Le sda n’a que 6 mois et sdb un peu plus d’un an.
Depuis le reboot je n’ai eu que quelque fois les erreurs, ca s’est calmé aujourd’hui.
smartctl -a /dev/sda
smartctl 5.41 2011-06-09 r3365 [x86_64-linux-3.2.0-4-amd64] (local build)
Copyright (C) 2002-11 by Bruce Allen, http://smartmontools.sourceforge.net
=== START OF INFORMATION SECTION ===
Device Model: ST31000524AS
Serial Number: 6VPJS9VX
LU WWN Device Id: 5 000c50 04a9f0416
Firmware Version: JC4B
User Capacity: 1 000 204 886 016 bytes [1,00 TB]
Sector Size: 512 bytes logical/physical
Device is: Not in smartctl database [for details use: -P showall]
ATA Version is: 8
ATA Standard is: ATA-8-ACS revision 4
Local Time is: Fri Feb 1 18:27:46 2013 CET
SMART support is: Available - device has SMART capability.
SMART support is: Enabled
=== START OF READ SMART DATA SECTION ===
SMART overall-health self-assessment test result: PASSED
General SMART Values:
Offline data collection status: (0x82) Offline data collection activity
was completed without error.
Auto Offline Data Collection: Enabled.
Self-test execution status: ( 0) The previous self-test routine completed
without error or no self-test has ever
been run.
Total time to complete Offline
data collection: ( 600) seconds.
capabilities: (0x7b) SMART execute Offline immediate.
Auto Offline data collection on/off support.
Suspend Offline collection upon new
command.
Offline surface scan supported.
Self-test supported.
Conveyance Self-test supported.
Selective Self-test supported.
SMART capabilities: (0x0003) Saves SMART data before entering
power-saving mode.
Supports SMART auto save timer.
Error logging capability: (0x01) Error logging supported.
General Purpose Logging supported.
Short self-test routine
recommended polling time: ( 1) minutes.
Extended self-test routine
recommended polling time: ( 177) minutes.
Conveyance self-test routine
recommended polling time: ( 2) minutes.
SCT capabilities: (0x103f) SCT Status supported.
SCT Error Recovery Control supported.
SCT Feature Control supported.
SCT Data Table supported.
SMART Attributes Data Structure revision number: 10
Vendor Specific SMART Attributes with Thresholds:
ID# ATTRIBUTE_NAME FLAG VALUE WORST THRESH TYPE UPDATED WHEN_FAILED RAW_VALUE
1 Raw_Read_Error_Rate 0x000f 110 099 006 Pre-fail Always - 27902769
3 Spin_Up_Time 0x0003 100 100 000 Pre-fail Always - 0
4 Start_Stop_Count 0x0032 100 100 020 Old_age Always - 36
5 Reallocated_Sector_Ct 0x0033 100 100 036 Pre-fail Always - 0
7 Seek_Error_Rate 0x000f 071 060 030 Pre-fail Always - 14342840
9 Power_On_Hours 0x0032 094 094 000 Old_age Always - 5296
10 Spin_Retry_Count 0x0013 100 100 097 Pre-fail Always - 0
12 Power_Cycle_Count 0x0032 100 100 020 Old_age Always - 36
183 Runtime_Bad_Block 0x0032 100 100 000 Old_age Always - 0
184 End-to-End_Error 0x0032 100 100 099 Old_age Always - 0
187 Reported_Uncorrect 0x0032 100 100 000 Old_age Always - 0
188 Command_Timeout 0x0032 100 099 000 Old_age Always - 40
189 High_Fly_Writes 0x003a 100 100 000 Old_age Always - 0
190 Airflow_Temperature_Cel 0x0022 060 052 045 Old_age Always - 40 (Min/Max 39/41)
194 Temperature_Celsius 0x0022 040 048 000 Old_age Always - 40 (0 18 0 0)
195 Hardware_ECC_Recovered 0x001a 035 024 000 Old_age Always - 27902769
197 Current_Pending_Sector 0x0012 100 100 000 Old_age Always - 0
198 Offline_Uncorrectable 0x0010 100 100 000 Old_age Offline - 0
199 UDMA_CRC_Error_Count 0x003e 200 200 000 Old_age Always - 0
240 Head_Flying_Hours 0x0000 100 253 000 Old_age Offline - 79680233280766
241 Total_LBAs_Written 0x0000 100 253 000 Old_age Offline - 15014408
242 Total_LBAs_Read 0x0000 100 253 000 Old_age Offline - 385216748
SMART Error Log Version: 1
No Errors Logged
SMART Self-test log structure revision number 1
No self-tests have been logged. [To run self-tests, use: smartctl -t]
SMART Selective self-test log data structure revision number 1
SPAN MIN_LBA MAX_LBA CURRENT_TEST_STATUS
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
Selective self-test flags (0x0):
After scanning selected spans, do NOT read-scan remainder of disk.
If Selective self-test is pending on power-up, resume after 0 minute delay.
smartctl -a /dev/sdb
Model Family: Hitachi Deskstar 7K3000
Device Model: Hitachi HDS723020BLA642
Serial Number: MN1220F31SLMRD
LU WWN Device Id: 5 000cca 369d8d1ff
Firmware Version: MN6OA5C0
User Capacity: 2 000 398 934 016 bytes [2,00 TB]
Device is: In smartctl database [for details use: -P show]
ATA Version is: 8
Local Time is: Fri Feb 1 18:29:38 2013 CET
Offline data collection status: (0x84) Offline data collection activity
was suspended by an interrupting command from host.
been run.
data collection: (19381) seconds.
capabilities: (0x5b) SMART execute Offline immediate.
command.
No Conveyance Self-test supported.
power-saving mode.
recommended polling time: ( 255) minutes.
SCT capabilities: (0x003d) SCT Status supported.
SMART Attributes Data Structure revision number: 16
1 Raw_Read_Error_Rate 0x000b 100 100 016 Pre-fail Always - 0
2 Throughput_Performance 0x0005 135 135 054 Pre-fail Offline - 86
3 Spin_Up_Time 0x0007 136 136 024 Pre-fail Always - 411 (Average 430)
4 Start_Stop_Count 0x0012 100 100 000 Old_age Always - 190
5 Reallocated_Sector_Ct 0x0033 100 100 005 Pre-fail Always - 0
7 Seek_Error_Rate 0x000b 100 100 067 Pre-fail Always - 0
8 Seek_Time_Performance 0x0005 135 135 020 Pre-fail Offline - 26
9 Power_On_Hours 0x0012 099 099 000 Old_age Always - 12359
10 Spin_Retry_Count 0x0013 100 100 060 Pre-fail Always - 0
12 Power_Cycle_Count 0x0032 100 100 000 Old_age Always - 79
192 Power-Off_Retract_Count 0x0032 100 100 000 Old_age Always - 217
193 Load_Cycle_Count 0x0012 100 100 000 Old_age Always - 217
194 Temperature_Celsius 0x0002 139 139 000 Old_age Always - 43 (Min/Max 16/48)
196 Reallocated_Event_Count 0x0032 100 100 000 Old_age Always - 0
197 Current_Pending_Sector 0x0022 100 100 000 Old_age Always - 0
198 Offline_Uncorrectable 0x0008 100 100 000 Old_age Offline - 0
199 UDMA_CRC_Error_Count 0x000a 200 200 000 Old_age Always - 0
No Errors Logged
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
Je sauvegarde tout, tous les weeks end, à surveiller de près… :\
PS: Intéressant le lien wikipedia, merci
