J’ai installé debian 9 depuis peu sur un pc portable et le démarrage est un peu long car il y a des messages d’erreur et des temps d’attente …
Je vous donne le résultat de la commande : sudo dmesg -l err
9.185825] rtl8723be 0000:02:00.0: firmware: failed to load rtlwifi/rtl8723befw.bin (-2)
[ 9.200218] intel_soc_dts_thermal: request_threaded_irq ret -22
[ 9.909617] bluetooth hci0: firmware: failed to load rtl_bt/rtl8723b_config.bin (-2)
[ 9.909621] Bluetooth: hci0: Failed to load rtl_bt/rtl8723b_config.bin
[ 9.909635] bluetooth hci0: firmware: failed to load rtl_bt/rtl8723b_fw.bin (-2)
[ 9.909638] Bluetooth: hci0: Failed to load rtl_bt/rtl8723b_fw.bin
[ 25.592727] r8169 0000:03:00.0: firmware: failed to load rtl_nic/rtl8168g-2.fw (-2)
[ 46.674162] INFO: rcu_sched self-detected stall on CPU
[ 46.674223] 0-...: (5250 ticks this GP) idle=c5d/140000000000001/0 softirq=5199/5199 fqs=2625
[ 46.674293] (t=5251 jiffies g=1611 c=1610 q=138)
[ 77.162364] INFO: rcu_sched self-detected stall on CPU
[ 77.162372] 1-...: (1 GPs behind) idle=8b1/140000000000001/0 softirq=4317/4318 fqs=2624
[ 77.162375] (t=5250 jiffies g=1615 c=1614 q=7305)
[ 109.939476] INFO: rcu_sched self-detected stall on CPU
[ 109.939487] 0-...: (5249 ticks this GP) idle=d15/140000000000001/0 softirq=6200/6200 fqs=2623
[ 109.939490] (t=5250 jiffies g=1740 c=1739 q=38)
[ 165.265595] INFO: rcu_sched self-detected stall on CPU
[ 165.265606] 0-...: (5250 ticks this GP) idle=351/140000000000001/0 softirq=8974/8974 fqs=2624
[ 165.265609] (t=5251 jiffies g=3327 c=3326 q=3835)
[ 196.706162] INFO: rcu_sched self-detected stall on CPU
[ 196.706172] 1-...: (5250 ticks this GP) idle=8ff/140000000000001/0 softirq=7863/7866 fqs=2623
[ 196.706175] (t=5250 jiffies g=3388 c=3387 q=1452)
Merci pour votre aide
