pour evolution c’est bon mais toujours des problème avec JDownloader, après mise à jour il semble y avoir un problème avec libc6…
[code]sebastien@sebastien-desktop:~$ ~/bin/JDownloader/jd.sh
JD Installation found: Starting JD now
------------------------ Thread: 10 -----------------------
10 06/06/10 19:10:29 - INFO [jd.Main(main)] -> Start JDownloader
JAR
10 06/06/10 19:10:29 - FINEST [jd.utils.JDUtilities(getJDClassLoader)] -> Create Classloader: for: /home/sebastien/.jd
10 06/06/10 19:10:29 - FINEST [jd.JDClassLoader()] -> rootDir:/home/sebastien/.jd
/home/sebastien/.jd
file:/home/sebastien/.jd/jd
10 06/06/10 19:10:29 - FINER [jd.JDClassLoader()] -> Jar file loaded: /home/sebastien/.jd/plugins/JDExternInterface.jar
10 06/06/10 19:10:29 - FINER [jd.JDClassLoader()] -> Jar file loaded: /home/sebastien/.jd/plugins/JDWebinterface.jar
10 06/06/10 19:10:29 - FINER [jd.JDClassLoader()] -> Jar file loaded: /home/sebastien/.jd/plugins/JDLangFileEditor.jar
10 06/06/10 19:10:29 - FINER [jd.JDClassLoader()] -> Jar file loaded: /home/sebastien/.jd/plugins/JDHTTPLiveHeaderScripter.jar
10 06/06/10 19:10:29 - FINER [jd.JDClassLoader()] -> Jar file loaded: /home/sebastien/.jd/plugins/JDInfoFileWriter.jar
10 06/06/10 19:10:29 - FINER [jd.JDClassLoader()] -> Jar file loaded: /home/sebastien/.jd/plugins/JDChat.jar
10 06/06/10 19:10:29 - FINER [jd.JDClassLoader()] -> Jar file loaded: /home/sebastien/.jd/plugins/JDGrowl.jar
10 06/06/10 19:10:29 - FINER [jd.JDClassLoader()] -> Jar file loaded: /home/sebastien/.jd/plugins/JDFolderWatch.jar
10 06/06/10 19:10:29 - FINER [jd.JDClassLoader()] -> Jar file loaded: /home/sebastien/.jd/plugins/JDUnrar.jar
10 06/06/10 19:10:29 - FINER [jd.JDClassLoader()] -> Jar file loaded: /home/sebastien/.jd/plugins/JDRemoteControl.jar
10 06/06/10 19:10:29 - FINER [jd.JDClassLoader()] -> Jar file loaded: /home/sebastien/.jd/plugins/schedule.jar
10 06/06/10 19:10:29 - FINER [jd.JDClassLoader()] -> Jar file loaded: /home/sebastien/.jd/plugins/JDShutdown.jar
10 06/06/10 19:10:29 - FINER [jd.JDClassLoader()] -> Jar file loaded: /home/sebastien/.jd/plugins/JDTray.jar
10 06/06/10 19:10:29 - FINER [jd.JDClassLoader()] -> Jar file loaded: /home/sebastien/.jd/plugins/JDHJMerge.jar
10 06/06/10 19:10:29 - FINER [jd.JDClassLoader()] -> Jar file loaded: /home/sebastien/.jd/plugins/JDPackageCustomizer.jar
10 06/06/10 19:10:29 - FINER [jd.JDClassLoader()] -> Jar file loaded: /home/sebastien/.jd/JDownloader.jar
10 06/06/10 19:10:29 - FINER [jd.JDClassLoader()] -> Look and Feel JAR loaded: /home/sebastien/.jd/libs/laf/syntheticaOrangeMetallic.jar
10 06/06/10 19:10:29 - FINER [jd.JDClassLoader()] -> Look and Feel JAR loaded: /home/sebastien/.jd/libs/laf/substance-swingx.jar
10 06/06/10 19:10:29 - FINER [jd.JDClassLoader()] -> Look and Feel JAR loaded: /home/sebastien/.jd/libs/laf/synthetica.jar
10 06/06/10 19:10:29 - FINER [jd.JDClassLoader()] -> Look and Feel JAR loaded: /home/sebastien/.jd/libs/laf/syntheticaSilverMoon.jar
10 06/06/10 19:10:29 - FINER [jd.JDClassLoader()] -> Look and Feel JAR loaded: /home/sebastien/.jd/libs/laf/syntheticaBlackStar.jar
10 06/06/10 19:10:29 - FINER [jd.JDClassLoader()] -> Look and Feel JAR loaded: /home/sebastien/.jd/libs/laf/syntheticaWhiteVision.jar
10 06/06/10 19:10:29 - FINER [jd.JDClassLoader()] -> Look and Feel JAR loaded: /home/sebastien/.jd/libs/laf/syntheticaBlueMoon.jar
10 06/06/10 19:10:29 - FINER [jd.JDClassLoader()] -> Look and Feel JAR loaded: /home/sebastien/.jd/libs/laf/syntheticaBlackEye.jar
10 06/06/10 19:10:29 - FINER [jd.JDClassLoader()] -> Look and Feel JAR loaded: /home/sebastien/.jd/libs/laf/syntheticaBlueIce.jar
10 06/06/10 19:10:29 - FINER [jd.JDClassLoader()] -> Look and Feel JAR loaded: /home/sebastien/.jd/libs/laf/syntheticaMauveMetallic.jar
10 06/06/10 19:10:29 - FINER [jd.JDClassLoader()] -> Look and Feel JAR loaded: /home/sebastien/.jd/libs/laf/syntheticaSkyMetallic.jar
10 06/06/10 19:10:29 - FINER [jd.JDClassLoader()] -> Look and Feel JAR loaded: /home/sebastien/.jd/libs/laf/syntheticaBatik.jar
10 06/06/10 19:10:29 - FINER [jd.JDClassLoader()] -> Look and Feel JAR loaded: /home/sebastien/.jd/libs/laf/syntheticaGreenDream.jar
10 06/06/10 19:10:29 - FINER [jd.JDClassLoader()] -> Look and Feel JAR loaded: /home/sebastien/.jd/libs/laf/syntheticaBlackMoon.jar
10 06/06/10 19:10:29 - FINER [jd.JDClassLoader()] -> Look and Feel JAR loaded: /home/sebastien/.jd/libs/laf/syntheticaBlueSteel.jar
10 06/06/10 19:10:29 - FINER [jd.JDClassLoader()] -> Look and Feel JAR loaded: /home/sebastien/.jd/libs/laf/syntheticaSimple2D.jar
10 06/06/10 19:10:29 - FINER [jd.JDClassLoader()] -> Look and Feel JAR loaded: /home/sebastien/.jd/libs/laf/substance.jar
A fatal error has been detected by the Java Runtime Environment:
SIGSEGV (0xb) at pc=0xb76b7c1c, pid=18762, tid=3064585104
JRE version: 6.0_20-b02
Java VM: Java HotSpot™ Server VM (16.3-b01 mixed mode linux-x86 )
Problematic frame:
C [libc.so.6+0x77c1c] memcpy+0x1c
An error report file with more information is saved as:
/home/sebastien/.jd/hs_err_pid18762.log
If you would like to submit a bug report, please visit:
The crash happened outside the Java Virtual Machine in native code.
See problematic frame for where to report the bug.
/home/sebastien/bin/JDownloader/jd.sh: line 70: 18762 Abandon java -Xmx512m -jar JDownloader.jar
et le fichier log “/home/sebastien/.jd/hs_err_pid18762.log” :
[code]#
Problematic frame:
--------------- T H R E A D ---------------
Current thread (0x08059000): JavaThread “main” [_thread_in_native, id=18763, stack(0xb6a4d000,0xb6a9e000)]
siginfo:si_signo=SIGSEGV: si_errno=0, si_code=2 (SEGV_ACCERR), si_addr=0xb6a1f000
Registers:
EAX=0x8ee08001, EBX=0xb7796ff4, ECX=0x0000031a, EDX=0x00000fff
ESP=0xb6a1cb08, EBP=0xb6a1cb2c, ESI=0x8ee08398, EDI=0xb6a1f000
EIP=0xb76b7c1c, CR2=0xb6a1f000, EFLAGS=0x00210207
Top of Stack: (sp=0xb6a1cb08)
0xb6a1cb08: b769fc6c b6a1ec69 8ee08001 00000fff
0xb6a1cb18: b6a1ec69 00000000 b7796ff4 b6a1cc68
0xb6a1cb28: fbad2488 b6a1cb50 b769fbe1 8f57e660
0xb6a1cb38: b6a1cc68 0003dfe6 0000000a 00000001
0xb6a1cb48: 00000000 b7796ff4 b6a1cb7c b76a8c93
0xb6a1cb58: 8f57e660 b6a1cc68 0003ffe7 0000000a
0xb6a1cb68: 00000001 00000000 b69d5ff4 b6a5cc4f
0xb6a1cb78: b6a1cc68 b6a1cc1c b69ce977 b6a1cc68
Instructions: (pc=0xb76b7c1c)
0xb76b7c0c: 8b 74 24 08 fc d1 e9 73 01 a4 d1 e9 73 02 66 a5
0xb76b7c1c: f3 a5 89 c7 89 d6 8b 44 24 04 c3 90 90 90 90 90
Stack: [0xb6a4d000,0xb6a9e000], sp=0xb6a1cb08, free space=ffffff3eb6a1c4a0k
Native frames: (J=compiled Java code, j=interpreted, Vv=VM code, C=native code)
C [libc.so.6+0x5fbe1] _IO_getline+0x41
C [libc.so.6+0x68c93] fgets_unlocked+0x63
C [libnss_files.so.2+0x3977] _nss_files_gethostbyname2_r+0xf7
Java frames: (J=compiled Java code, j=interpreted, Vv=VM code)
j java.net.Inet6AddressImpl.lookupAllHostAddr(Ljava/lang/String;)[Ljava/net/InetAddress;+0
j java.net.InetAddress$1.lookupAllHostAddr(Ljava/lang/String;)[Ljava/net/InetAddress;+4
j java.net.InetAddress.getAddressFromNameService(Ljava/lang/String;Ljava/net/InetAddress;)Ljava/lang/Object;+17
j java.net.InetAddress.getLocalHost()Ljava/net/InetAddress;+43
j it.sauronsoftware.junique.Server.start()V+57
j it.sauronsoftware.junique.JUnique.acquireLock(Ljava/lang/String;Lit/sauronsoftware/junique/MessageHandler;)V+121
j jd.Main.main([Ljava/lang/String;)V+810
v ~StubRoutines::call_stub
--------------- P R O C E S S ---------------
Java Threads: ( => current thread )
0x08066c00 JavaThread “Low Memory Detector” daemon [_thread_blocked, id=18772, stack(0x8ef36000,0x8ef87000)]
0x08065000 JavaThread “CompilerThread1” daemon [_thread_in_native, id=18771, stack(0x8ef87000,0x8f008000)]
0x8f588c00 JavaThread “CompilerThread0” daemon [_thread_in_native, id=18770, stack(0x8f008000,0x8f089000)]
0x8f587400 JavaThread “Signal Dispatcher” daemon [_thread_blocked, id=18769, stack(0x8f089000,0x8f0da000)]
0x8f576c00 JavaThread “Finalizer” daemon [_thread_blocked, id=18768, stack(0x8f214000,0x8f265000)]
0x8f575400 JavaThread “Reference Handler” daemon [_thread_blocked, id=18767, stack(0x8f265000,0x8f2b6000)]
=>0x08059000 JavaThread “main” [_thread_in_native, id=18763, stack(0xb6a4d000,0xb6a9e000)]
Other Threads:
0x8f572800 VMThread [stack: 0x8f2b6000,0x8f337000] [id=18766]
0x08068800 WatcherThread [stack: 0x8eeb5000,0x8ef36000] [id=18773]
VM state:not at safepoint (normal execution)
VM Mutex/Monitor currently owned by a thread: None
Heap
PSYoungGen total 9472K, used 4923K [0xa8e60000, 0xaa0e0000, 0xb3900000)
eden space 8128K, 44% used [0xa8e60000,0xa91e2358,0xa9650000)
from space 1344K, 99% used [0xa9650000,0xa979cbc0,0xa97a0000)
to space 1344K, 0% used [0xa9f90000,0xa9f90000,0xaa0e0000)
PSOldGen total 21632K, used 64K [0x93900000, 0x94e20000, 0xa8e60000)
object space 21632K, 0% used [0x93900000,0x93910000,0x94e20000)
PSPermGen total 16384K, used 4325K [0x8f900000, 0x90900000, 0x93900000)
object space 16384K, 26% used [0x8f900000,0x8fd395a0,0x90900000)
Dynamic libraries:
08048000-08052000 r-xp 00000000 08:03 214740 /usr/lib/jvm/java-6-sun-1.6.0.20/jre/bin/java
08052000-08053000 rwxp 00009000 08:03 214740 /usr/lib/jvm/java-6-sun-1.6.0.20/jre/bin/java
08053000-086a0000 rwxp 08053000 00:00 0 [heap]
8e900000-8e932000 rwxp 8e900000 00:00 0
8e932000-8ea00000 —p 8e932000 00:00 0
8eaec000-8eaff000 r-xp 00000000 08:03 411885 /usr/lib/jvm/java-6-sun-1.6.0.20/jre/lib/i386/libnet.so
8eaff000-8eb00000 rwxp 00013000 08:03 411885 /usr/lib/jvm/java-6-sun-1.6.0.20/jre/lib/i386/libnet.so
8eb00000-8ebfa000 rwxp 8eb00000 00:00 0
8ebfa000-8ec00000 —p 8ebfa000 00:00 0
8ec00000-8ecfc000 rwxp 8ec00000 00:00 0
8ecfc000-8ed00000 —p 8ecfc000 00:00 0
8ed00000-8edf9000 rwxp 8ed00000 00:00 0
8edf9000-8ee00000 —p 8edf9000 00:00 0
8ee08000-8ee09000 rwxp 8ee08000 00:00 0
8ee09000-8ee10000 r-xp 00000000 08:03 412631 /usr/lib/jvm/java-6-sun-1.6.0.20/jre/lib/i386/libnio.so
8ee10000-8ee11000 rwxp 00006000 08:03 412631 /usr/lib/jvm/java-6-sun-1.6.0.20/jre/lib/i386/libnio.so
8ee11000-8ee30000 r-xs 00184000 08:03 1064519 /home/sebastien/.jd/libs/laf/substance.jar
8ee30000-8ee33000 r-xs 0001b000 08:03 1064504 /home/sebastien/.jd/libs/laf/syntheticaSimple2D.jar
8ee33000-8ee38000 r-xs 00025000 08:03 1064512 /home/sebastien/.jd/libs/laf/syntheticaBlueSteel.jar
8ee38000-8ee3e000 r-xs 00029000 08:03 1064501 /home/sebastien/.jd/libs/laf/syntheticaBlackMoon.jar
8ee3e000-8ee42000 r-xs 00014000 08:03 1064509 /home/sebastien/.jd/libs/laf/syntheticaGreenDream.jar
8ee42000-8ee44000 r-xs 00004000 08:03 1064506 /home/sebastien/.jd/libs/laf/syntheticaBatik.jar
8ee44000-8ee4c000 r-xs 0003e000 08:03 1064516 /home/sebastien/.jd/libs/laf/syntheticaSkyMetallic.jar
8ee4c000-8ee54000 r-xs 00043000 08:03 1064517 /home/sebastien/.jd/libs/laf/syntheticaMauveMetallic.jar
8ee54000-8ee59000 r-xs 0001b000 08:03 1064513 /home/sebastien/.jd/libs/laf/syntheticaBlueIce.jar
8ee59000-8ee62000 r-xs 00035000 08:03 1064503 /home/sebastien/.jd/libs/laf/syntheticaBlackEye.jar
8ee62000-8ee68000 r-xs 0002c000 08:03 1064514 /home/sebastien/.jd/libs/laf/syntheticaBlueMoon.jar
8ee68000-8ee72000 r-xs 00035000 08:03 1064518 /home/sebastien/.jd/libs/laf/syntheticaWhiteVision.jar
8ee72000-8ee77000 r-xs 00017000 08:03 1064508 /home/sebastien/.jd/libs/laf/syntheticaBlackStar.jar
8ee77000-8ee7c000 r-xs 00018000 08:03 1064511 /home/sebastien/.jd/libs/laf/syntheticaSilverMoon.jar
8ee7c000-8ee89000 r-xs 00077000 08:03 1064515 /home/sebastien/.jd/libs/laf/synthetica.jar
8ee89000-8ee8b000 r-xs 0000f000 08:03 1064507 /home/sebastien/.jd/libs/laf/substance-swingx.jar
8ee8b000-8ee94000 r-xs 0003e000 08:03 1064510 /home/sebastien/.jd/libs/laf/syntheticaOrangeMetallic.jar
8ee94000-8ee96000 r-xs 00007000 08:03 1064444 /home/sebastien/.jd/plugins/JDHJMerge.jar
8ee96000-8ee97000 r-xs 00008000 08:03 1064488 /home/sebastien/.jd/plugins/JDTray.jar
8ee97000-8ee98000 r-xs 00002000 08:03 1064489 /home/sebastien/.jd/plugins/JDShutdown.jar
8ee98000-8ee99000 r-xs 00003000 08:03 1064486 /home/sebastien/.jd/plugins/JDRemoteControl.jar
8ee99000-8ee9a000 r-xs 0000b000 08:03 1064450 /home/sebastien/.jd/plugins/JDUnrar.jar
8ee9a000-8ee9b000 r-xs 00001000 08:03 1064441 /home/sebastien/.jd/plugins/JDFolderWatch.jar
8ee9b000-8ee9d000 r-xs 00000000 08:03 1064487 /home/sebastien/.jd/plugins/JDGrowl.jar
8ee9d000-8ee9e000 r-xs 0000b000 08:03 1064491 /home/sebastien/.jd/plugins/JDChat.jar
8ee9e000-8eea1000 r-xs 00025000 08:03 1064522 /home/sebastien/.jd/libs/JDUtils.jar
8eea1000-8eea7000 r-xs 00067000 08:03 1064528 /home/sebastien/.jd/libs/JAntiCaptcha.jar
8eea7000-8eeb5000 r-xs 000a9000 08:03 1064495 /home/sebastien/.jd/libs/JDGUI.jar
8eeb5000-8eeb6000 —p 8eeb5000 00:00 0
8eeb6000-8ef36000 rwxp 8eeb6000 00:00 0
8ef36000-8ef39000 —p 8ef36000 00:00 0
8ef39000-8ef87000 rwxp 8ef39000 00:00 0
8ef87000-8ef8a000 —p 8ef87000 00:00 0
8ef8a000-8f008000 rwxp 8ef8a000 00:00 0
8f008000-8f00b000 —p 8f008000 00:00 0
8f00b000-8f089000 rwxp 8f00b000 00:00 0
8f089000-8f08c000 —p 8f089000 00:00 0
8f08c000-8f0da000 rwxp 8f08c000 00:00 0
8f0da000-8f214000 r-xp 00000000 08:03 368791 /usr/lib/locale/locale-archive
8f214000-8f217000 —p 8f214000 00:00 0
8f217000-8f265000 rwxp 8f217000 00:00 0
8f265000-8f268000 —p 8f265000 00:00 0
8f268000-8f2b6000 rwxp 8f268000 00:00 0
8f2b6000-8f2b7000 —p 8f2b6000 00:00 0
8f2b7000-8f36a000 rwxp 8f2b7000 00:00 0
8f36a000-8f500000 r-xs 02fd0000 08:03 752790 /usr/lib/jvm/java-6-sun-1.6.0.20/jre/lib/rt.jar
8f500000-8f5fa000 rwxp 8f500000 00:00 0
8f5fa000-8f600000 —p 8f5fa000 00:00 0
8f600000-8f601000 r-xs 00001000 08:03 1064484 /home/sebastien/.jd/plugins/JDInfoFileWriter.jar
8f601000-8f603000 r-xs 00002000 08:03 1064445 /home/sebastien/.jd/plugins/JDHTTPLiveHeaderScripter.jar
8f603000-8f605000 r-xs 0000c000 08:03 1064490 /home/sebastien/.jd/plugins/JDLangFileEditor.jar
8f605000-8f607000 r-xs 00015000 08:03 1064534 /home/sebastien/.jd/libs/JDHttp.jar
8f607000-8f60a000 r-xs 000cf000 08:03 1064521 /home/sebastien/.jd/libs/jna.jar
8f60a000-8f612000 r-xs 0008a000 08:03 1038702 /home/sebastien/.jd/JDownloader.jar
8f612000-8f613000 —p 8f612000 00:00 0
8f613000-8f693000 rwxp 8f613000 00:00 0
8f693000-8f694000 —p 8f693000 00:00 0
8f694000-8f71c000 rwxp 8f694000 00:00 0
8f71c000-8f734000 rwxp 8f71c000 00:00 0
8f734000-8f73f000 rwxp 8f734000 00:00 0
8f73f000-8f7df000 rwxp 8f73f000 00:00 0
8f7df000-8f7e7000 rwxp 8f7df000 00:00 0
8f7e7000-8f7ff000 rwxp 8f7e7000 00:00 0
8f7ff000-8f80a000 rwxp 8f7ff000 00:00 0
8f80a000-8f8a9000 rwxp 8f80a000 00:00 0
8f8a9000-8f8b3000 rwxp 8f8a9000 00:00 0
8f8b3000-8f8ff000 rwxp 8f8b3000 00:00 0
8f8ff000-90900000 rwxp 8f8ff000 00:00 0
90900000-93900000 rwxp 90900000 00:00 0
93900000-94e20000 rwxp 93900000 00:00 0
94e20000-a8e60000 rwxp 94e20000 00:00 0
a8e60000-aa0e0000 rwxp a8e60000 00:00 0
aa0e0000-b3900000 rwxp aa0e0000 00:00 0
b3900000-b3901000 r-xs 00003000 08:03 1064499 /home/sebastien/.jd/libs/JUnique.jar
b3901000-b3903000 r-xs 0000a000 08:03 1064485 /home/sebastien/.jd/plugins/schedule.jar
b3903000-b390b000 r-xs 0008a000 08:03 1038702 /home/sebastien/.jd/JDownloader.jar
b390b000-b3914000 rwxp b390b000 00:00 0
b3914000-b39cb000 rwxp b3914000 00:00 0
b39cb000-b3c0b000 rwxp b39cb000 00:00 0
b3c0b000-b69cb000 rwxp b3c0b000 00:00 0
b69cb000-b69d5000 r-xp 00000000 08:03 997494 /lib/i686/cmov/libnss_files-2.7.so
b69d5000-b69d7000 rwxp 00009000 08:03 997494 /lib/i686/cmov/libnss_files-2.7.so
b69d7000-b69df000 r-xp 00000000 08:03 997483 /lib/i686/cmov/libnss_nis-2.7.so
b69df000-b69e1000 rwxp 00008000 08:03 997483 /lib/i686/cmov/libnss_nis-2.7.so
b69e1000-b69e8000 r-xp 00000000 08:03 997487 /lib/i686/cmov/libnss_compat-2.7.so
b69e8000-b69ea000 rwxp 00006000 08:03 997487 /lib/i686/cmov/libnss_compat-2.7.so
b69ea000-b69ff000 r-xp 00000000 08:03 997484 /lib/i686/cmov/libnsl-2.7.so
b69ff000-b6a01000 rwxp 00014000 08:03 997484 /lib/i686/cmov/libnsl-2.7.so
b6a01000-b6a03000 rwxp b6a01000 00:00 0
b6a03000-b6a04000 r-xs 0000d000 08:03 1064493 /home/sebastien/.jd/plugins/JDWebinterface.jar
b6a04000-b6a06000 r-xs 00006000 08:03 1064492 /home/sebastien/.jd/plugins/JDPackageCustomizer.jar
b6a06000-b6a15000 r-xp 00000000 08:03 412606 /usr/lib/jvm/java-6-sun-1.6.0.20/jre/lib/i386/libzip.so
b6a15000-b6a17000 rwxp 0000e000 08:03 412606 /usr/lib/jvm/java-6-sun-1.6.0.20/jre/lib/i386/libzip.so
b6a17000-b6a1f000 rwxs 00000000 08:03 179927 /tmp/hsperfdata_sebastien/18762
b6a1f000-b6a42000 r-xp 00000000 08:03 409746 /usr/lib/jvm/java-6-sun-1.6.0.20/jre/lib/i386/libjava.so
b6a42000-b6a44000 rwxp 00023000 08:03 409746 /usr/lib/jvm/java-6-sun-1.6.0.20/jre/lib/i386/libjava.so
b6a44000-b6a4b000 r-xp 00000000 08:03 997492 /lib/i686/cmov/librt-2.7.so
b6a4b000-b6a4d000 rwxp 00006000 08:03 997492 /lib/i686/cmov/librt-2.7.so
b6a4d000-b6a50000 —p b6a4d000 00:00 0
b6a50000-b6a9e000 rwxp b6a50000 00:00 0
b6a9e000-b6ac2000 r-xp 00000000 08:03 997474 /lib/i686/cmov/libm-2.7.so
b6ac2000-b6ac4000 rwxp 00023000 08:03 997474 /lib/i686/cmov/libm-2.7.so
b6ac4000-b71d0000 r-xp 00000000 08:03 370496 /usr/lib/jvm/java-6-sun-1.6.0.20/jre/lib/i386/server/libjvm.so
b71d0000-b7221000 rwxp 0070b000 08:03 370496 /usr/lib/jvm/java-6-sun-1.6.0.20/jre/lib/i386/server/libjvm.so
b7221000-b7640000 rwxp b7221000 00:00 0
b7640000-b7795000 r-xp 00000000 08:03 997489 /lib/i686/cmov/libc-2.7.so
b7795000-b7796000 r-xp 00155000 08:03 997489 /lib/i686/cmov/libc-2.7.so
b7796000-b7798000 rwxp 00156000 08:03 997489 /lib/i686/cmov/libc-2.7.so
b7798000-b779b000 rwxp b7798000 00:00 0
b779b000-b779d000 r-xp 00000000 08:03 997486 /lib/i686/cmov/libdl-2.7.so
b779d000-b779f000 rwxp 00001000 08:03 997486 /lib/i686/cmov/libdl-2.7.so
b779f000-b77a6000 r-xp 00000000 08:03 728076 /usr/lib/jvm/java-6-sun-1.6.0.20/jre/lib/i386/jli/libjli.so
b77a6000-b77a8000 rwxp 00006000 08:03 728076 /usr/lib/jvm/java-6-sun-1.6.0.20/jre/lib/i386/jli/libjli.so
b77a8000-b77a9000 rwxp b77a8000 00:00 0
b77a9000-b77be000 r-xp 00000000 08:03 997482 /lib/i686/cmov/libpthread-2.7.so
b77be000-b77c0000 rwxp 00014000 08:03 997482 /lib/i686/cmov/libpthread-2.7.so
b77c0000-b77c2000 rwxp b77c0000 00:00 0
b77c2000-b77c3000 r-xs 00005000 08:03 1064443 /home/sebastien/.jd/plugins/JDExternInterface.jar
b77c3000-b77c9000 r-xs 0004d000 08:03 1064530 /home/sebastien/.jd/libs/Filters.jar
b77c9000-b77cf000 r-xp 00000000 08:03 809572 /usr/lib/jvm/java-6-sun-1.6.0.20/jre/lib/i386/native_threads/libhpi.so
b77cf000-b77d0000 rwxp 00006000 08:03 809572 /usr/lib/jvm/java-6-sun-1.6.0.20/jre/lib/i386/native_threads/libhpi.so
b77d0000-b77d1000 rwxp b77d0000 00:00 0
b77d1000-b77d2000 r-xp b77d1000 00:00 0
b77d2000-b77dd000 r-xp 00000000 08:03 412633 /usr/lib/jvm/java-6-sun-1.6.0.20/jre/lib/i386/libverify.so
b77dd000-b77de000 rwxp 0000b000 08:03 412633 /usr/lib/jvm/java-6-sun-1.6.0.20/jre/lib/i386/libverify.so
b77de000-b77e0000 rwxp b77de000 00:00 0
b77e0000-b77e1000 r-xp b77e0000 00:00 0 [vdso]
b77e1000-b77fb000 r-xp 00000000 08:03 956718 /lib/ld-2.7.so
b77fb000-b77fd000 rwxp 0001a000 08:03 956718 /lib/ld-2.7.so
bffea000-bffff000 rwxp bffeb000 00:00 0 [stack]
VM Arguments:
jvm_args: -Xmx512m
java_command: JDownloader.jar
Launcher Type: SUN_STANDARD
Environment Variables:
PATH=/home/sebastien/bin:/usr/local/bin:/usr/bin:/bin:/usr/games
USERNAME=sebastien
LD_LIBRARY_PATH=/usr/lib/jvm/java-6-sun-1.6.0.20/jre/lib/i386/server:/usr/lib/jvm/java-6-sun-1.6.0.20/jre/lib/i386:/usr/lib/jvm/java-6-sun-1.6.0.20/jre/…/lib/i386
SHELL=/bin/bash
DISPLAY=:0.0
Signal Handlers:
SIGSEGV: [libjvm.so+0x68d5c0], sa_mask[0]=0x7ffbfeff, sa_flags=0x10000004
SIGBUS: [libjvm.so+0x68d5c0], sa_mask[0]=0x7ffbfeff, sa_flags=0x10000004
SIGFPE: [libjvm.so+0x55cb30], sa_mask[0]=0x7ffbfeff, sa_flags=0x10000004
SIGPIPE: [libjvm.so+0x55cb30], sa_mask[0]=0x7ffbfeff, sa_flags=0x10000004
SIGXFSZ: [libjvm.so+0x55cb30], sa_mask[0]=0x7ffbfeff, sa_flags=0x10000004
SIGILL: [libjvm.so+0x55cb30], sa_mask[0]=0x7ffbfeff, sa_flags=0x10000004
SIGUSR1: SIG_DFL, sa_mask[0]=0x00000000, sa_flags=0x00000000
SIGUSR2: [libjvm.so+0x55f770], sa_mask[0]=0x00000000, sa_flags=0x10000004
SIGHUP: [libjvm.so+0x55f4a0], sa_mask[0]=0x7ffbfeff, sa_flags=0x10000004
SIGINT: [libjvm.so+0x55f4a0], sa_mask[0]=0x7ffbfeff, sa_flags=0x10000004
SIGTERM: [libjvm.so+0x55f4a0], sa_mask[0]=0x7ffbfeff, sa_flags=0x10000004
SIGQUIT: [libjvm.so+0x55f4a0], sa_mask[0]=0x7ffbfeff, sa_flags=0x10000004
--------------- S Y S T E M ---------------
OS:5.0.4
uname:Linux 2.6.26-2-686 #1 SMP Wed May 12 21:56:10 UTC 2010 i686
libc:glibc 2.7 NPTL 2.7
rlimit: STACK 8192k, CORE 0k, NPROC 16380, NOFILE 1024, AS infinity
load average:0.19 0.23 0.25
CPU:total 2 (2 cores per cpu, 1 threads per core) family 6 model 15 stepping 13, cmov, cx8, fxsr, mmx, sse, sse2, sse3, ssse3
Memory: 4k page, physical 2075856k(132804k free), swap 1951888k(1951088k free)
vm_info: Java HotSpot™ Server VM (16.3-b01) for linux-x86 JRE (1.6.0_20-b02), built on Apr 12 2010 13:58:11 by “java_re” with gcc 3.2.1-7a (J2SE release)
time: Sun Jun 6 19:10:29 2010
elapsed time: 0 seconds
