J’ai un serveur web ssh etc sous jessie
Au début mes virtualhost etaient sous http et mon fail2ban fonctionnait sans soucis
Mais par la suite je suis passé en https et depuis j’ai ce message d’erreur chaque mois
[quote]/etc/cron.daily/logrotate:
ERROR Unable to contact server. Is it running?
error: error running non-shared postrotate script for /var/log/fail2ban.log of '/var/log/fail2ban.log '
run-parts: /etc/cron.daily/logrotate exited with return code 1[/quote]
je joint mon jail.conf
[code]# Fail2Ban configuration file.
This file was composed for Debian systems from the original one
provided now under /usr/share/doc/fail2ban/examples/jail.conf
for additional examples.
Comments: use ‘#’ for comment lines and ‘;’ for inline comments
To avoid merges during upgrades DO NOT MODIFY THIS FILE
and rather provide your changes in /etc/fail2ban/jail.local
The DEFAULT allows a global definition of the options. They can be overridden
in each jail afterwards.
[DEFAULT]
“ignoreip” can be an IP address, a CIDR mask or a DNS host. Fail2ban will not
ban a host which matches an address in this list. Several addresses can be
defined using space separator.
ignoreip = 127.0.0.1/8
External command that will take an tagged arguments to ignore, e.g. ,
and return true if the IP is to be ignored. False otherwise.
ignorecommand = /path/to/command
ignorecommand =
“bantime” is the number of seconds that a host is banned.
bantime = 600
A host is banned if it has generated “maxretry” during the last “findtime”
seconds.
findtime = 600
maxretry = 3
“backend” specifies the backend used to get files modification.
Available options are “pyinotify”, “gamin”, “polling” and “auto”.
This option can be overridden in each jail as well.
pyinotify: requires pyinotify (a file alteration monitor) to be installed.
If pyinotify is not installed, Fail2ban will use auto.
gamin: requires Gamin (a file alteration monitor) to be installed.
If Gamin is not installed, Fail2ban will use auto.
polling: uses a polling algorithm which does not require external libraries.
i# auto: will try to use the following backends, in order:
pyinotify, gamin, polling.
backend = auto
“usedns” specifies if jails should trust hostnames in logs,
warn when reverse DNS lookups are performed, or ignore all hostnames in logs
yes: if a hostname is encountered, a reverse DNS lookup will be performed.
warn: if a hostname is encountered, a reverse DNS lookup will be performed,
but it will be logged as a warning.
no: if a hostname is encountered, will not be used for banning,
but it will be logged as info.
usedns = warn
Destination email address used solely for the interpolations in
jail.{conf,local} configuration files.
destemail = root@localhost
Name of the sender for mta actions
sendername = Fail2Ban
Email address of the sender
sender = fail2ban@localhost
ACTIONS
Default banning action (e.g. iptables, iptables-new,
iptables-multiport, shorewall, etc) It is used to define
action_* variables. Can be overridden globally or per
section within jail.local file
banaction = iptables-multiport
email action. Since 0.8.1 upstream fail2ban uses sendmail
MTA for the mailing. Change mta configuration parameter to mail
if you want to revert to conventional ‘mail’.
mta = sendmail
Default protocol
protocol = tcp
Specify chain where jumps would need to be added in iptables-* actions
chain = INPUT
Action shortcuts. To be used to define action parameter
The simplest action to take: ban only
action_ = %(banaction)s[name=%(name)s, port="%(port)s", protocol="%(protocol)s", chain="%(chain)s"]
ban & send an e-mail with whois report to the destemail.
action_mw = %(banaction)s[name=%(name)s, port="%(port)s", protocol="%(protocol)s", chain="%(chain)s"]
%(mta)s-whois[name=%(name)s, dest="%(destemail)s", protocol="%(protocol)s", chain="%(chain)s", sendername="%(sendername)s"]
ban & send an e-mail with whois report and relevant log lines
to the destemail.
action_mwl = %(banaction)s[name=%(name)s, port="%(port)s", protocol="%(protocol)s", chain="%(chain)s"]
%(mta)s-whois-lines[name=%(name)s, dest="%(destemail)s", logpath=%(logpath)s, chain="%(chain)s", sendername="%(sendername)s"]
Choose default action. To change, just override value of ‘action’ with the
interpolation to the chosen action shortcut (e.g. action_mw, action_mwl, etc) in jail.local
globally (section [DEFAULT]) or per specific section
action = %(action_mwl)s
JAILS
Next jails corresponds to the standard configuration in Fail2ban 0.6 which
was shipped in Debian. Enable any defined here jail by including
[SECTION_NAME]
enabled = true
in /etc/fail2ban/jail.local.
Optionally you may override any other parameter (e.g. banaction,
action, port, logpath, etc) in that section within jail.local
[ssh]
enabled = true
port = 1334
filter = sshd
logpath = /var/log/auth.log
maxretry = 6
[dropbear]
enabled = false
port = ssh
filter = dropbear
maxretry = 6
Generic filter for pam. Has to be used with action which bans all ports
such as iptables-allports, shorewall
[pam-generic]
enabled = false
pam-generic filter can be customized to monitor specific subset of 'tty’s
filter = pam-generic
port actually must be irrelevant but lets leave it all for some possible uses
port = all
banaction = iptables-allports
port = anyport
maxretry = 6
[xinetd-fail]
enabled = false
filter = xinetd-fail
port = all
banaction = iptables-multiport-log
logpath = /var/log/daemon.log
maxretry = 2
[ssh-ddos]
enabled = true
port = 1334
filter = sshd-ddos
maxretry = 6
Here we use blackhole routes for not requiring any additional kernel support
to store large volumes of banned IPs
[ssh-route]
enabled = true
filter = sshd
action = route
logpath = /var/log/sshd.log
maxretry = 6
Here we use a combination of Netfilter/Iptables and IPsets
for storing large volumes of banned IPs
IPset comes in two versions. See ipset -V for which one to use
requires the ipset package and kernel support.
[ssh-iptables-ipset4]
enabled = true
port = ssh
filter = sshd
banaction = iptables-ipset-proto4
maxretry = 6
[ssh-iptables-ipset6]
enabled = true
port = ssh
filter = sshd
banaction = iptables-ipset-proto6
maxretry = 6
HTTP servers
[apache]
enabled = true
port = http,https
filter = apache-auth
logpath = /var/log/apache*/*error.log
maxretry = 6
default action is now multiport, so apache-multiport jail was left
for compatibility with previous (<0.7.6-2) releases
[apache-multiport]
enabled = true
port = http,https
maxretry = 6
[apache-noscript]
enabled = true
port = http,https
filter = apache-noscript
maxretry = 6
[apache-overflows]
enabled = true
port = http,https
filter = apache-overflows
maxretry = 2
[apache-modsecurity]
enabled = true
filter = apache-modsecurity
port = http,https
maxretry = 2
[apache-nohome]
enabled = true
filter = apache-nohome
port = http,https
maxretry = 2
Ban attackers that try to use PHP’s URL-fopen() functionality
through GET/POST variables. - Experimental, with more than a year
of usage in production environments.
[php-url-fopen]
enabled = false
port = http,https
filter = php-url-fopen
logpath = /var/www/*/logs/access_log
A simple PHP-fastcgi jail which works with lighttpd.
If you run a lighttpd server, then you probably will
find these kinds of messages in your error_log:
ALERT – tried to register forbidden variable ‘GLOBALS’
through GET variables (attacker ‘1.2.3.4’, file ‘/var/www/default/htdocs/index.php’)
[lighttpd-fastcgi]
enabled = false
port = http,https
filter = lighttpd-fastcgi
logpath = /var/log/lighttpd/error.log
Same as above for mod_auth
It catches wrong authentifications
[lighttpd-auth]
enabled = false
port = http,https
filter = suhosin
[nginx-http-auth]
enabled = false
filter = nginx-http-auth
port = http,https
logpath = /var/log/nginx/error.log
Monitor roundcube server
[roundcube-auth]
enabled = false
filter = roundcube-auth
port = http,https
logpath = /var/log/roundcube/userlogins
[sogo-auth]
enabled = false
filter = sogo-auth
port = http, https
without proxy this would be:
port = 20000
logpath = /var/log/sogo/sogo.log
FTP servers
[vsftpd]
enabled = false
port = ftp,ftp-data,ftps,ftps-data
filter = vsftpd
logpath = /var/log/vsftpd.log
or overwrite it in jails.local to be
if you want to rely on PAM failed login attempts
vsftpd’s failregex should match both of those formats
maxretry = 6
[proftpd]
enabled = true
filter = proftpd
logpath = /var/log/proftpd/proftpd.log
maxretry = 6
[pure-ftpd]
enabled = false
filter = pure-ftpd
logpath = /var/log/syslog
maxretry = 6
[wuftpd]
enabled = false
filter = wuftpd
maxretry = 6
Mail servers
[postfix]
enabled = true
port = smtp,ssmtp,submission
filter = postfix
logpath = /var/log/mail.log
[couriersmtp]
enabled = true
filter = couriersmtp
Mail servers authenticators: might be used for smtp,ftp,imap servers, so
all relevant ports get banned
[courierauth]
enabled = false
port = smtp,ssmtp,submission,imap2,imap3,imaps,pop3,pop3s
filter = courierlogin
[sasl]
enabled = true
filter = postfix-sasl
You might consider monitoring /var/log/mail.warn instead if you are
running postfix since it would provide the same log lines at the
“warn” level but overall at the smaller filesize.
[dovecot]
enabled = false
filter = dovecot
To log wrong MySQL access attempts add to /etc/my.cnf:
log-error=/var/log/mysqld.log
log-warning = 2
[mysqld-auth]
enabled = false
filter = mysqld-auth
port = 3306
logpath = /var/log/mysqld.log
DNS Servers
These jails block attacks against named (bind9). By default, logging is off
with bind9 installation. You will need something like this:
logging {
channel security_file {
file “/var/log/named/security.log” versions 3 size 30m;
severity dynamic;
print-time yes;
category security {
security_file;
in your named.conf to provide proper logging
!!! WARNING !!!
Since UDP is connection-less protocol, spoofing of IP and imitation
of illegal actions is way too simple. Thus enabling of this filter
might provide an easy way for implementing a DoS against a chosen
victim. See
http://nion.modprobe.de/blog/archives/690-fail2ban-+-dns-fail.html
Please DO NOT USE this jail unless you know what you are doing.
#[named-refused-udp]
#enabled = false
#port = domain,953
#protocol = udp
#filter = named-refused
#logpath = /var/log/named/security.log
[named-refused-tcp]
enabled = false
port = domain,953
protocol = tcp
[freeswitch]
enabled = false
filter = freeswitch
logpath = /var/log/freeswitch.log
maxretry = 10
action = iptables-multiport[name=freeswitch-tcp, port=“5060,5061,5080,5081”, protocol=tcp]
iptables-multiport[name=freeswitch-udp, port=“5060,5061,5080,5081”, protocol=udp]
[ejabberd-auth]
enabled = false
filter = ejabberd-auth
port = xmpp-client
protocol = tcp
logpath = /var/log/ejabberd/ejabberd.log
Multiple jails, 1 per protocol, are necessary ATM:
see https://github.com/fail2ban/fail2ban/issues/37
[asterisk-tcp]
enabled = false
filter = asterisk
port = 5060,5061
protocol = tcp
logpath = /var/log/asterisk/messages
[asterisk-udp]
enabled = false
filter = asterisk
port = 5060,5061
protocol = udp
Jail for more extended banning of persistent abusers
!!! WARNING !!!
Make sure that your loglevel specified in fail2ban.conf/.local
is not at DEBUG level – which might then cause fail2ban to fall into
an infinite loop constantly feeding itself with non-informative lines
[recidive]
enabled = false
filter = recidive
logpath = /var/log/fail2ban.log
action = iptables-allports[name=recidive]
sendmail-whois-lines[name=recidive, logpath=/var/log/fail2ban.log]
bantime = 604800 ; 1 week
findtime = 86400 ; 1 day
maxretry = 5
See the IMPORTANT note in action.d/blocklist_de.conf for when to
use this action
Report block via blocklist.de fail2ban reporting service API
See action.d/blocklist_de.conf for more information
[ssh-blocklist]
enabled = true
filter = sshd
action = iptables[name=SSH, port=ssh, protocol=tcp]
sendmail-whois[name=SSH, dest="%(destemail)s", sender="%(sender)s", sendername="%(sendername)s"]
blocklist_de[email="%(sender)s", apikey=“xxxxxx”, service="%(filter)s"]
maxretry = 20
consider low maxretry and a long bantime
nobody except your own Nagios server should ever probe nrpe
[nagios]
enabled = false
filter = nagios
action = iptables[name=Nagios, port=5666, protocol=tcp]
sendmail-whois[name=Nagios, dest="%(destemail)s", sender="%(sender)s", sendername="%(sendername)s"]
logpath = /var/log/messages ; nrpe.cfg may define a different log_facility
maxretry = 1[/code]
Je ne comprend pas bien l’anglais, donc si quelqu’un a une idée je le remercie d’avance
