Erreurs dans syslog
J’ai plusieurs erreurs dans mon syslog :
Mar  7 12:11:29 jessie kernel: [ 1970.075163] Raw EDID:
Mar  7 12:11:29 jessie kernel: [ 1970.075167]  	00 ff ff ff ff ff ff 00 22 f0 1e 26 01 01 01 01
Mar  7 12:11:29 jessie kernel: [ 1970.075170]  	0f 0f 01 03 68 26 1e 78 ee a1 50 a3 57 4c 9d 25
Mar  7 12:11:29 jessie kernel: [ 1970.075172]  	11 50 54 ad ef 80 81 80 01 01 01 01 01 01 01 01
Mar  7 12:11:29 jessie kernel: [ 1970.075175]  	01 01 01 01 01 01 30 2a 00 98 51 00 2a 40 30 70
Mar  7 12:11:29 jessie kernel: [ 1970.075177]  	13 00 54 0e 11 40 00 1e 00 00 00 ff 00 43 4e 43
Mar  7 12:11:29 jessie kernel: [ 1970.075180]  	35 31 35 30 36 4c 4c 0a 20 20 00 00 00 fd 00 32
Mar  7 12:11:29 jessie kernel: [ 1970.075182]  	4c 1e 53 0e 00 0a 20 20 20 20 20 20 00 00 00 fc
Mar  7 12:11:29 jessie kernel: [ 1970.075185]  	00 68 70 20 4c 31 39 30 32 0a 20 20 20 20 00 9e
Mar  7 12:11:29 jessie kernel: [ 1970.103009] [drm:drm_edid_block_valid] *ERROR* EDID checksum is invalid, remainder is 2
Mar  7 12:11:29 jessie kernel: [ 1970.103012] Raw EDID:
Mar  7 12:11:29 jessie kernel: [ 1970.103015]  	00 ff ff ff ff ff ff 00 22 f0 1e 26 01 01 01 01
Mar  7 12:11:29 jessie kernel: [ 1970.103017]  	0f 0f 01 03 68 26 1e 78 ee a1 50 a3 57 4c 9d 25
Mar  7 12:11:29 jessie kernel: [ 1970.103020]  	11 50 54 ad ef 80 81 80 01 01 01 01 01 01 01 01
Mar  7 12:11:29 jessie kernel: [ 1970.103022]  	01 01 01 01 01 01 30 2a 00 98 51 00 2a 40 30 70
Mar  7 12:11:29 jessie kernel: [ 1970.103024]  	13 00 54 0e 11 00 00 1e 00 00 00 ff 00 43 4e 43
Mar  7 12:11:29 jessie kernel: [ 1970.103027]  	35 31 35 30 36 4c 4c 0a 20 20 00 00 00 fd 00 32
Mar  7 12:11:29 jessie kernel: [ 1970.103029]  	4c 1e 53 0e 00 0a 20 20 20 20 20 20 00 02 00 fc
Mar  7 12:11:29 jessie kernel: [ 1970.103031]  	00 68 70 20 4c 31 39 30 32 0a 20 20 20 20 00 9e
Mar  7 12:11:29 jessie kernel: [ 1970.130842] [drm:drm_edid_block_valid] *ERROR* EDID checksum is invalid, remainder is 1
Mar  7 12:11:29 jessie kernel: [ 1970.130845] Raw EDID:
J’ai plusieurs lignes comme celles-la.
radeon 0000:01:00.0: VGA-1: EDID block 0 invalid.
Mar  7 12:11:29 jessie kernel: [ 1970.158706] [drm:radeon_vga_detect] *ERROR* VGA-1: probed a monitor but no|invalid EDID
Mar  7 12:17:01 jessie CRON[1249]: (root) CMD (   cd / && run-parts --report /etc/cron.hourly)
Au démarrage, avant grub et après le bios, j’ai ceci qui apparaît à l’écran :
Signal entrée hors limite. Change settings  1280 x 1024-60hz par 1280 x 1024@60hz.
Je n’ai pas de xorg.conf. Je pensais en créer un et y mettre :
Identifier "Screen0"
Device     "Card0"
Monitor    "Monitor0"
SubSection "Display"
	Viewport   0 0
	Depth     1
EndSubSection
      	Viewport   0 0
	Depth     4
EndSubSection
	Viewport   0 0
	Depth     8
EndSubSection
	Viewport   0 0
	Depth     15
EndSubSection
	Viewport   0 0
	Depth     16
EndSubSection
	Viewport   0 0
	Depth     24
       Modes    "1280x1024@60hz"
EndSubSection
Le message d’avertissement apparaît avant Grub, donc je pencherais pour un problème de configuration de GRUB.
Peut-être que ce sujet peut t’intéresser :
https://www.debian-fr.org/t/grub-resolution-de-grub-sous-sandybridge/57918
Il faut utiliser les commandes vbeinfo et bien paramétrer ton fichier /etc/default/grub.
Et ne pas oublier de mettre à jour GRUB avec un update-grub après modification de son fichier de configuration.
