=S_IFREG|0644, st_size=1209056, ...}) = 0
mmap2(NULL, 1209056, PROT_READ, MAP_PRIVATE, 3, 0) = 0xb7cb8000
close(3) = 0
brk(0x80f5000) = 0x80f5000
brk(0x80f6000) = 0x80f6000
getuid32() = 1000
getgid32() = 1000
geteuid32() = 1000
getegid32() = 1000
time(NULL) = 1215073562
brk(0x80f7000) = 0x80f7000
open("/etc/mtab", O_RDONLY) = 3
fstat64(3, {st_mode=S_IFREG|0644, st_size=349, ...}) = 0
mmap2(NULL, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0xb7 f64000
read(3, "/dev/hda1 / ext3 rw,errors=remou"..., 4096) = 349
close(3) = 0
munmap(0xb7f64000, 4096) = 0
open("/proc/meminfo", O_RDONLY) = 3
fstat64(3, {st_mode=S_IFREG|0444, st_size=0, ...}) = 0
read(3, "MemTotal: 2067388 kB\nMemFre"..., 1024) = 676
close(3) = 0
brk(0x80f8000) = 0x80f8000
rt_sigaction(SIGCHLD, {SIG_DFL}, {SIG_DFL}, 8) = 0
rt_sigaction(SIGINT, {SIG_DFL}, {SIG_DFL}, 8) = 0
rt_sigaction(SIGQUIT, {SIG_DFL}, {SIG_DFL}, 8) = 0
rt_sigaction(SIGQUIT, {SIG_IGN}, {SIG_DFL}, 8) = 0
brk(0x80f9000) = 0x80f9000
stat64("/home/kresta/ts", {st_mode=S_IFDIR|0755, st_size=4096, ...}) = 0
stat64(".", {st_mode=S_IFDIR|0755, st_size=4096, ...}) = 0
getpid() = 7355
open("/usr/lib/gconv/gconv-modules.cache", O_RDONLY) = 3
fstat64(3, {st_mode=S_IFREG|0644, st_size=21568, ...}) = 0
mmap2(NULL, 21568, PROT_READ, MAP_SHARED, 3, 0) = 0xb7f5f000
close(3) = 0
getppid() = 7354
getpgrp() = 7354
rt_sigaction(SIGCHLD, {0x807acd0, [], 0}, {SIG_DFL}, 8) = 0
open("./teamspeak2-server_startscript", O_RDONLY|O_LARGEFILE) = 3
ioctl(3, SNDCTL_TMR_TIMEBASE or TCGETS, 0xbfa47978) = -1 ENOTTY (Inappropriate i octl for device)
_llseek(3, 0, [0], SEEK_CUR) = 0
read(3, "#! /bin/bash\n# Copyright (c) 200"..., 80) = 80
_llseek(3, 0, [0], SEEK_SET) = 0
getrlimit(RLIMIT_NOFILE, {rlim_cur=1024, rlim_max=1024}) = 0
dup2(3, 255) = 255
close(3) = 0
fcntl64(255, F_SETFD, FD_CLOEXEC) = 0
fcntl64(255, F_GETFL) = 0x8000 (flags O_RDONLY|O_LARGEFILE)
fstat64(255, {st_mode=S_IFREG|0744, st_size=2465, ...}) = 0
_llseek(255, 0, [0], SEEK_CUR) = 0
brk(0x80fa000) = 0x80fa000
brk(0x80fb000) = 0x80fb000
read(255, "#! /bin/bash\n# Copyright (c) 200"..., 2465) = 2465
brk(0x80fc000) = 0x80fc000
brk(0x80fd000) = 0x80fd000
brk(0x80fe000) = 0x80fe000
brk(0x80ff000) = 0x80ff000
brk(0x8100000) = 0x8100000
brk(0x8101000) = 0x8101000
write(1, "Usage: ./teamspeak2-server_start"..., 77Usage: ./teamspeak2-server_sta rtscript {start|stop|restart|status|passwords}
) = 77
rt_sigprocmask(SIG_SETMASK, [], NULL, 8) = 0
exit_group(2) = ?
Process 7355 detached
Vous en pensez quoi ?
