j’avais bien penser
attention c’est long est surtout je n’ai pas le debut du message je suis limiter dans le retour en arrier dans le shell!
[code]kernel:[131142.708983] Call Trace:
Message from syslogd@server at May 2 00:49:01 …
kernel:[131142.709013] Code: fa 66 0f 1f 44 00 00 65 8b 04 25 a8 e3 00 00 48 98 49 8b 94 c4 f0 02 00 00 8b 4a 18 89 4c 24 14 48 8b 1a 48 85 db 74 0c 8b 42 14 <48> 8b 04 c3 48 89 02 eb 19 48 8b 4c 24 08 49 89 d0 44 89 ee 83
Message from syslogd@server at May 2 01:07:01 …
kernel:[132222.665058] general protection fault: 0000 [#73] SMP
kernel:[132222.665063] last sysfs file: /sys/devices/pci0000:00/0000:00:1f.2/host3/target3:0:0/3:0:0:0/block/sdb/uevent
kernel:[132222.665170] Stack:
kernel:[132222.665185] Call Trace:
kernel:[132222.665215] Code: fa 66 0f 1f 44 00 00 65 8b 04 25 a8 e3 00 00 48 98 49 8b 94 c4 f0 02 00 00 8b 4a 18 89 4c 24 14 48 8b 1a 48 85 db 74 0c 8b 42 14 <48> 8b 04 c3 48 89 02 eb 19 48 8b 4c 24 08 49 89 d0 44 89 ee 83
Message from syslogd@server at May 2 01:08:01 …
kernel:[132282.665536] general protection fault: 0000 [#74] SMP
kernel:[132282.665541] last sysfs file: /sys/devices/pci0000:00/0000:00:1f.2/host3/target3:0:0/3:0:0:0/block/sdb/uevent
kernel:[132282.665649] Stack:
kernel:[132282.665663] Call Trace:
kernel:[132282.665693] Code: fa 66 0f 1f 44 00 00 65 8b 04 25 a8 e3 00 00 48 98 49 8b 94 c4 f0 02 00 00 8b 4a 18 89 4c 24 14 48 8b 1a 48 85 db 74 0c 8b 42 14 <48> 8b 04 c3 48 89 02 eb 19 48 8b 4c 24 08 49 89 d0 44 89 ee 83
Message from syslogd@server at May 2 01:16:01 …
kernel:[132762.699583] general protection fault: 0000 [#75] SMP
kernel:[132762.699589] last sysfs file: /sys/devices/pci0000:00/0000:00:1f.2/host3/target3:0:0/3:0:0:0/block/sdb/uevent
kernel:[132762.699698] Stack:
kernel:[132762.699713] Call Trace:
kernel:[132762.699745] Code: fa 66 0f 1f 44 00 00 65 8b 04 25 a8 e3 00 00 48 98 49 8b 94 c4 f0 02 00 00 8b 4a 18 89 4c 24 14 48 8b 1a 48 85 db 74 0c 8b 42 14 <48> 8b 04 c3 48 89 02 eb 19 48 8b 4c 24 08 49 89 d0 44 89 ee 83
Message from syslogd@server at May 2 01:43:01 …
kernel:[134382.745743] general protection fault: 0000 [#76] SMP
kernel:[134382.745748] last sysfs file: /sys/devices/pci0000:00/0000:00:1f.2/host3/target3:0:0/3:0:0:0/block/sdb/uevent
kernel:[134382.745858] Stack:
kernel:[134382.745873] Call Trace:
kernel:[134382.745903] Code: fa 66 0f 1f 44 00 00 65 8b 04 25 a8 e3 00 00 48 98 49 8b 94 c4 f0 02 00 00 8b 4a 18 89 4c 24 14 48 8b 1a 48 85 db 74 0c 8b 42 14 <48> 8b 04 c3 48 89 02 eb 19 48 8b 4c 24 08 49 89 d0 44 89 ee 83
Message from syslogd@server at May 2 01:50:01 …
kernel:[134802.753497] general protection fault: 0000 [#77] SMP
kernel:[134802.753503] last sysfs file: /sys/devices/pci0000:00/0000:00:1f.2/host3/target3:0:0/3:0:0:0/block/sdb/uevent
kernel:[134802.753612] Stack:
kernel:[134802.753627] Call Trace:
kernel:[134802.753657] Code: fa 66 0f 1f 44 00 00 65 8b 04 25 a8 e3 00 00 48 98 49 8b 94 c4 f0 02 00 00 8b 4a 18 89 4c 24 14 48 8b 1a 48 85 db 74 0c 8b 42 14 <48> 8b 04 c3 48 89 02 eb 19 48 8b 4c 24 08 49 89 d0 44 89 ee 83
Message from syslogd@server at May 2 01:51:01 …
kernel:[134862.753950] general protection fault: 0000 [#78] SMP
kernel:[134862.753956] last sysfs file: /sys/devices/pci0000:00/0000:00:1f.2/host3/target3:0:0/3:0:0:0/block/sdb/uevent
kernel:[134862.754064] Stack:
kernel:[134862.754078] Call Trace:
kernel:[134862.754108] Code: fa 66 0f 1f 44 00 00 65 8b 04 25 a8 e3 00 00 48 98 49 8b 94 c4 f0 02 00 00 8b 4a 18 89 4c 24 14 48 8b 1a 48 85 db 74 0c 8b 42 14 <48> 8b 04 c3 48 89 02 eb 19 48 8b 4c 24 08 49 89 d0 44 89 ee 83
Message from syslogd@server at May 2 02:50:01 …
kernel:[138402.858709] general protection fault: 0000 [#79] SMP
kernel:[138402.858715] last sysfs file: /sys/devices/pci0000:00/0000:00:1f.2/host3/target3:0:0/3:0:0:0/block/sdb/uevent
kernel:[138402.858827] Stack:
kernel:[138402.858842] Call Trace:
kernel:[138402.858874] Code: fa 66 0f 1f 44 00 00 65 8b 04 25 a8 e3 00 00 48 98 49 8b 94 c4 f0 02 00 00 8b 4a 18 89 4c 24 14 48 8b 1a 48 85 db 74 0c 8b 42 14 <48> 8b 04 c3 48 89 02 eb 19 48 8b 4c 24 08 49 89 d0 44 89 ee 83
Message from syslogd@server at May 2 03:03:01 …
kernel:[139182.864909] general protection fault: 0000 [#80] SMP
kernel:[139182.864914] last sysfs file: /sys/devices/pci0000:00/0000:00:1f.2/host3/target3:0:0/3:0:0:0/block/sdb/uevent
kernel:[139182.865022] Stack:
kernel:[139182.865036] Call Trace:
kernel:[139182.865066] Code: fa 66 0f 1f 44 00 00 65 8b 04 25 a8 e3 00 00 48 98 49 8b 94 c4 f0 02 00 00 8b 4a 18 89 4c 24 14 48 8b 1a 48 85 db 74 0c 8b 42 14 <48> 8b 04 c3 48 89 02 eb 19 48 8b 4c 24 08 49 89 d0 44 89 ee 83
Message from syslogd@server at May 2 03:26:01 …
kernel:[140562.919304] general protection fault: 0000 [#81] SMP
kernel:[140562.919310] last sysfs file: /sys/devices/pci0000:00/0000:00:1f.2/host3/target3:0:0/3:0:0:0/block/sdb/uevent
kernel:[140562.919420] Stack:
kernel:[140562.919434] Call Trace:
kernel:[140562.919465] Code: fa 66 0f 1f 44 00 00 65 8b 04 25 a8 e3 00 00 48 98 49 8b 94 c4 f0 02 00 00 8b 4a 18 89 4c 24 14 48 8b 1a 48 85 db 74 0c 8b 42 14 <48> 8b 04 c3 48 89 02 eb 19 48 8b 4c 24 08 49 89 d0 44 89 ee 83
Message from syslogd@server at May 2 03:45:01 …
kernel:[141702.954109] general protection fault: 0000 [#82] SMP
kernel:[141702.954115] last sysfs file: /sys/devices/pci0000:00/0000:00:1f.2/host3/target3:0:0/3:0:0:0/block/sdb/uevent
kernel:[141702.954223] Stack:
kernel:[141702.954237] Call Trace:
kernel:[141702.954268] Code: fa 66 0f 1f 44 00 00 65 8b 04 25 a8 e3 00 00 48 98 49 8b 94 c4 f0 02 00 00 8b 4a 18 89 4c 24 14 48 8b 1a 48 85 db 74 0c 8b 42 14 <48> 8b 04 c3 48 89 02 eb 19 48 8b 4c 24 08 49 89 d0 44 89 ee 83
Message from syslogd@server at May 2 04:02:01 …
kernel:[142722.967896] general protection fault: 0000 [#83] SMP
kernel:[142722.967901] last sysfs file: /sys/devices/pci0000:00/0000:00:1f.2/host3/target3:0:0/3:0:0:0/block/sdb/uevent
kernel:[142722.968010] Stack:
kernel:[142722.968025] Call Trace:
kernel:[142722.968055] Code: fa 66 0f 1f 44 00 00 65 8b 04 25 a8 e3 00 00 48 98 49 8b 94 c4 f0 02 00 00 8b 4a 18 89 4c 24 14 48 8b 1a 48 85 db 74 0c 8b 42 14 <48> 8b 04 c3 48 89 02 eb 19 48 8b 4c 24 08 49 89 d0 44 89 ee 83
Message from syslogd@server at May 2 04:14:01 …
kernel:[143442.997710] general protection fault: 0000 [#84] SMP
kernel:[143442.997716] last sysfs file: /sys/devices/pci0000:00/0000:00:1f.2/host3/target3:0:0/3:0:0:0/block/sdb/uevent
kernel:[143442.997825] Stack:
kernel:[143442.997839] Call Trace:
kernel:[143442.997870] Code: fa 66 0f 1f 44 00 00 65 8b 04 25 a8 e3 00 00 48 98 49 8b 94 c4 f0 02 00 00 8b 4a 18 89 4c 24 14 48 8b 1a 48 85 db 74 0c 8b 42 14 <48> 8b 04 c3 48 89 02 eb 19 48 8b 4c 24 08 49 89 d0 44 89 ee 83
Message from syslogd@server at May 2 04:36:01 …
kernel:[144763.015878] general protection fault: 0000 [#85] SMP
kernel:[144763.015884] last sysfs file: /sys/devices/pci0000:00/0000:00:1f.2/host3/target3:0:0/3:0:0:0/block/sdb/uevent
kernel:[144763.015991] Stack:
kernel:[144763.016005] Call Trace:
kernel:[144763.016034] Code: fa 66 0f 1f 44 00 00 65 8b 04 25 a8 e3 00 00 48 98 49 8b 94 c4 f0 02 00 00 8b 4a 18 89 4c 24 14 48 8b 1a 48 85 db 74 0c 8b 42 14 <48> 8b 04 c3 48 89 02 eb 19 48 8b 4c 24 08 49 89 d0 44 89 ee 83
Message from syslogd@server at May 2 05:17:01 …
kernel:[147223.140318] general protection fault: 0000 [#86] SMP
kernel:[147223.140324] last sysfs file: /sys/devices/pci0000:00/0000:00:1f.2/host3/target3:0:0/3:0:0:0/block/sdb/uevent
kernel:[147223.140434] Stack:
kernel:[147223.140448] Call Trace:
kernel:[147223.140480] Code: fa 66 0f 1f 44 00 00 65 8b 04 25 a8 e3 00 00 48 98 49 8b 94 c4 f0 02 00 00 8b 4a 18 89 4c 24 14 48 8b 1a 48 85 db 74 0c 8b 42 14 <48> 8b 04 c3 48 89 02 eb 19 48 8b 4c 24 08 49 89 d0 44 89 ee 83
Message from syslogd@server at May 2 05:19:01 …
kernel:[147343.150134] general protection fault: 0000 [#87] SMP
kernel:[147343.150140] last sysfs file: /sys/devices/pci0000:00/0000:00:1f.2/host3/target3:0:0/3:0:0:0/block/sdb/uevent
kernel:[147343.150248] Stack:
kernel:[147343.150262] Call Trace:
kernel:[147343.150293] Code: fa 66 0f 1f 44 00 00 65 8b 04 25 a8 e3 00 00 48 98 49 8b 94 c4 f0 02 00 00 8b 4a 18 89 4c 24 14 48 8b 1a 48 85 db 74 0c 8b 42 14 <48> 8b 04 c3 48 89 02 eb 19 48 8b 4c 24 08 49 89 d0 44 89 ee 83
Message from syslogd@server at May 2 05:38:01 …
kernel:[148483.157661] general protection fault: 0000 [#88] SMP
kernel:[148483.157667] last sysfs file: /sys/devices/pci0000:00/0000:00:1f.2/host3/target3:0:0/3:0:0:0/block/sdb/uevent
kernel:[148483.157776] Stack:
kernel:[148483.157791] Call Trace:
kernel:[148483.157821] Code: fa 66 0f 1f 44 00 00 65 8b 04 25 a8 e3 00 00 48 98 49 8b 94 c4 f0 02 00 00 8b 4a 18 89 4c 24 14 48 8b 1a 48 85 db 74 0c 8b 42 14 <48> 8b 04 c3 48 89 02 eb 19 48 8b 4c 24 08 49 89 d0 44 89 ee 83
Message from syslogd@server at May 2 06:17:01 …
kernel:[150823.256957] general protection fault: 0000 [#89] SMP
kernel:[150823.256962] last sysfs file: /sys/devices/pci0000:00/0000:00:1f.2/host3/target3:0:0/3:0:0:0/block/sdb/uevent
kernel:[150823.257071] Stack:
kernel:[150823.257086] Call Trace:
kernel:[150823.257116] Code: fa 66 0f 1f 44 00 00 65 8b 04 25 a8 e3 00 00 48 98 49 8b 94 c4 f0 02 00 00 8b 4a 18 89 4c 24 14 48 8b 1a 48 85 db 74 0c 8b 42 14 <48> 8b 04 c3 48 89 02 eb 19 48 8b 4c 24 08 49 89 d0 44 89 ee 83
Message from syslogd@server at May 2 06:24:01 …
kernel:[151243.281188] general protection fault: 0000 [#90] SMP
kernel:[151243.281194] last sysfs file: /sys/devices/pci0000:00/0000:00:1f.2/host3/target3:0:0/3:0:0:0/block/sdb/uevent
kernel:[151243.281302] Stack:
kernel:[151243.281316] Call Trace:
kernel:[151243.281349] Code: fa 66 0f 1f 44 00 00 65 8b 04 25 a8 e3 00 00 48 98 49 8b 94 c4 f0 02 00 00 8b 4a 18 89 4c 24 14 48 8b 1a 48 85 db 74 0c 8b 42 14 <48> 8b 04 c3 48 89 02 eb 19 48 8b 4c 24 08 49 89 d0 44 89 ee 83
Message from syslogd@server at May 2 06:55:01 …
kernel:[153103.319004] general protection fault: 0000 [#91] SMP
kernel:[153103.319010] last sysfs file: /sys/devices/pci0000:00/0000:00:1f.2/host3/target3:0:0/3:0:0:0/block/sdb/uevent
kernel:[153103.319120] Stack:
kernel:[153103.319134] Call Trace:
kernel:[153103.319166] Code: fa 66 0f 1f 44 00 00 65 8b 04 25 a8 e3 00 00 48 98 49 8b 94 c4 f0 02 00 00 8b 4a 18 89 4c 24 14 48 8b 1a 48 85 db 74 0c 8b 42 14 <48> 8b 04 c3 48 89 02 eb 19 48 8b 4c 24 08 49 89 d0 44 89 ee 83
Message from syslogd@server at May 2 07:05:01 …
kernel:[153703.324043] general protection fault: 0000 [#92] SMP
kernel:[153703.324050] last sysfs file: /sys/devices/pci0000:00/0000:00:1f.2/host3/target3:0:0/3:0:0:0/block/sdb/uevent
kernel:[153703.324165] Stack:
kernel:[153703.324180] Call Trace:
kernel:[153703.324213] Code: fa 66 0f 1f 44 00 00 65 8b 04 25 a8 e3 00 00 48 98 49 8b 94 c4 f0 02 00 00 8b 4a 18 89 4c 24 14 48 8b 1a 48 85 db 74 0c 8b 42 14 <48> 8b 04 c3 48 89 02 eb 19 48 8b 4c 24 08 49 89 d0 44 89 ee 83
Message from syslogd@server at May 2 07:35:02 …
kernel:[155503.612738] general protection fault: 0000 [#93] SMP
kernel:[155503.612744] last sysfs file: /sys/devices/pci0000:00/0000:00:1f.2/host3/target3:0:0/3:0:0:0/block/sdb/uevent
kernel:[155503.612852] Stack:
kernel:[155503.612867] Call Trace:
kernel:[155503.612898] Code: fa 66 0f 1f 44 00 00 65 8b 04 25 a8 e3 00 00 48 98 49 8b 94 c4 f0 02 00 00 8b 4a 18 89 4c 24 14 48 8b 1a 48 85 db 74 0c 8b 42 14 <48> 8b 04 c3 48 89 02 eb 19 48 8b 4c 24 08 49 89 d0 44 89 ee 83
Message from syslogd@server at May 2 07:54:01 …
kernel:[156642.677873] general protection fault: 0000 [#94] SMP
kernel:[156642.677879] last sysfs file: /sys/devices/pci0000:00/0000:00:1f.2/host3/target3:0:0/3:0:0:0/block/sdb/uevent
kernel:[156642.677988] Stack:
kernel:[156642.678003] Call Trace:
kernel:[156642.678034] Code: fa 66 0f 1f 44 00 00 65 8b 04 25 a8 e3 00 00 48 98 49 8b 94 c4 f0 02 00 00 8b 4a 18 89 4c 24 14 48 8b 1a 48 85 db 74 0c 8b 42 14 <48> 8b 04 c3 48 89 02 eb 19 48 8b 4c 24 08 49 89 d0 44 89 ee 83
Message from syslogd@server at May 2 08:13:01 …
kernel:[157782.778172] general protection fault: 0000 [#95] SMP
kernel:[157782.778178] last sysfs file: /sys/devices/pci0000:00/0000:00:1f.2/host3/target3:0:0/3:0:0:0/block/sdb/uevent
kernel:[157782.778287] Stack:
kernel:[157782.778302] Call Trace:
kernel:[157782.778332] Code: fa 66 0f 1f 44 00 00 65 8b 04 25 a8 e3 00 00 48 98 49 8b 94 c4 f0 02 00 00 8b 4a 18 89 4c 24 14 48 8b 1a 48 85 db 74 0c 8b 42 14 <48> 8b 04 c3 48 89 02 eb 19 48 8b 4c 24 08 49 89 d0 44 89 ee 83
Message from syslogd@server at May 2 08:40:01 …
kernel:[159402.912001] general protection fault: 0000 [#96] SMP
kernel:[159402.912008] last sysfs file: /sys/devices/pci0000:00/0000:00:1f.2/host3/target3:0:0/3:0:0:0/block/sdb/uevent
kernel:[159402.912118] Stack:
kernel:[159402.912132] Call Trace:
kernel:[159402.912163] Code: fa 66 0f 1f 44 00 00 65 8b 04 25 a8 e3 00 00 48 98 49 8b 94 c4 f0 02 00 00 8b 4a 18 89 4c 24 14 48 8b 1a 48 85 db 74 0c 8b 42 14 <48> 8b 04 c3 48 89 02 eb 19 48 8b 4c 24 08 49 89 d0 44 89 ee 83
Message from syslogd@server at May 2 08:46:01 …
kernel:[159762.911939] general protection fault: 0000 [#97] SMP
kernel:[159762.911944] last sysfs file: /sys/devices/pci0000:00/0000:00:1f.2/host3/target3:0:0/3:0:0:0/block/sdb/uevent
kernel:[159762.912053] Stack:
kernel:[159762.912068] Call Trace:
kernel:[159762.912099] Code: fa 66 0f 1f 44 00 00 65 8b 04 25 a8 e3 00 00 48 98 49 8b 94 c4 f0 02 00 00 8b 4a 18 89 4c 24 14 48 8b 1a 48 85 db 74 0c 8b 42 14 <48> 8b 04 c3 48 89 02 eb 19 48 8b 4c 24 08 49 89 d0 44 89 ee 83
Message from syslogd@server at May 2 08:55:01 …
kernel:[160302.915438] general protection fault: 0000 [#98] SMP
kernel:[160302.915444] last sysfs file: /sys/devices/pci0000:00/0000:00:1f.2/host3/target3:0:0/3:0:0:0/block/sdb/uevent
kernel:[160302.915554] Stack:
kernel:[160302.915568] Call Trace:
kernel:[160302.915599] Code: fa 66 0f 1f 44 00 00 65 8b 04 25 a8 e3 00 00 48 98 49 8b 94 c4 f0 02 00 00 8b 4a 18 89 4c 24 14 48 8b 1a 48 85 db 74 0c 8b 42 14 <48> 8b 04 c3 48 89 02 eb 19 48 8b 4c 24 08 49 89 d0 44 89 ee 83
Message from syslogd@server at May 2 09:04:01 …
kernel:[160842.919049] general protection fault: 0000 [#99] SMP
kernel:[160842.919055] last sysfs file: /sys/devices/pci0000:00/0000:00:1f.2/host3/target3:0:0/3:0:0:0/block/sdb/uevent
kernel:[160842.919163] Stack:
kernel:[160842.919177] Call Trace:
kernel:[160842.919207] Code: fa 66 0f 1f 44 00 00 65 8b 04 25 a8 e3 00 00 48 98 49 8b 94 c4 f0 02 00 00 8b 4a 18 89 4c 24 14 48 8b 1a 48 85 db 74 0c 8b 42 14 <48> 8b 04 c3 48 89 02 eb 19 48 8b 4c 24 08 49 89 d0 44 89 ee 83
^C
root@server:/home/administrateur#
Message from syslogd@server at May 2 09:22:01 …
kernel:[161923.016105] general protection fault: 0000 [#100] SMP
kernel:[161923.016111] last sysfs file: /sys/devices/pci0000:00/0000:00:1f.2/host3/target3:0:0/3:0:0:0/block/sdb/uevent
kernel:[161923.016218] Stack:
kernel:[161923.016232] Call Trace:
kernel:[161923.016262] Code: fa 66 0f 1f 44 00 00 65 8b 04 25 a8 e3 00 00 48 98 49 8b 94 c4 f0 02 00 00 8b 4a 18 89 4c 24 14 48 8b 1a 48 85 db 74 0c 8b 42 14 <48> 8b 04 c3 48 89 02 eb 19 48 8b 4c 24 08 49 89 d0 44 89 ee 83
