Je suis sous squeeze et il y a peu de temps j’ai décidé de faire un petit:
Apparemment, tout ne s’est pas bien passé mais je n’y ai pas fait attention. Sauf que maintenant ça a l’air de bloquer un peu tout…
lorsque je fais un:
j’obtiens ceci :
Setting up libthunar-vfs-1-2 (0.9.0-10) ...
No manual entry for thunar-data
No manual entry for libthunar-vfs-1-2
dpkg: error processing libthunar-vfs-1-2 (--configure):
subprocess post-installation script returned error exit status 16
dpkg: dependency problems prevent configuration of thunar:
thunar depends on libthunar-vfs-1-2 (>= 0.9.0); however:
Package libthunar-vfs-1-2 is not configured yet.
dpkg: error processing thunar (--configure):
dependency problems - leaving unconfigured
Setting up xscreensaver (5.05-3) ...
No manual entry for XScreenSaver-nogl
dpkg: error processing xscreensaver (--configure):
Setting up ca-certificates (20081127) ...
Updating certificates in /etc/ssl/certs....<standard input>:8: warning [p 1, 1.0i]: cannot adjust line
<standard input>:9: warning [p 1, 1.2i]: cannot adjust line
<standard input>:10: warning [p 1, 1.3i]: cannot adjust line
<standard input>:11: warning [p 1, 1.5i]: cannot adjust line
<standard input>:12: warning [p 1, 1.7i]: cannot adjust line
<standard input>:13: warning [p 1, 1.8i]: cannot adjust line
<standard input>:14: warning [p 1, 2.0i]: cannot adjust line
<standard input>:15: warning [p 1, 2.2i]: cannot adjust line
<standard input>:16: warning [p 1, 2.3i]: cannot adjust line
<standard input>:17: warning [p 1, 2.5i]: cannot adjust line
<standard input>:18: warning [p 1, 2.7i]: cannot adjust line
<standard input>:19: warning [p 1, 2.8i]: cannot adjust line
<standard input>:20: warning [p 1, 3.0i]: cannot adjust line
<standard input>:21: warning [p 1, 3.2i]: cannot adjust line
<standard input>:22: warning [p 1, 3.3i]: cannot adjust line
<standard input>:23: warning [p 1, 3.5i]: cannot adjust line
<standard input>:24: warning [p 1, 3.7i]: cannot adjust line
<standard input>:25: warning [p 1, 3.8i]: cannot adjust line
<standard input>:26: warning [p 1, 4.0i]: cannot adjust line
<standard input>:27: warning [p 1, 4.2i]: cannot adjust line
No manual entry for brasil.gov.br.pem
dpkg: error processing ca-certificates (--configure):
dpkg: dependency problems prevent configuration of xfdesktop4:
xfdesktop4 depends on libthunar-vfs-1-2 (>= 0.9.0); however:
dpkg: error processing xfdesktop4 (--configure):
Errors were encountered while processing:
libthunar-vfs-1-2
thunar
xscreensaver
ca-certificates
xfdesktop4
Est ce que quelqu’un rencontre un problème similaire, ou peut m’aider, s’il vous plait…?
D’avance merci pour votre aide,
Olivier
