Error, pkgProblemResolver::Resolve generated breaks
Je suis nouveau sur le forum et je cherche de l’aide pour un problème qui dépasse mes maigres compétences en Linux…
Voici les informations de mon serveur: Debian AMD64 Wheezy noyau 3.2.13-grsec-xxxx-grs-ipv6-64 #1
J’ai récemment voulu tester ProFTPd version 1.3.5 qui n’est disponible que sous Jessie, et ai donc forcer son installation… et je crois que ca a mis un pêu le bazarre dans le système.
Voila les logs que j’obtions quand je veux faire un apt-get install xxx:
[code]Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
The following packages have unmet dependencies:
apache2.2-bin : Depends: libapr1 (>= 1.4.2) but it is not going to be installed
Depends: libaprutil1 (>= 1.4.0) but it is not going to be installed
Depends: libaprutil1-dbd-sqlite3 but it is not going to be installed or
libaprutil1-dbd-mysql but it is not going to be installed or
libaprutil1-dbd-odbc but it is not going to be installed or
libaprutil1-dbd-pgsql but it is not going to be installed or
libaprutil1-dbd-freetds but it is not going to be installed
Depends: libaprutil1-ldap but it is not going to be installed
Depends: libcap2 (>= 2.10) but it is not going to be installed
Depends: libldap-2.4-2 (>= 2.4.7) but it is not going to be installed
apache2.2-common : Depends: apache2-utils but it is not going to be installed
Depends: procps
Depends: perl but it is not going to be installed
Recommends: ssl-cert but it is not going to be installed
libbz2-1.0 : PreDepends: multiarch-support
libc6 : Depends: libgcc1 but it is not going to be installed
Breaks: locales (< 2.19)
libcomerr2 : PreDepends: multiarch-support
libdb5.1 : PreDepends: multiarch-support
libgssapi-krb5-2 : Depends: libkeyutils1 but it is not going to be installed
Depends: libkrb5support0 (>= 1.7dfsg~beta2) but it is not going to be installed
libk5crypto3 : Depends: libkeyutils1 but it is not going to be installed
libkrb5-3 : Depends: libkeyutils1 but it is not going to be installed
Depends: libkrb5support0 (= 1.10.1+dfsg-5+deb7u2) but it is not going to be installed
libmagic1 : PreDepends: multiarch-support
libpcre3 : PreDepends: multiarch-support
libssl1.0.0 : Depends: debconf (>= 0.5) but it is not going to be installed or
debconf-2.0
libxml2 : Depends: liblzma5 (>= 5.1.1alpha+20120614) but it is not going to be installed
Recommends: xml-core but it is not going to be installed
locales : Depends: glibc-2.13-1
debconf-2.0
php5-common : Depends: sed (>= 4.1.1-1) but it is not going to be installed
Depends: psmisc (>= 22.15-1~) but it is not going to be installed
Depends: lsof but it is not going to be installed
PreDepends: dpkg (>= 1.15.7.2~)
tzdata : Depends: debconf (>= 0.5) but it is not going to be installed or
debconf-2.0
ucf : Depends: debconf (>= 1.5.19) but it is not going to be installed
Depends: coreutils (>= 5.91)
zlib1g : PreDepends: multiarch-support
E: Error, pkgProblemResolver::Resolve generated breaks, this may be caused by held packages.
Une idée de comment résoudre cela svp???
Je me répond à moi même…
J’avais aussi du upgrader libc6 pour que ProFTPd fonctionne en version 1.3.5 Jessie.
Il fallait donc aussi le downgrader ce que j’ai pu faire via la commande:
Problème résolu :slightly_smiling:
