voilà, je possède une distribution xebian (distribution pour xbox, basée sur une debian).
Cet apres-midi j’ai voulu installer firestarter avec la commande apt-get install firestarter. il m’a sorti une liste de package devant être mis à jour.
J’ai validé et à la fin j’ai eu un message d’erreur m’indiquant que firestarter n’a pu être installé car certains package n’ont pas été mis à jour.
Depuis quand je veux installer n’importe quel package avec cette commande,
j’obtiens une erreur:
[i]You might want to run `apt-get -f install' to correct these:
The following packages have unmet dependencies:
libdps1: Depends: xfree86-common but it is not installable
libfontenc1: Depends: x11-common but it is not going to be installed
libice6: Depends: x11-common but it is not going to be installed
libsm6: Depends: x11-common but it is not going to be installed
libx11-6: Depends: xfree86-common (> 4.3.0) but it is not installable
libxau6: Depends: x11-common but it is not going to be installed
libxaw7: Depends: xfree86-common but it is not installable
libxdmcp6: Depends: x11-common (>= 1:7.0.0) but it is not going to be installed
libxext6: Depends: xfree86-common but it is not installable
libxfont1: Depends: x11-common but it is not going to be installed
libxft1: Depends: xfree86-common but it is not installable
libxi6: Depends: xfree86-common but it is not installable
libxmu6: Depends: xfree86-common but it is not installable
libxmuu1: Depends: xfree86-common but it is not installable
libxp6: Depends: xfree86-common but it is not installable
libxpm4: Depends: xfree86-common but it is not installable
libxrandr2: Depends: xfree86-common but it is not installable
libxt6: Depends: xfree86-common but it is not installable
libxtrap6: Depends: xfree86-common but it is not installable
libxtst6: Depends: xfree86-common but it is not installable
libxv1: Depends: xfree86-common but it is not installable
mysql-server: Depends: mysql-server-5.0 but it is not going to be installed
nv-drv-xbox: Depends: xserver-xfree86 (>= 4.2.1-1) but it is not going to be installed
x-window-system: Depends: lbxproxy but it is not installable
Depends: proxymngr but it is not installable
Depends: twm but it is not going to be installed
Depends: xdm but it is not going to be installed
Depends: xfs but it is not going to be installed
Depends: xfwp but it is not installable
Depends: xnest but it is not going to be installed
Depends: xterm but it is not going to be installed
Depends: xvfb but it is not going to be installed
x-window-system-core: Depends: xserver-xfree86 but it is not going to be installed
Depends: xbase-clients but it is not going to be installed
Depends: xutils but it is not going to be installed
xfonts-100dpi: Depends: xfree86-common but it is not installable
Depends: xutils (> 4.0.3) but it is not going to be installed
xfonts-75dpi: Depends: xfree86-common but it is not installable
xfonts-base: Depends: xfree86-common but it is not installable
xfonts-scalable: Depends: xfree86-common but it is not installable
xlibmesa-dri: Depends: xfree86-common but it is not installable
xlibmesa-gl: Depends: xfree86-common but it is not installable
xlibmesa-glu: Depends: xfree86-common but it is not installable
xlibs-data: Depends: xfree86-common but it is not installable
xprint-common: Depends: xprint but it is not going to be installed
xprt-xprintorg: Depends: xprint but it is not going to be installed
xserver-xorg-core: Depends: x11-common (>= 1:7.0.0) but it is not going to be installed
Depends: xserver-xorg but it is not going to be installed
E: Unmet dependencies. Try 'apt-get -f install' with no packages (or specify a solution[/i]
Quelqu’un aurait-il une solution à ce problème.
Merci pour votre aide
