Bonsoir, j’ai démarré mon serveur Garry’s mod avec une map(rp_rockford_v1b) assez lourde et la!
J’ai installé “tmux gdb mailutils postfix ca-certificates lib32gcc1”
[code]Engine hunk overflow!
Segmentation fault (core dumped)
warning: not using untrusted file “/home/serveurgmod/.gdbinit”
warning: Can’t read pathname for load map: Input/output error.
warning: the debug information found in “bin/libm-2.15.so” does not match “bin/libm.so.6” (CRC mismatch).
warning: the debug information found in “bin/libdl-2.15.so” does not match “bin/libdl.so.2” (CRC mismatch).
warning: the debug information found in “bin/libpthread-2.15.so” does not match “bin/libpthread.so.0” (CRC mismatch).
warning: Expected absolute pathname for libpthread in the inferior, but got bin/libpthread.so.0.
warning: Unable to find libthread_db matching inferior’s thread library, thread debugging will not be available.
warning: the debug information found in “bin/libc-2.15.so” does not match “bin/libc.so.6” (CRC mismatch).
warning: the debug information found in “bin/librt-2.15.so” does not match “bin/librt.so.1” (CRC mismatch).
warning: the debug information found in “bin/libnss_files-2.15.so” does not match “bin/libnss_files.so.2” (CRC mismatch).
warning: the debug information found in “bin/libnss_dns-2.15.so” does not match “bin/libnss_dns.so.2” (CRC mismatch).
warning: the debug information found in “bin/libresolv-2.15.so” does not match “bin/libresolv.so.2” (CRC mismatch).
La Version de débian: debian-7.0-x86_64
Le Noyau utilisé: Linux vps21499 2.6.32-openvz-042stab106.6-amd64 #1 SMP Mon Apr 20 14:57:06 MSK 2015 x86_64 GNU/Linux
Spécifité: AMD 64
Pouvez-vous m’aidez ?
