Je suis sous debian SID et après avoir installé tous les paquets sun-java-6, j’ai lancé un petit :
et au lancement j’ai l’image d’eclipse puis on me signale un message d’erreur dans un .log :
!SESSION 2009-11-12 18:39:43.973 -----------------------------------------------
eclipse.buildId=M20080911-1700
java.fullversion=GNU libgcj 4.3.4
BootLoader constants: OS=linux, ARCH=x86, WS=gtk, NL=fr_FR
Framework arguments:
Command-line arguments: -os linux -ws gtk -arch x86
!ENTRY org.eclipse.ui.workbench 4 0 2009-11-12 18:40:15.532
!MESSAGE Widget disposed too early!
!STACK 0
java.lang.RuntimeException: Widget disposed too early!
at org.eclipse.ui.internal.WorkbenchPartReference$1.widgetDisposed(WorkbenchPartReference.java:171)
at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListener.java:117)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java:84)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1158)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1182)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1163)
at org.eclipse.swt.widgets.Widget.release(Widget.java:1026)
at org.eclipse.swt.widgets.Control.release(Control.java:3221)
at org.eclipse.swt.widgets.Composite.releaseChildren(Composite.java:1184)
at org.eclipse.swt.widgets.Widget.release(Widget.java:1029)
at org.eclipse.swt.widgets.Canvas.releaseChildren(Canvas.java:211)
at org.eclipse.swt.widgets.Decorations.releaseChildren(Decorations.java:466)
at org.eclipse.swt.widgets.Shell.releaseChildren(Shell.java:1948)
at org.eclipse.swt.widgets.Widget.dispose(Widget.java:442)
at org.eclipse.swt.widgets.Shell.dispose(Shell.java:1893)
at org.eclipse.swt.widgets.Display.release(Display.java:3083)
at org.eclipse.swt.graphics.Device.dispose(Device.java:237)
at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:129)
at org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:193)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:110)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:79)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:386)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:179)
at java.lang.reflect.Method.invoke(libgcj.so.90)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:549)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:504)
at org.eclipse.equinox.launcher.Main.run(Main.java:1236)
at org.eclipse.equinox.launcher.Main.main(Main.java:1212)
!ENTRY org.eclipse.ui.workbench 4 0 2009-11-12 18:40:15.932
!STACK 0
!ENTRY org.eclipse.ui.workbench 4 0 2009-11-12 18:40:16.080
!STACK 0
!ENTRY org.eclipse.ui.workbench 4 0 2009-11-12 18:40:16.084
!STACK 0
!ENTRY org.eclipse.osgi 4 0 2009-11-12 18:40:16.120
!MESSAGE Application error
!STACK 1
org.eclipse.swt.SWTError: XPCOM error -2147467262
at org.eclipse.swt.browser.Mozilla.error(Mozilla.java:1638)
at org.eclipse.swt.browser.Mozilla.setText(Mozilla.java:1861)
at org.eclipse.swt.browser.Browser.setText(Browser.java:737)
at org.eclipse.ui.internal.intro.impl.presentations.BrowserIntroPartImplementation.generateContentForPage(BrowserIntroPartImplementation.java:252)
at org.eclipse.ui.internal.intro.impl.presentations.BrowserIntroPartImplementation.dynamicStandbyStateChanged(BrowserIntroPartImplementation.java:451)
at org.eclipse.ui.internal.intro.impl.presentations.BrowserIntroPartImplementation.doStandbyStateChanged(BrowserIntroPartImplementation.java:658)
at org.eclipse.ui.internal.intro.impl.model.AbstractIntroPartImplementation.standbyStateChanged(AbstractIntroPartImplementation.java:249)
at org.eclipse.ui.internal.intro.impl.model.IntroPartPresentation.standbyStateChanged(IntroPartPresentation.java:443)
at org.eclipse.ui.intro.config.CustomizableIntroPart.standbyStateChanged(CustomizableIntroPart.java:266)
at org.eclipse.ui.internal.ViewIntroAdapterPart$2.run(ViewIntroAdapterPart.java:74)
at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator.java:70)
at org.eclipse.ui.internal.ViewIntroAdapterPart.setStandby(ViewIntroAdapterPart.java:70)
at org.eclipse.ui.internal.ViewIntroAdapterPart$1.propertyChanged(ViewIntroAdapterPart.java:55)
at org.eclipse.ui.internal.WorkbenchPartReference.fireInternalPropertyChange(WorkbenchPartReference.java:374)
at org.eclipse.ui.internal.WorkbenchPartReference.fireZoomChange(WorkbenchPartReference.java:539)
at org.eclipse.ui.internal.PartPane.setZoomed(PartPane.java:349)
at org.eclipse.ui.internal.PartStack.setZoomed(PartStack.java:1526)
at org.eclipse.ui.internal.PartSashContainer.zoomIn(PartSashContainer.java:884)
at org.eclipse.ui.internal.PartSashContainer.childRequestZoomIn(PartSashContainer.java:905)
at org.eclipse.ui.internal.LayoutPart.requestZoomIn(LayoutPart.java:354)
at org.eclipse.ui.internal.PartStack.setState(PartStack.java:1501)
at org.eclipse.ui.internal.WorkbenchPage.setState(WorkbenchPage.java:3872)
at org.eclipse.ui.internal.WorkbenchPage.toggleZoom(WorkbenchPage.java:3944)
at org.eclipse.ui.internal.WorkbenchIntroManager.setIntroStandby(WorkbenchIntroManager.java:201)
at org.eclipse.ui.internal.WorkbenchIntroManager.showIntro(WorkbenchIntroManager.java:136)
at org.eclipse.ui.application.WorkbenchWindowAdvisor.openIntro(WorkbenchWindowAdvisor.java:173)
at org.eclipse.ui.internal.ide.application.IDEWorkbenchWindowAdvisor.openIntro(IDEWorkbenchWindowAdvisor.java:458)
at org.eclipse.ui.internal.WorkbenchWindow.open(WorkbenchWindow.java:777)
at org.eclipse.ui.internal.Workbench$20.runWithException(Workbench.java:1041)
at org.eclipse.ui.internal.StartupThreading$StartupRunnable.run(StartupThreading.java:31)
at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:35)
at org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchronizer.java:133)
at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.java:3378)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3036)
at org.eclipse.ui.application.WorkbenchAdvisor.openWindows(WorkbenchAdvisor.java:803)
at org.eclipse.ui.internal.Workbench$25.runWithException(Workbench.java:1361)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2293)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:2198)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:493)
at org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:288)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:488)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.java:149)
at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:113)
!SESSION 2009-11-12 18:49:53.969 -----------------------------------------------
!ENTRY org.eclipse.ui.workbench 4 0 2009-11-12 18:50:08.579
!STACK 0
!ENTRY org.eclipse.ui.workbench 4 0 2009-11-12 18:50:08.701
!STACK 0
!ENTRY org.eclipse.ui.workbench 4 0 2009-11-12 18:50:08.703
!STACK 0
!ENTRY org.eclipse.ui.workbench 4 0 2009-11-12 18:50:08.706
!STACK 0
!ENTRY org.eclipse.osgi 4 0 2009-11-12 18:50:08.743
!STACK 1
!SESSION 2009-11-12 19:36:28.514 -----------------------------------------------
!ENTRY org.eclipse.ui.workbench 4 0 2009-11-12 19:36:44.364
!STACK 0
!ENTRY org.eclipse.ui.workbench 4 0 2009-11-12 19:36:44.567
!STACK 0
!ENTRY org.eclipse.ui.workbench 4 0 2009-11-12 19:36:44.570
!STACK 0
!ENTRY org.eclipse.ui.workbench 4 0 2009-11-12 19:36:44.576
!STACK 0
!ENTRY org.eclipse.osgi 4 0 2009-11-12 19:36:44.630
!STACK 1
J’ai pourtant essayé d’installer d’autres paquets java mais sans succès !
Je m’en remet à vous maintenant !
Merci d’avance
