bonsoir,
mauvais présage pour un 31 decembre, après un redémarrage kdm me signale une erreur et ne reconnait plus mon login, j’ai récuperé les logs avec knoppix, c’est un peu long dsl:
Note that your system uses syslog. All of kdm’s internally generated messages
(i.e., not from libraries and external programs/scripts it uses) go to the
daemon.* syslog facility; check your syslog configuration to find out to which
file(s) it is logged. PAM logs messages related to authentication to authpriv.*.
XFree86 Version 4.3.0.1 (Debian 4.3.0.dfsg.1-14sarge1 20050901212727 fjp@localhost.localdomain)
Release Date: 15 August 2003
X Protocol Version 11, Revision 0, Release 6.6
Build Operating System: Linux 2.6.8-16.0508-2 i686 [ELF]
Build Date: 02 September 2005
This version of XFree86 has been extensively modified by the Debian
Project, and is not supported by the XFree86 Project, Inc., in any
way. Bugs should be reported to the Debian Bug Tracking System; see
<URL: debian.org/Bugs/Reporting >.
We strongly encourage the use of the “reportbug” package and command
to ensure that bug reports contain as much useful information as
possible.
Before filing a bug report, you may want to consult the Debian X FAQ:
XHTML version: file:///usr/share/doc/xfree86-common/FAQ.xhtml
plain text version: file:///usr/share/doc/xfree86-common/FAQ.gz
Module Loader present
OS Kernel: Linux version 2.6.8-2-k7 (horms@tabatha.lab.ultramonkey.org) (gcc version 3.3.5 (Debian 1:3.3.5-12)) #1 Thu May 19 18:03:29 JST 2005
Markers: (–) probed, (**) from config file, (==) default setting,
(==) Log file: “/var/log/XFree86.0.log”, Time: Sat Dec 3 11:02:29 2005
(==) Using config file: "/etc/X11/XF86Config-4"
Skipping “/usr/X11R6/lib/modules/extensions/libGLcore.a:m_debug_clip.o”: No symbols found
Skipping “/usr/X11R6/lib/modules/extensions/libGLcore.a:m_debug_norm.o”: No symbols found
Skipping “/usr/X11R6/lib/modules/extensions/libGLcore.a:m_debug_xform.o”: No symbols found
Skipping “/usr/X11R6/lib/modules/extensions/libGLcore.a:m_debug_vertex.o”: No symbols found
Skipping “/usr/X11R6/lib/modules/fonts/libspeedo.a:spencode.o”: No symbols found
The XKEYBOARD keymap compiler (xkbcomp) reports:
Warning: Type “ONE_LEVEL” has 1 levels, but has 2 symbols
Ignoring extra symbols
Errors from xkbcomp are not fatal to the X server
Warning: font renderer for “.pcf” already registered at priority 0
Warning: font renderer for “.pcf.Z” already registered at priority 0
Warning: font renderer for “.pcf.gz” already registered at priority 0
Warning: font renderer for “.snf” already registered at priority 0
Warning: font renderer for “.snf.Z” already registered at priority 0
Warning: font renderer for “.snf.gz” already registered at priority 0
Warning: font renderer for “.bdf” already registered at priority 0
Warning: font renderer for “.bdf.Z” already registered at priority 0
Warning: font renderer for “.bdf.gz” already registered at priority 0
Warning: font renderer for “.pmf” already registered at priority 0
Could not init font path element unix/:7100, removing from list!
QImage::convertDepth: Image is a null image
QImage::smoothScale: Image is a null image
SetClientVersion: 0 9
possible.
(==) Log file: “/var/log/XFree86.0.log”, Time: Sat Dec 3 11:04:59 2005
possible.
(==) Log file: “/var/log/XFree86.0.log”, Time: Sat Dec 3 19:28:24 2005
possible.
(==) Log file: “/var/log/XFree86.0.log”, Time: Sun Dec 4 00:11:40 2005
possible.
(==) Log file: “/var/log/XFree86.0.log”, Time: Sun Dec 4 10:18:01 2005
possible.
(==) Log file: “/var/log/XFree86.0.log”, Time: Sun Dec 4 23:40:25 2005
possible.
(==) Log file: “/var/log/XFree86.0.log”, Time: Mon Dec 5 08:36:56 2005
possible.
(==) Log file: “/var/log/XFree86.0.log”, Time: Mon Dec 5 12:07:53 2005
possible.
(==) Log file: “/var/log/XFree86.0.log”, Time: Tue Dec 6 08:47:55 2005
possible.
(==) Log file: “/var/log/XFree86.0.log”, Time: Wed Dec 7 10:17:29 2005
possible.
(==) Log file: “/var/log/XFree86.0.log”, Time: Thu Dec 8 15:36:26 2005
possible.
(==) Log file: “/var/log/XFree86.0.log”, Time: Fri Dec 9 08:34:19 2005
possible.
(==) Log file: “/var/log/XFree86.0.log”, Time: Fri Dec 9 16:50:39 2005
possible.
(==) Log file: “/var/log/XFree86.0.log”, Time: Fri Dec 9 16:55:57 2005
possible.
(==) Log file: “/var/log/XFree86.0.log”, Time: Fri Dec 9 19:07:44 2005
possible.
(==) Log file: “/var/log/XFree86.0.log”, Time: Fri Dec 9 19:27:00 2005
possible.
(==) Log file: “/var/log/XFree86.0.log”, Time: Sat Dec 10 09:50:58 2005
possible.
(==) Log file: “/var/log/XFree86.0.log”, Time: Sat Dec 10 16:59:04 2005
possible.
(==) Log file: “/var/log/XFree86.0.log”, Time: Sat Dec 10 18:22:13 2005
possible.
(==) Log file: “/var/log/XFree86.0.log”, Time: Sat Dec 10 22:04:59 2005
possible.
(==) Log file: “/var/log/XFree86.0.log”, Time: Sat Dec 10 23:24:48 2005
Warning: font rend
