J’ai trouvé la solution apparament c un beug connu sur debian
Post subject: Bug#386469: openbsd-inetd: action “start” failed
Archived from groups: linux>debian>bugs>rc (more info?)
I’ve just tried this on a Debian Etch system and have not had any
problem, even with xinetd installed.
For reference I performed the following actions:
apt-get install xinetd
apt-get install openbsd-inetd (upgrade -3 to -5)
apt-get install inetutils-inetd (replacing openbsd-inetd)
apt-get install openbsd-inetd (replacing openbsd-inetd)
the last of these had the following messages:
mjj29@hecate:~/scm/debian/build $ sudo apt-get install openbsd-inetd
Reading package lists… Done
Building dependency tree… Done
The following packages will be REMOVED
inetutils-inetd
The following NEW packages will be installed
openbsd-inetd
0 upgraded, 1 newly installed, 1 to remove and 665 not upgraded.
Need to get 0B/34.6kB of archives.
After unpacking 45.1kB disk space will be freed.
Do you want to continue [Y/n]? y
dpkg: inetutils-inetd: dependency problems, but removing anyway as you request:
netbase depends on openbsd-inetd | inet-superserver; however:
Package openbsd-inetd is not installed.
Package inet-superserver is not installed.
Package openbsd-inetd which provides inet-superserver is not installed.
Package inetutils-inetd which provides inet-superserver is to be removed.
(Reading database … 189567 files and directories currently installed.)
Removing inetutils-inetd …
Stopping internet superserver: inetd.
Selecting previously deselected package openbsd-inetd.
(Reading database … 189557 files and directories currently installed.)
Unpacking openbsd-inetd (from …/openbsd-inetd_0.20050402-5_i386.deb) …
start-stop-daemon: warning: failed to kill 16239: No such process
Setting up openbsd-inetd (0.20050402-5) …
Starting internet superserver: inetd.
When upgrading it also stopped the inetd.
I’m currently running Version: 0.20050402-5
Matt
