Erreur mysql avec kontact
Bonjour et merci à ceux qui prendront le temps ne serait ce que de lire ces lignes.
Depuis quelques jours je ne peux plus accéder à mon carnet d’adresse de kontact (assez ennuyeux tout de même)…
J’ai le message suivant au démarrage : Akonadi n’est pas opérationnel.
Voici les détails :
[code]Akonadi Server Self-Test Report
Test 1: SUCCESS
Database driver found.
Details: The QtSQL driver ‘QMYSQL’ is required by your current Akonadi server configuration and was found on your system.
File content of ‘/home/lavilotte-rolle/.config/akonadi/akonadiserverrc’:
[%General]
Driver=QMYSQL
SizeThreshold=4096
ExternalPayload=false
[QMYSQL]
Name=akonadi
Host=
User=
Password=
Options="UNIX_SOCKET=/home/lavilotte-rolle/.local/share/akonadi/db_misc/mysql.socket"
ServerPath=/usr/sbin/mysqld
StartServer=true
[Debug]
Tracer=null
Test 2: SUCCESS
MySQL server found.
Details: You currently have configured Akonadi to use the MySQL server ‘/usr/sbin/mysqld’.
Make sure you have the MySQL server installed, set the correct path and ensure you have the necessary read and execution rights on the server executable. The server executable is typically called ‘mysqld’, its locations varies depending on the distribution.
Test 3: SUCCESS
MySQL server is executable.
Details: MySQL server found: /usr/sbin/mysqld Ver 5.1.47-1 for debian-linux-gnu on x86_64 ((Debian))
Test 4: ERROR
MySQL server log contains errors.
Details: The MySQL server error log file ‘/home/lavilotte-rolle/.local/share/akonadi/db_data/mysql.err’ contains errors.
File content of ‘/home/lavilotte-rolle/.local/share/akonadi/db_data/mysql.err’:
100612 9:35:14 [Note] Plugin ‘FEDERATED’ is disabled.
InnoDB: The log sequence number in ibdata files does not match
InnoDB: the log sequence number in the ib_logfiles!
100612 9:35:15 InnoDB: Database was not shut down normally!
InnoDB: Starting crash recovery.
InnoDB: Reading tablespace information from the .ibd files…
InnoDB: Restoring possible half-written data pages from the doublewrite
InnoDB: buffer…
InnoDB: Last MySQL binlog file position 0 1286, file name ./mysql-bin.000056
100612 9:35:19 InnoDB: Started; log sequence number 0 3893415
100612 9:35:19 [Warning] Can’t open and lock time zone table: Table ‘mysql.time_zone_leap_second’ doesn’t exist trying to live without them
100612 9:35:19 [ERROR] Can’t open and lock privilege tables: Table ‘mysql.servers’ doesn’t exist
100612 9:35:19 [Note] /usr/sbin/mysqld: ready for connections.
Version: ‘5.1.47-1-log’ socket: ‘/home/lavilotte-rolle/.local/share/akonadi/db_misc/mysql.socket’ port: 0 (Debian)
Test 5: SUCCESS
MySQL server default configuration found.
Details: The default configuration for the MySQL server was found and is readable at /etc/akonadi/mysql-global.conf.
File content of ‘/etc/akonadi/mysql-global.conf’:
Global Akonadi MySQL server settings,
These settings can be adjusted using $HOME/.config/akonadi/mysql-local.conf
Based on advice by Kris Köhntopp kris@mysql.com
[mysqld]
skip_grant_tables
skip_networking
strict query parsing/interpretation
TODO: make Akonadi work with those settings enabled
#sql_mode=strict_trans_tables,strict_all_tables,strict_error_for_division_by_zero,no_auto_create_user,no_auto_value_on_zero,no_engine_substitution,no_zero_date,no_zero_in_date,only_full_group_by,pipes_as_concat
use InnoDB for transactions and better crash recovery
default_storage_engine=innodb
case-insensitive table names, avoids trouble on windows
lower_case_table_names=1
character_set_server=latin1
collation_server=latin1_general_ci
table_cache=200
thread_cache_size=3
log_bin=mysql-bin
expire_logs_days=3
#sync_bin_log=0
error log file name, relative to datadir
log_error=mysql.err
log_warnings=2
log all queries, useful for debugging but generates an enormous amount of data
#log=mysql.full
log queries slower than n seconds, log file name relative to datadir (for debugging only)
#log_slow_queries=mysql.slow
#long_query_time=1
log queries not using indices, debug only, disable for production use
#log_queries_not_using_indexes=1
maximum blob size
max_allowed_packet=32M
max_connections=256
makes sense when having the same query multiple times
makes no sense with prepared statements and/or transactions
query_cache_type=0
query_cache_size=0
innodb_file_per_table=1
innodb_log_buffer_size=1M
innodb_additional_mem_pool_size=1M
messure database size and adjust
SELECT sum(data_length) as bla, sum(index_length) as blub FROM information_schema.tables WHERE table_schema not in (“mysql”, “information_schema”);
innodb_buffer_pool_size=80M
size of average write burst, keep Innob_log_waits small, keep Innodb_buffer_pool_wait_free small (see show global status like “inno%”, show global variables)
innodb_log_file_size=64M
innodb_flush_log_at_trx_commit=2
Test 6: SKIP
MySQL server custom configuration not available.
Details: The custom configuration for the MySQL server was not found but is optional.
Test 7: SUCCESS
MySQL server configuration is usable.
Details: The MySQL server configuration was found at /home/lavilotte-rolle/.local/share/akonadi/mysql.conf and is readable.
File content of ‘/home/lavilotte-rolle/.local/share/akonadi/mysql.conf’:
[mysqld]
skip_grant_tables
skip_networking
table_cache=200
thread_cache_size=3
log_bin=mysql-bin
expire_logs_days=3
#sync_bin_log=0
log_error=mysql.err
log_warnings=2
#log=mysql.full
#long_query_time=1
maximum blob size
max_connections=256
query_cache_type=0
query_cache_size=0
Test 8: SUCCESS
akonadictl found and usable
Details: The program ‘/usr/bin/akonadictl’ to control the Akonadi server was found and could be executed successfully.
Result:
Akonadi 1.3.1
Test 9: SUCCESS
Akonadi control process registered at D-Bus.
Details: The Akonadi control process is registered at D-Bus which typically indicates it is operational.
Test 10: SUCCESS
Akonadi server process registered at D-Bus.
Details: The Akonadi server process is registered at D-Bus which typically indicates it is operational.
Test 11: ERROR
Nepomuk search service not registered at D-Bus.
Details: The Nepomuk search service is not registered at D-Bus which typically means it was not started or encountered a fatal error during startup.
Test 12: SUCCESS
Server protocol version is recent enough.
Details: The server Protocol version is 23, which equal or newer than the required version 23.
Test 13: ERROR
No resource agents found.
Details: No resource agents have been found, Akonadi is not usable without at least one. This usually means that no resource agents are installed or that there is a setup problem. The following paths have been searched: ‘/usr/share/akonadi/agents /usr/share/akonadi/agents’. The XDG_DATA_DIRS environment variable is set to ‘/usr/share:/usr/share:/usr/local/share’, make sure this includes all paths where Akonadi agents are installed to.
Directory listing of ‘/usr/share/akonadi/agents’:
birthdaysresource.desktop
contactsresource.desktop
icalresource.desktop
imapresource.desktop
kabcresource.desktop
kcalresource.desktop
knutresource.desktop
kolabproxyresource.desktop
localbookmarksresource.desktop
maildirresource.desktop
maildispatcheragent.desktop
mboxresource.desktop
microblog.desktop
mtdummyresource.desktop
nepomukcalendarfeeder.desktop
nepomukcontactfeeder.desktop
nepomuktagresource.desktop
nntpresource.desktop
notesresource.desktop
pop3resource.desktop
vcarddirresource.desktop
vcardresource.desktop
microblog.desktop
Environment variable XDG_DATA_DIRS is set to ‘/usr/share:/usr/share:/usr/local/share’
Test 14: SUCCESS
No current Akonadi server error log found.
Details: The Akonadi server did not report any errors during its current startup.
Test 15: SUCCESS
No previous Akonadi server error log found.
Details: The Akonadi server did not report any errors during its previous startup.
Test 16: SUCCESS
No current Akonadi control error log found.
Details: The Akonadi control process did not report any errors during its current startup.
Test 17: SUCCESS
No previous Akonadi control error log found.
Details: The Akonadi control process did not report any errors during its previous startup.
Si quelqu’un sait comment réparer tout ça…
Merci à vous !
