Bonjour, au boot j’ai cette erreur :
root@lagache:/home/chris# cat /var/log/boot
Sat Jul 17 12:22:17 2010: Setting parameters of disc: (none).
Sat Jul 17 12:22:17 2010: Activating swap...done.
Sat Jul 17 12:22:17 2010: Checking root file system...fsck from util-linux-ng 2.17.2
Sat Jul 17 12:22:17 2010: /dev/sdc7: clean, 170425/9650176 files, 1805557/38582097 blocks (check in 5 mounts)
Sat Jul 17 12:22:17 2010: done.
Sat Jul 17 12:22:17 2010: Cleaning up ifupdown....
Sat Jul 17 12:22:17 2010: Setting up networking....
Sat Jul 17 12:22:17 2010: Loading kernel modules...done.
Sat Jul 17 12:22:17 2010: Activating lvm and md swap...done.
Sat Jul 17 12:22:17 2010: Checking file systems...fsck from util-linux-ng 2.17.2
Sat Jul 17 12:22:18 2010: /dev/sdd1: clean, 23365/5029888 files, 4714151/20103331 blocks
Sat Jul 17 12:22:18 2010: /dev/sdc5: clean, 223/61312 files, 12330/244975 blocks
Sat Jul 17 12:22:18 2010: /dev/sda1: clean, 36321/18317312 files, 33222043/73262416 blocks
Sat Jul 17 12:22:18 2010: /dev/sdb1: clean, 9249/18317312 files, 28097266/73262416 blocks (check in 5 mounts)
Sat Jul 17 12:22:19 2010: done.
Sat Jul 17 12:22:19 2010: Mounting local filesystems...done.
Sat Jul 17 12:22:19 2010: Activating swapfile swap...done.
Sat Jul 17 12:22:19 2010: Cleaning up temporary files....
Sat Jul 17 12:22:20 2010: Setting kernel variables ...done.
Sat Jul 17 12:22:20 2010: Configuring network interfaces...done.
Sat Jul 17 12:22:20 2010: Starting portmap daemon....
Sat Jul 17 12:22:20 2010: Starting NFS common utilities: statd.
Sat Jul 17 12:22:20 2010: Cleaning up temporary files....
Sat Jul 17 12:22:20 2010: Setting up ALSA...done.
Sat Jul 17 12:22:20 2010: Setting console screen modes and fonts.
Sat Jul 17 12:22:20 2010: ^[]R^[[9;30]^[[14;30]Setting sensors limits.
Sat Jul 17 12:22:21 2010: Running scripts in rcS.d/ took 10 seconds.
Sat Jul 17 12:22:21 2010: INIT: Entering runlevel: 2
Sat Jul 17 12:22:21 2010: Using makefile-style concurrent boot in runlevel 2.
Sat Jul 17 12:22:21 2010: udevd[1129]: bind failed: Address already in use
Sat Jul 17 12:22:21 2010: udevd[1129]: error binding control socket, seems udevd is already running
Sat Jul 17 12:22:21 2010: Setting up ALSA…done.
Sat Jul 17 12:22:21 2010: Cleaning up temporary files…
Sat Jul 17 12:22:21 2010: Starting the hotplug events dispatcher: udevderror binding control socket, seems udevd is already running
Sat Jul 17 12:22:21 2010: ^[[31mfailed!^[[39;49m
Sat Jul 17 12:22:21 2010: Cleaning up ifupdown....
Sat Jul 17 12:22:21 2010: Setting sensors limits.
Sat Jul 17 12:22:22 2010: Enabling additional executable binary formats: binfmt-support.
Sat Jul 17 12:22:22 2010: Setting parameters of disc: (none).
Sat Jul 17 12:22:22 2010: Starting enhanced syslogd: rsyslogd.
Sat Jul 17 12:22:23 2010: Starting system message bus: dbus.
Sat Jul 17 12:22:24 2010: Starting ACPI services....
Sat Jul 17 12:22:24 2010: Starting network connection manager: NetworkManager.
Sat Jul 17 12:22:24 2010: Starting GNOME Display Manager: gdm3.
Sat Jul 17 12:22:26 2010: Starting anac(h)ronistic cron: anacron.
Sat Jul 17 12:22:26 2010: Starting deferred execution scheduler: atd.
Sat Jul 17 12:22:27 2010: Starting Avahi mDNS/DNS-SD Daemon: avahi-daemon.
Sat Jul 17 12:22:27 2010: Starting bluetooth: bluetoothd.
Sat Jul 17 12:22:28 2010: Starting periodic command scheduler: cron.
Sat Jul 17 12:22:28 2010: Starting Common Unix Printing System: cupsd.
Sat Jul 17 12:22:30 2010: Starting MTA:Starting kerneloops:
Sat Jul 17 12:22:31 2010: exim4.
Sat Jul 17 12:22:31 2010: Loading cpufreq kernel modules...done (none).
Sat Jul 17 12:22:31 2010: Loading kernel modules...done.
Sat Jul 17 12:22:31 2010: CPUFreq Utilities: Setting ondemand CPUFreq governor...disabled, governor not available...done.
Sat Jul 17 12:22:31 2010: Cleaning up temporary files....
Sat Jul 17 12:22:31 2010: mkdir: cannot create directory `/lib/init/rw/sendsigs.omit.d/': File exists
Sat Jul 17 12:22:31 2010: Starting NFS common utilities: statd.
Sat Jul 17 12:22:32 2010: Starting portmap daemon....
Sat Jul 17 12:22:32 2010: Setting kernel variables ...done.
Sat Jul 17 12:22:32 2010: Starting SANE network scanner server: saned.
Je ne sais si cela est la cause de mon problême, mais je n’ai plus de clavier ( brancher sur la petite prise verte de ma CM …) PS/2 il me semble !!
et de souris brancher sur le port USB de la CM, actuellemnt je fonctionne avec un clavier USB et ma souris USB branchés sur une carte PCI multi ports USB .
Merci de votre aide urgente !!! ![]()
[EDIT du 18-07] J’ai changé le titre tu topic pour être plus explicite avec la réalité !!!
mais est-ce bien cela qui me bloque mon clavier et ma souris ???
