Bonsoir
Tout est dans le titre, ça dure depuis un moment, c’est moche mais je ne vois pas de dysfonctionnement.
Je n’ai pas trouvé de piste sur le net
Quelqu’un a une piste et comprend un peu d’où ça peut venir ?
[quote]Wed Oct 5 23:11:19 2011: Setting parameters of disc: (none).
Wed Oct 5 23:11:19 2011: Setting preliminary keymap…done.
Wed Oct 5 23:11:19 2011: Activating swap…done.
Wed Oct 5 23:11:19 2011: Checking root file system…fsck from util-linux 2.19.1
Wed Oct 5 23:11:19 2011: udevd[823]: failed to execute ‘/lib/udev/vol_id’ ‘vol_id --export /dev/sda5’: No such file or directory
Wed Oct 5 23:11:19 2011: /dev/sda5: clean, 208026/666496 files, 2015805/2662765 blocks
Wed Oct 5 23:11:19 2011: done.
Wed Oct 5 23:11:19 2011: udevd[830]: failed to execute ‘/lib/udev/vol_id’ ‘vol_id --export /dev/sda5’: No such file or directory
Wed Oct 5 23:11:20 2011: udevd[902]: failed to execute ‘/lib/udev/vol_id’ ‘vol_id --export /dev/loop1’: No such file or directory
Wed Oct 5 23:11:20 2011: udevd[905]: failed to execute ‘/lib/udev/vol_id’ ‘vol_id --export /dev/loop4’: No such file or directory
Wed Oct 5 23:11:20 2011: udevd[904]: failed to execute ‘/lib/udev/vol_id’ ‘vol_id --export /dev/loop6’: No such file or directory
Wed Oct 5 23:11:20 2011: udevd[906]: failed to execute ‘/lib/udev/vol_id’ ‘vol_id --export /dev/loop2’: No such file or directory
Wed Oct 5 23:11:20 2011: udevd[908]: failed to execute ‘/lib/udev/vol_id’ ‘vol_id --export /dev/loop7’: No such file or directory
Wed Oct 5 23:11:20 2011: udevd[909]: failed to execute ‘/lib/udev/vol_id’ ‘vol_id --export /dev/loop5’: No such file or directory
Wed Oct 5 23:11:20 2011: udevd[907]: failed to execute ‘/lib/udev/vol_id’ ‘vol_id --export /dev/loop0’: No such file or directory
Wed Oct 5 23:11:20 2011: udevd[911]: failed to execute ‘/lib/udev/vol_id’ ‘vol_id --export /dev/loop3’: No such file or directory
Wed Oct 5 23:11:20 2011: Loading kernel modules…done.
Wed Oct 5 23:11:20 2011: Activating lvm and md swap…done.
Wed Oct 5 23:11:20 2011: Checking file systems…fsck from util-linux 2.19.1
Wed Oct 5 23:11:20 2011: udevd[1006]: failed to execute ‘/lib/udev/vol_id’ ‘vol_id --export /dev/sda2’: No such file or directory
Wed Oct 5 23:11:20 2011: /dev/sda2: clean, 239/64384 files, 13314/257040 blocks (check in 3 mounts)
Wed Oct 5 23:11:20 2011: /dev/sda7: clean, 57139/4915200 files, 2628878/19649495 blocks
Wed Oct 5 23:11:20 2011: udevd[1011]: failed to execute ‘/lib/udev/vol_id’ ‘vol_id --export /dev/sda2’: No such file or directory
Wed Oct 5 23:11:20 2011: udevd[1013]: failed to execute ‘/lib/udev/vol_id’ ‘vol_id --export /dev/sda7’: No such file or directory
Wed Oct 5 23:11:20 2011: udevd[1018]: failed to execute ‘/lib/udev/vol_id’ ‘vol_id --export /dev/sda7’: No such file or directory
Wed Oct 5 23:11:20 2011: udevd[1020]: failed to execute ‘/lib/udev/vol_id’ ‘vol_id --export /dev/sda4’: No such file or directory
Wed Oct 5 23:11:20 2011: multimedia: clean, 13985/39362560 files, 35881992/157441016 blocks (check after next mount)
Wed Oct 5 23:11:20 2011: done.
Wed Oct 5 23:11:20 2011: udevd[1026]: failed to execute ‘/lib/udev/vol_id’ ‘vol_id --export /dev/sda4’: No such file or directory
Wed Oct 5 23:11:20 2011: Mounting local filesystems…done.
Wed Oct 5 23:11:21 2011: Activating swapfile swap…done.
Wed Oct 5 23:11:21 2011: Cleaning up temporary files…
Wed Oct 5 23:11:21 2011: Cleaning up ifupdown…
Wed Oct 5 23:11:21 2011: Setting up networking…
Wed Oct 5 23:11:21 2011: Configuring network interfaces…done.
Wed Oct 5 23:11:21 2011: Setting kernel variables …done.
Wed Oct 5 23:11:21 2011: Starting rpcbind daemon…rpcbind: Cannot open ‘/var/run/rpcbind/rpcbind.xdr’ file for reading, errno 2 (No such file or directory)
Wed Oct 5 23:11:21 2011: rpcbind: Cannot open ‘/var/run/rpcbind/portmap.xdr’ file for reading, errno 2 (No such file or directory)
Wed Oct 5 23:11:21 2011: .
Wed Oct 5 23:11:21 2011: Starting NFS common utilities: statd idmapd.
Wed Oct 5 23:11:21 2011: Setting up ALSA…done.
Wed Oct 5 23:11:22 2011: Setting console screen modes and fonts.
Wed Oct 5 23:11:22 2011: ^[]R^[[9;30]^[[14;30]Setting up console font and keymap…done.
Wed Oct 5 23:11:22 2011: Setting sensors limits.
Wed Oct 5 23:11:22 2011: INIT: Entering runlevel: 2
Wed Oct 5 23:11:22 2011: Using makefile-style concurrent boot in runlevel 2.
Wed Oct 5 23:11:22 2011: Starting NFS common utilities: statd idmapd.
Wed Oct 5 23:11:23 2011: Starting rpcbind daemon…Already running…
Wed Oct 5 23:11:23 2011: Enabling additional executable binary formats: binfmt-support.
Wed Oct 5 23:11:23 2011: Starting enhanced syslogd: rsyslogd.
Wed Oct 5 23:11:24 2011: Starting system message bus: dbus.
Wed Oct 5 23:11:24 2011: Starting Music Player Daemon: mpd.
Wed Oct 5 23:11:25 2011: Starting virtual private network daemon:.
Wed Oct 5 23:11:25 2011: Starting GNOME Display Manager: gdm3.
Wed Oct 5 23:11:26 2011: Starting ACPI services…
Wed Oct 5 23:11:26 2011: Starting web server: apache2.
Wed Oct 5 23:11:27 2011: Starting deferred execution scheduler: atd.
Wed Oct 5 23:11:28 2011: Starting Avahi mDNS/DNS-SD Daemon: avahi-daemon.
Wed Oct 5 23:11:28 2011: Starting bluetooth: bluetoothd compatibily daemons not started, see bluez-compat package.
Wed Oct 5 23:11:29 2011: Starting periodic command scheduler: cron.
Wed Oct 5 23:11:29 2011: Starting MTA:saned disabled; edit /etc/default/saned
Wed Oct 5 23:11:30 2011: exim4.
Wed Oct 5 23:11:30 2011: Loading cpufreq kernel modules…done (acpi-cpufreq).
Wed Oct 5 23:11:30 2011: CPUFreq Utilities: Setting ondemand CPUFreq governor…CPU0…CPU1…done.
Wed Oct 5 23:11:31 2011: Starting upnp media server: mediatomb.
