Voilà (64 ko
[code]
X Window System Version 6.9.0 (Debian 6.9.0.dfsg.1-4 20060114230205 David Nusinow dnusinow@debian.org)
Release Date: 21 December 2005
X Protocol Version 11, Revision 0, Release 6.9
Build Operating System: Linux 2.6.15-1-686 i686 [ELF]
Current Operating System: Linux maxime 2.6.15-1-486 #2 Mon Mar 6 15:19:16 UTC 2006 i686
Build Date: 14 January 2006
Before reporting problems, check http://wiki.X.Org
Module Loader present
OS Kernel: Linux version 2.6.15-1-486 (Debian 2.6.15-8) (waldi@debian.org) (gcc version 4.0.3 20060212 (prerelease) (Debian 4.0.2-9)) #2 Mon Mar 6 15:19:16 UTC 2006
Markers: (–) probed, () from config file, (==) default setting,
(==) Log file: “/var/log/Xorg.0.log”, Time: Fri Mar 24 17:05:53 2006
(==) Using config file: “/etc/X11/xorg.conf”
(==) ServerLayout “Default Layout”
() |–>Screen “Default Screen” (0)
() | |–>Monitor “99G”
() | |–>Device “ATI Technologies, Inc. Radeon R350 [Radeon 9800 Pro]”
() |–>Input Device “Generic Keyboard”
() Option “XkbRules” “xorg”
() XKB: rules: “xorg”
() Option “XkbModel” “pc105”
() XKB: model: “pc105”
() Option “XkbLayout” “fr”
() XKB: layout: “fr”
(==) Keyboard: CustomKeycode disabled
() |–>Input Device “Configured Mouse”
(WW) The directory “/usr/lib/X11/fonts/cyrillic” does not exist.
Entry deleted from font path.
(WW) The directory “/usr/lib/X11/fonts/CID” does not exist.
(**) FontPath set to “unix/:7100,/usr/lib/X11/fonts/misc,/usr/lib/X11/fonts/100dpi/:unscaled,/usr/lib/X11/fonts/75dpi/:unscaled,/usr/lib/X11/fonts/Type1,/usr/lib/X11/fonts/100dpi,/usr/lib/X11/fonts/75dpi”
(==) RgbPath set to “/usr/X11R6/lib/X11/rgb”
(==) ModulePath set to “/usr/X11R6/lib/modules”
(II) Open ACPI successful (/var/run/acpid.socket)
(II) Module ABI versions:
X.Org ANSI C Emulation: 0.2
X.Org Video Driver: 0.8
X.Org XInput driver : 0.5
X.Org Server Extension : 0.2
X.Org Font Renderer : 0.4
(II) Loader running on linux
(II) LoadModule: “bitmap”
(II) Loading /usr/X11R6/lib/modules/fonts/libbitmap.so
(II) Module bitmap: vendor="X.Org Foundation"
compiled for 6.9.0, module version = 1.0.0
Module class: X.Org Font Renderer
ABI class: X.Org Font Renderer, version 0.4
(II) Loading font Bitmap
(II) LoadModule: “pcidata”
(II) Loading /usr/X11R6/lib/modules/libpcidata.so
(II) Module pcidata: vendor="X.Org Foundation"
ABI class: X.Org Video Driver, version 0.8
(++) using VT number 7
(II) PCI: PCI scan (all values are in hex)
(II) PCI: 00:00:0: chip 8086,2570 card 8086,2570 rev 02 class 06,00,00 hdr 00
(II) PCI: 00:01:0: chip 8086,2571 card 0000,0000 rev 02 class 06,04,00 hdr 01
(II) PCI: 00:1d:0: chip 8086,24d2 card 1462,0120 rev 02 class 0c,03,00 hdr 80
(II) PCI: 00:1d:1: chip 8086,24d4 card 1462,0120 rev 02 class 0c,03,00 hdr 00
(II) PCI: 00:1d:2: chip 8086,24d7 card 1462,0120 rev 02 class 0c,03,00 hdr 00
(II) PCI: 00:1d:3: chip 8086,24de card 1462,0120 rev 02 class 0c,03,00 hdr 00
(II) PCI: 00:1d:7: chip 8086,24dd card 1462,7470 rev 02 class 0c,03,20 hdr 00
(II) PCI: 00:1e:0: chip 8086,244e card 0000,0000 rev c2 class 06,04,00 hdr 01
(II) PCI: 00:1f:0: chip 8086,24d0 card 0000,0000 rev 02 class 06,01,00 hdr 80
(II) PCI: 00:1f:1: chip 8086,24db card 1462,0120 rev 02 class 01,01,8a hdr 00
(II) PCI: 00:1f:3: chip 8086,24d3 card 1462,0120 rev 02 class 0c,05,00 hdr 00
(II) PCI: 00:1f:5: chip 8086,24d5 card 1462,0120 rev 02 class 04,01,00 hdr 00
(II) PCI: 01:00:0: chip 1002,4e48 card 1787,8500 rev 00 class 03,00,00 hdr 80
(II) PCI: 01:00:1: chip 1002,4e68 card 1787,8501 rev 00 class 03,80,00 hdr 00
(II) PCI: 02:00:0: chip 1260,3890 card 17cf,0014 rev 01 class 02,80,00 hdr 00
(II) PCI: 02:02:0: chip 1131,7134 card 16be,0003 rev 01 class 04,80,00 hdr 00
(II) PCI: 02:03:0: chip 1102,0002 card 1102,8065 rev 0a class 04,01,00 hdr 80
(II) PCI: 02:03:1: chip 1102,7002 card 1102,0020 rev 0a class 09,80,00 hdr 80
(II) PCI: 02:04:0: chip 8086,1040 card 16be,1040 rev 00 class 07,80,00 hdr 00
(II) PCI: 02:09:0: chip 1106,3106 card 1462,012c rev 8b class 02,00,00 hdr 00
(II) PCI: 02:0a:0: chip 1106,3044 card 1462,716d rev 46 class 0c,00,10 hdr 00
(II) PCI: End of PCI scan
(II) Host-to-PCI bridge:
(II) Bus 0: bridge is at (0:0:0), (0,0,2), BCTRL: 0x0008 (VGA_EN is set)
(II) Bus 0 I/O range:
[0] -1 0 0x00000000 - 0x0000ffff (0x10000) IX[B]
(II) Bus 0 non-prefetchable memory range:
[0] -1 0 0x00000000 - 0xffffffff (0x0) MX[B]
(II) Bus 0 prefetchable memory range:
(II) PCI-to-PCI bridge:
(II) Bus 1: bridge is at (0:1:0), (0,1,1), BCTRL: 0x000c (VGA_EN is set)
(II) Bus 1 I/O range:
[0] -1 0 0x0000a000 - 0x0000a0ff (0x100) IX[B]
[1] -1 0 0x0000a400 - 0x0000a4ff (0x100) IX[B]
[2] -1 0 0x0000a800 - 0x0000a8ff (0x100) IX[B]
[3] -1 0 0x0000ac00 - 0x0000acff (0x100) IX[B]
(II) Bus 1 non-prefetchable memory range:
[0] -1 0 0xf0000000 - 0xf1ffffff (0x2000000) MX[B]
(II) Bus 1 prefetchable memory range:
[0] -1 0 0xe0000000 - 0xefffffff (0x10000000) MX[B]
(II) Bus 2: bridge is at (0:30:0), (0,2,2), BCTRL: 0x0006 (VGA_EN is cleared)
(II) Bus 2 I/O range:
[0] -1 0 0x0000b000 - 0x0000b0ff (0x100) IX[B]
[1] -1 0 0x0000b400 - 0x0000b4ff (0x100) IX[B]
[2] -1 0 0x0000b800 - 0x0000b8ff (0x100) IX[B]
[3] -1 0 0x0000bc00 - 0x0000bcff (0x100) IX[B]
(II) Bus 2 non-prefetchable memory range:
[0] -1 0 0xf2000000 - 0xf27fffff (0x800000) MX[B]
(II) PCI-to-ISA bridge:
(II) Bus -1: bridge is at (0:31:0), (0,-1,-1), BCTRL: 0x0008 (VGA_EN is set)
(–) PCI:*(1:0:0) ATI Technologies Inc Radeon R350 [Radeon 9800 Pro] rev 0, Mem @ 0xe0000000/27, 0xf1000000/16, I/O @ 0xa000/8
(–) PCI: (1:0:1) ATI Technologies Inc Radeon R350 [Radeon 9800 Pro] (Secondary) rev 0, Mem @ 0xe8000000/27, 0xf1010000/16
(II) Addressable bus resource ranges are
[1] -1 0 0x00000000 - 0x0000ffff (0x10000) IX[B]
(II) OS-reported resource ranges:
[0] -1 0 0xffe00000 - 0xffffffff (0x200000) MXB
[1] -1 0 0x00100000 - 0x3fffffff (0x3ff00000) MX[B]E(B)
[2] -1 0 0x000f0000 - 0x000fffff (0x10000) MX[B]
[3] -1 0 0x000c0000 - 0x000effff (0x30000) MX[B]
[4] -1 0 0x00000000 - 0x0009ffff (0xa0000) MX[B]
[5] -1 0 0x0000ffff - 0x0000ffff (0x1) IX[B]
[6] -1 0 0x00000000 - 0x000000ff (0x100) IX[B]
(II) PCI Memory resource overlap reduced 0xd0000000 from 0xdfffffff to 0xcfffffff
(II) Active PCI resource ranges:
[0] -1 0 0xf2404000 - 0xf24047ff (0x800) MX[B]
[1] -1 0 0xf2403000 - 0xf24030ff (0x100) MX[B]
[2] -1 0 0xf2000000 - 0xf23fffff (0x400000) MX[B]
[3] -1 0 0xf2402000 - 0xf24023ff (0x400) MX[B]
[4] -1 0 0xf2400000 - 0xf2401fff (0x2000) MX[B]
[5] -1 0 0xf2802000 - 0xf28020ff (0x100) MX[B]
[6] -1 0 0xf2801000 - 0xf28011ff (0x200) MX[B]
[7] -1 0 0x70000000 - 0x700003ff (0x400) MX[B]
[8] -1 0 0xf2800000 - 0xf28003ff (0x400) MX[B]
[9] -1 0 0xd0000000 - 0xcfffffff (0x0) MX[B]O
[10] -1 0 0xf1000000 - 0xf100ffff (0x10000) MXB
[11] -1 0 0xe0000000 - 0xe7ffffff (0x8000000) MXB
[12] -1 0 0x0000bc00 - 0x0000bc7f (0x80) IX[B]
[13] -1 0 0x0000b800 - 0x0000b8ff (0x100) IX[B]
[14] -1 0 0x0000b400 - 0x0000b407 (0x8) IX[B]
[15] -1 0 0x0000b000 - 0x0000b01f (0x20) IX[B]
[16] -1 0 0x0000d800 - 0x0000d83f (0x40) IX[B]
[17] -1 0 0x0000d400 - 0x0000d4ff (0x100) IX[B]
[18] -1 0 0x00000500 - 0x0000051f (0x20) IX[B]
[19] -1 0 0x0000f000 - 0x0000f00f (0x10) IX[B]
[20] -1 0 0x0000c800 - 0x0000c81f (0x20) IX[B]
[21] -1 0 0x0000c400 - 0x0000c41f (0x20) IX[B]
[22] -1 0 0x0000c000 - 0x0000c01f (0x20) IX[B]
[23] -1 0 0x0000cc00 - 0x0000cc1f (0x20) IX[B]
[24] -1 0 0x0000a000 - 0x0000a0ff (0x100) IXB
(II) Inactive PCI resource ranges:
[0] -1 0 0xf1010000 - 0xf101ffff (0x10000) MXB
[1] -1 0 0xe8000000 - 0xefffffff (0x8000000) MXB
(II) Active PCI resource ranges after removing overlaps:
(II) Inactive PCI resource ranges after removing overlaps:
(II) OS-reported resource ranges after removing overlaps with PCI:
(II) All system resource ranges:
[5] -1 0 0xf2404000 - 0xf24047ff (0x800) MX[B]
[6] -1 0 0xf2403000 - 0xf24030ff (0x100) MX[B]
[7] -1 0 0xf2000000 - 0xf23fffff (0x400000) MX[B]
[8] -1 0 0xf2402000 - 0xf24023ff (0x400) MX[B]
[9] -1 0 0xf2400000 - 0xf2401fff (0x2000) MX[B]
[10] -1 0 0xf2802000 - 0xf28020ff (0x100) MX[B]
[11] -1 0 0xf2801000 - 0xf28011ff (0x200) MX[B]
[12] -1 0 0x70000000 - 0x700003ff (0x400) MX[B]
[13] -1 0 0xf2800000 - 0xf28003ff (0x400) MX[B]
[14] -1 0 0xd0000000 - 0xcfffffff (0x0) MX[B]O
[15] -1 0 0xf1000000 - 0xf100ffff (0x10000) MXB
[16] -1 0 0xe0000000 - 0xe7ffffff (0x8000000) MXB
[17] -1 0 0xf1010000 - 0xf101ffff (0x10000) MXB
[18] -1 0 0xe8000000 - 0xefffffff (0x8000000) MXB
[19] -1 0 0x0000ffff - 0x0000ffff (0x1) IX[B]
[20] -1 0 0x00000000 - 0x000000ff (0x100) IX[B]
[21] -1 0 0x0000bc00 - 0x0000bc7f (0x80) IX[B]
[22] -1 0 0x0000b800 - 0x0000b8ff (0x100) IX[B]
[23] -1 0 0x0000b400 - 0x0000b407 (0x8) IX[B]
[24] -1 0 0x0000b000 - 0x0000b01f (0x20) IX[B]
[25] -1 0 0x0000d800 - 0x0000d83f (0x40) IX[B]
[26] -1 0 0x0000d400 - 0x0000d4ff (0x100) IX[B]
[27] -1 0 0x00000500 - 0x0000051f (0x20) IX[B]
[28] -1 0 0x0000f000 - 0x0000f00f (0x10) IX[B]
[29] -1 0 0x0000c800 - 0x0000c81f (0x20) IX[B]
[30] -1 0 0x0000c400 - 0x0000c41f (0x20) IX[B]
[31] -1 0 0x0000c000 - 0x0000c01f (0x20) IX[B]
[32] -1 0 0x0000cc00 - 0x0000cc1f (0x20) IX[B]
[33] -1 0 0x0000a000 - 0x0000a0ff (0x100) IXB
(II) Reloading /usr/X11R6/lib/modules/fonts/libbitmap.so
(II) LoadModule: “dbe”
(II) Loading /usr/X11R6/lib/modules/extensions/libdbe.so
(II) Module dbe: vendor="X.Org Foundation"
Module class: X.Org Server Extension
ABI class: X.Org Server Extension, version 0.2
(II) Loading extension DOUBLE-BUFFER
(II) LoadModule: “ddc”
(II) Loading /usr/X11R6/lib/modules/libddc.so
(II) Module ddc: vendor="X.Org Foundation"
(II) LoadModule: “dri”
(II) Loading /usr/X11R6/lib/modules/extensions/libdri.so
(II) Module dri: vendor="X.Org Foundation"
(II) Loading sub module “drm”
(II) LoadModule: “drm”
(II) Loading /usr/X11R6/lib/modules/linux/libdrm.so
(II) Module drm: vendor="X.Org Foundation"
(II) Loading extension XFree86-DRI
(II) LoadModule: “evdev”
(II) Loading /usr/X11R6/lib/modules/input/evdev_drv.so
(II) Module evdev: vendor="X.Org Foundation"
compiled for 0.0.0, module version = 1.0.0
Module class: X.Org XInput Driver
ABI class: X.Org XInput driver, version 0.5
(II) LoadModule: “extmod”
(II) Loading /usr/X11R6/lib/modules/extensions/libextmod.so
(II) Module extmod: vendor="X.Org Foundation"
(II) Loading extension SHAPE
(II) Loading extension MIT-SUNDRY-NONSTANDARD
(II) Loading extension BIG-REQUESTS
(II) Loading extension SYNC
(II) Loading extension MIT-SCREEN-SAVER
(II) Loading extension XC-MISC
(II) Loading extension XFree86-VidModeExtension
(II) Loading extension XFree86-Misc
(II) Loading extension XFree86-DGA
(II) Loading extension DPMS
(II) Loading extension FontCache
(II) Loading extension TOG-CUP
(II) Loading extension Extended-Visual-Information
(II) Loading extension XVideo
(II) Loading extension XVideo-MotionCompensation
(II) Loading extension X-Resource
(II) LoadModule: “freetype”
(II) Loading /usr/X11R6/lib/modules/fonts/libfreetype.so
(II) Module freetype: vendor="X.Org Foundation & the After X-TT Project"
compiled for 6.9.0, module version = 2.1.0
(II) Loading font FreeType
(II) LoadModule: “glx”
(II) Loading /usr/X11R6/lib/modules/extensions/libglx.so
(II) Module glx: vendor="X.Org Foundation"
(II) Loading sub module “GLcore”
(II) LoadModule: “GLcore”
(II) Loading /usr/X11R6/lib/modules/extensions/libGLcore.so
(II) Module GLcore: vendor="X.Org Foundation"
(II) Loading extension GLX
(II) LoadModule: “int10”
(II) Loading /usr/X11R6/lib/modules/linux/libint10.so
(II) Module int10: vendor="X.Org Foundation"
(II) LoadModule: “record”
(II) Loading /usr/X11R6/lib/modules/extensions/librecord.so
(II) Module record: vendor="X.Org Foundation"
compiled for 6.9.0, module version = 1.13.0
(II) Loading extension RECORD
(II) LoadModule: “type1”
(II) Loading /usr/X11R6/lib/modules/fonts/libtype1.so
(II) Module type1: vendor="X.Org Foundation"
compiled for 6.9.0, module version = 1.0.2
(II) Loading font Type1
(II) Loading font CID
(II) LoadModule: “vbe”
(II) Loading /usr/X11R6/lib/modules/libvbe.so
(II) Module vbe: vendor="X.Org Foundation"
compiled for 6.9.0, module version = 1.1.0
(II) LoadModule: “ati”
(II) Loading /usr/X11R6/lib/modules/drivers/ati_drv.so
(II) Module ati: vendor="X.Org Foundation"
compiled for 6.9.0, module version = 6.5.7
Module class: X.Org Video Driver
(II) LoadModule: “keyboard”
(II) Loading /usr/X11R6/lib/modules/input/keyboard_drv.so
(II) Module keyboard: vendor="X.Org Foundation"
(II) LoadModule: “mouse”
(II) Loading /usr/X11R6/lib/modules/input/mouse_drv.so
(II) Module mouse: vendor="X.Org Foundation"
compiled for 6.9.0, module version = 1.0.3
(II) ATI: ATI driver (version 6.5.7) for chipsets: ati, ativga
(II) R128: Driver for ATI Rage 128 chipsets:
ATI Rage 128 Mobility M3 LE (PCI), ATI Rage 128 Mobility M3 LF (AGP),
ATI Rage 128 Mobility M4 MF (AGP), ATI Rage 128 Mobility M4 ML (AGP),
ATI Rage 128 Pro GL PA (AGP?), ATI Rage 128 Pro GL PB (AGP?),
ATI Rage 128 Pro GL PC (AGP?), ATI Rage 128 Pro GL PD (PCI),
ATI Rage 128 Pro GL PE (AGP?), ATI Rage 128 Pro GL PF (AGP),
ATI Rage 128 Pro VR PG (AGP?), ATI Rage 128 Pro VR PH (AGP?),
ATI Rage 128 Pro VR PI (AGP?), ATI Rage 128 Pro VR PJ (AGP?),
ATI Rage 128 Pro VR PK (AGP?), ATI Rage 128 Pro VR PL (AGP?),
ATI Rage 128 Pro VR PM (AGP?), ATI Rage 128 Pro VR PN (AGP?),
ATI Rage 128 Pro VR PO (AGP?), ATI Rage 128 Pro VR PP (PCI),
ATI Rage 128 Pro VR PQ (AGP?), ATI Rage 128 Pro VR PR (PCI),
ATI Rage 128 Pro VR PS (AGP?), ATI Rage 128 Pro VR PT (AGP?),
ATI Rage 128 Pro VR PU (AGP?), ATI Rage 128 Pro VR PV (AGP?),
ATI Rage 128 Pro VR PW (AGP?), ATI Rage 128 Pro VR PX (AGP?),
ATI Rage 128 GL RE (PCI), ATI Rage 128 GL RF (AGP),
ATI Rage 128 RG (AGP), ATI Rage 128 VR RK (PCI),
ATI Rage 128 VR RL (AGP), ATI Rage 128 4X SE (AGP?),
ATI Rage 128 4X SF (AGP?), ATI Rage 128 4X SG (AGP?),
ATI Rage 128 4X SH (AGP?), ATI Rage 128 4X SK (AGP?),
ATI Rage 128 4X SL (AGP?), ATI Rage 128 4X SM (AGP),
ATI Rage 128 4X SN (AGP?), ATI Rage 128 Pro ULTRA TF (AGP),
ATI Rage 128 Pro ULTRA TL (AGP), ATI Rage 128 Pro ULTRA TR (AGP),
ATI Rage 128 Pro ULTRA TS (AGP?), ATI Rage 128 Pro ULTRA TT (AGP?),
ATI Rage 128 Pro ULTRA TU (AGP?)
(II) RADEON: Driver for ATI Radeon chipsets: ATI Radeon QD (AGP),
ATI Radeon QE (AGP), ATI Radeon QF (AGP), ATI Radeon QG (AGP),
ATI Radeon VE/7000 QY (AGP/PCI), ATI Radeon VE/7000 QZ (AGP/PCI),
ATI ES1000 515E (PCI), ATI ES1000 5969 (PCI),
ATI Radeon Mobility M7 LW (AGP),
ATI Mobility FireGL 7800 M7 LX (AGP),
ATI Radeon Mobility M6 LY (AGP), ATI Radeon Mobility M6 LZ (AGP),
ATI Radeon IGP320 (A3) 4136, ATI Radeon IGP320M (U1) 4336,
ATI Radeon IGP330/340/350 (A4) 4137,
ATI Radeon IGP330M/340M/350M (U2) 4337,
ATI Radeon 7000 IGP (A4+) 4237, ATI Radeon Mobility 7000 IGP 4437,
ATI FireGL 8700/8800 QH (AGP), ATI Radeon 8500 QL (AGP),
ATI Radeon 9100 QM (AGP), ATI Radeon 8500 AIW BB (AGP),
ATI Radeon 8500 AIW BC (AGP), ATI Radeon 7500 QW (AGP/PCI),
ATI Radeon 7500 QX (AGP/PCI), ATI Radeon 9000/PRO If (AGP/PCI),
ATI Radeon 9000 Ig (AGP/PCI), ATI FireGL Mobility 9000 (M9) Ld (AGP),
ATI Radeon Mobility 9000 (M9) Lf (AGP),
ATI Radeon Mobility 9000 (M9) Lg (AGP),
ATI Radeon 9100 IGP (A5) 5834,
ATI Radeon Mobility 9100 IGP (U3) 5835, ATI Radeon 9100 PRO IGP 7834,
ATI Radeon Mobility 9200 IGP 7835, ATI Radeon 9200PRO 5960 (AGP),
ATI Radeon 9200 5961 (AGP), ATI Radeon 9200 5962 (AGP),
ATI Radeon 9200SE 5964 (AGP), ATI FireMV 2200 (PCI),
ATI Radeon Mobility 9200 (M9+) 5C61 (AGP),
ATI Radeon Mobility 9200 (M9+) 5C63 (AGP), ATI Radeon 9500 AD (AGP),
ATI Radeon 9500 AE (AGP), ATI Radeon 9600TX AF (AGP),
ATI FireGL Z1 AG (AGP), ATI Radeon 9700 Pro ND (AGP),
ATI Radeon 9700/9500Pro NE (AGP), ATI Radeon 9700 NF (AGP),
ATI FireGL X1 NG (AGP), ATI Radeon 9600 AP (AGP),
ATI Radeon 9600SE AQ (AGP), ATI Radeon 9600XT AR (AGP),
ATI Radeon 9600 AS (AGP), ATI FireGL T2 AT (AGP),
ATI FireGL RV360 AV (AGP),
ATI Radeon Mobility 9600/9700 (M10/M11) NP (AGP),
ATI Radeon Mobility 9600 (M10) NQ (AGP),
ATI Radeon Mobility 9600 (M11) NR (AGP),
ATI Radeon Mobility 9600 (M10) NS (AGP),
ATI FireGL Mobility T2 (M10) NT (AGP),
ATI FireGL Mobility T2e (M11) NV (AGP), ATI Radeon 9650,
ATI Radeon 9800SE AH (AGP), ATI Radeon 9800 AI (AGP),
ATI Radeon 9800 AJ (AGP), ATI FireGL X2 AK (AGP),
ATI Radeon 9800PRO NH (AGP), ATI Radeon 9800 NI (AGP),
ATI FireGL X2 NK (AGP), ATI Radeon 9800XT NJ (AGP),
ATI Radeon X600 (RV380) 3E50 (PCIE),
ATI FireGL V3200 (RV380) 3E54 (PCIE),
ATI Radeon Mobility X600 (M24) 3150 (PCIE),
ATI FireGL M24 GL 3154 (PCIE), ATI Radeon X300 (RV370) 5B60 (PCIE),
ATI Radeon X600 (RV370) 5B62 (PCIE),
ATI FireGL V3100 (RV370) 5B64 (PCIE),
ATI FireGL D1100 (RV370) 5B65 (PCIE),
ATI Radeon Mobility M300 (M22) 5460 (PCIE),
ATI FireGL M22 GL 5464 (PCIE), ATI Radeon XPRESS 200 5A41 (PCIE),
ATI Radeon XPRESS 200M 5A42 (PCIE),
ATI Radeon XPRESS 200 5A61 (PCIE),
ATI Radeon XPRESS 200M 5A62 (PCIE),
ATI Radeon XPRESS 200 5954 (PCIE),
ATI Radeon XPRESS 200M 5955 (PCIE),
ATI Radeon XPRESS 200 5974 (PCIE),
ATI Radeon XPRESS 200M 5975 (PCIE), ATI FireGL V5000 (RV410) (PCIE),
ATI Mobility FireGL V5000 (M26) (PCIE),
ATI Mobility Radeon X700 (M26) (PCIE),
ATI Radeon X700 PRO (RV410) (PCIE),
ATI Radeon X700 XT (RV410) (PCIE), ATI Radeon X700 (RV410) (PCIE),
ATI Radeon X700 SE (RV410) (PCIE), ATI Radeon X700 SE (RV410) (PCIE),
ATI Radeon X800 (R420) JH (AGP), ATI Radeon X800PRO (R420) JI (AGP),
ATI Radeon X800SE (R420) JJ (AGP), ATI Radeon X800 (R420) JK (AGP),
ATI Radeon X800 (R420) JL (AGP), ATI FireGL X3 (R420) JM (AGP),
ATI Radeon Mobility 9800 (M18) JN (AGP),
ATI Radeon X800XT (R420) JP (AGP), ATI Radeon X800 SE (R420) (AGP),
ATI Radeon X800 (R423) UH (PCIE),
ATI Radeon X800PRO (R423) UI (PCIE),
ATI Radeon X800LE (R423) UJ (PCIE),
ATI Radeon X800SE (R423) UK (PCIE),
ATI FireGL V7200 (R423) UQ (PCIE), ATI FireGL V5100 (R423) UR (PCIE),
ATI FireGL V7100 (R423) UT (PCIE),
ATI Radeon X800XT (R423) 5D57 (PCIE), ATI FireGL V7100 (R423) (PCIE),
ATI Mobility FireGL V5100 (M28) (PCIE),
ATI Mobility Radeon X800 (M28) (PCIE),
ATI Mobility Radeon X800 XT (M28) (PCIE),
ATI Radeon X800 (R430) (PCIE), ATI Radeon X800 XL (R430) (PCIE),
ATI Radeon X800 SE (R430) (PCIE), ATI Radeon X800 XTP (R430) (PCIE),
ATI Radeon X850 5D4C (PCIE), ATI Radeon FireGL (R480) GL 5D50 (PCIE),
ATI Radeon X850 SE (R480) (PCIE), ATI Radeon X850 PRO (R480) (PCIE),
ATI Radeon X850 XT (R480) (PCIE),
ATI Radeon X850 XT PE (R480) (PCIE),
ATI Radeon X850 PRO (R480) (AGP), ATI Radeon X850 SE (R480) (AGP),
ATI Radeon X850 XT (R480) (AGP), ATI Radeon X850 XT PE (R480) (AGP)
(II) Primary Device is: PCI 01:00:0
(II) ATI: Candidate “Device” section “ATI Technologies, Inc. Radeon R350 [Radeon 9800 Pro]”.
(WW) RADEON: No matching Device section for instance (BusID PCI:1:0:1) found
(–) Chipset ATI Radeon 9800PRO NH (AGP) found
(II) resource ranges after xf86ClaimFixedResources() call:
(II) Loading sub module “radeon”
(II) LoadModule: “radeon”
(II) Loading /usr/X11R6/lib/modules/drivers/radeon_drv.so
(II) Module radeon: vendor="X.Org Foundation"
compiled for 6.9.0, module version = 4.0.3
(II) resource ranges after probing:
[19] 0 0 0x000a0000 - 0x000affff (0x10000) MS[B]
[20] 0 0 0x000b0000 - 0x000b7fff (0x8000) MS[B]
[21] 0 0 0x000b8000 - 0x000bffff (0x8000) MS[B]
[22] -1 0 0x0000ffff - 0x0000ffff (0x1) IX[B]
[23] -1 0 0x00000000 - 0x000000ff (0x100) IX[B]
[24] -1 0 0x0000bc00 - 0x0000bc7f (0x80) IX[B]
[25] -1 0 0x0000b800 - 0x0000b8ff (0x100) IX[B]
[26] -1 0 0x0000b400 - 0x0000b407 (0x8) IX[B]
[27] -1 0 0x0000b000 - 0x0000b01f (0x20) IX[B]
[28] -1 0 0x0000d800 - 0x0000d83f (0x40) IX[B]
[29] -1 0 0x0000d400 - 0x0000d4ff (0x100) IX[B]
[30] -1 0 0x00000500 - 0x0000051f (0x20) IX[B]
[31] -1 0 0x0000f000 - 0x0000f00f (0x10) IX[B]
[32] -1 0 0x0000c800 - 0x0000c81f (0x20) IX[B]
[33] -1 0 0x0000c400 - 0x0000c41f (0x20) IX[B]
[34] -1 0 0x0000c000 - 0x0000c01f (0x20) IX[B]
[35] -1 0 0x0000cc00 - 0x0000cc1f (0x20) IX[B]
[36] -1 0 0x0000a000 - 0x0000a0ff (0x100) IXB
[37] 0 0 0xf00003b0 - 0xf00003bb (0xc) IS[B]
[38] 0 0 0xf00003c0 - 0xf00003df (0x20) IS[B]
(II) Setting vga for screen 0.
(II) RADEON(0): MMIO registers at 0xf1000000
(II) RADEON(0): PCI bus 1 card 0 func 0
() RADEON(0): Depth 24, (–) framebuffer bpp 32
(II) RADEON(0): Pixel depth = 24 bits stored in 4 bytes (32 bpp pixmaps)
(==) RADEON(0): Default visual is TrueColor
(II) Loading sub module “vgahw”
(II) LoadModule: “vgahw”
(II) Loading /usr/X11R6/lib/modules/libvgahw.so
(II) Module vgahw: vendor="X.Org Foundation"
compiled for 6.9.0, module version = 0.1.0
(II) RADEON(0): vgaHWGetIOBase: hwp->IOBase is 0x03d0, hwp->PIOOffset is 0x0000
(==) RADEON(0): RGB weight 888
(II) RADEON(0): Using 8 bits per RGB (8 bit DAC)
(II) Loading sub module “int10”
(II) Reloading /usr/X11R6/lib/modules/linux/libint10.so
(II) RADEON(0): initializing int10
(II) RADEON(0): Primary V_BIOS segment is: 0xc000
(–) RADEON(0): Chipset: “ATI Radeon 9800PRO NH (AGP)” (ChipID = 0x4e48)
(–) RADEON(0): Linear framebuffer at 0xe0000000
(II) RADEON(0): Video RAM override, using 131072 kB instead of 131072 kB
() RADEON(0): VideoRAM: 131072 kByte (256 bit DDR SDRAM)
(II) RADEON(0): AGP card detected
(II) RADEON(0): Color tiling disabled
(II) Loading sub module “ddc”
(II) Reloading /usr/X11R6/lib/modules/libddc.so
(II) Loading sub module “i2c”
(II) LoadModule: “i2c”
(II) Loading /usr/X11R6/lib/modules/libi2c.so
(II) Module i2c: vendor="X.Org Foundation"
compiled for 6.9.0, module version = 1.2.0
(II) RADEON(0): I2C bus “DDC” initialized.
(II) RADEON(0): Legacy BIOS detected
(II) RADEON(0): Connector0: DDCType-2, DACType-1, TMDSType–1, ConnectorType-2
(II) RADEON(0): Connector1: DDCType-3, DACType-0, TMDSType–1, ConnectorType-2
(II) RADEON(0): I2C device “DDC:ddc2” registered at address 0xA0.
(II) RADEON(0): I2C device “DDC:ddc2” removed.
(II) RADEON(0): DDC Type: 3, Detected Type: 1
(II) RADEON(0): DDC Type: 2, Detected Type: 0
(II) RADEON(0): EDID data from the display on port 1 ----------------------
(II) RADEON(0): Manufacturer: GSM Model: 4a54 Serial#: 3324
(II) RADEON(0): Year: 2001 Week: 12
(II) RADEON(0): EDID Version: 1.3
(II) RADEON(0): Analog Display Input, Input Voltage Level: 0.700/0.700 V
(II) RADEON(0): Signal levels configurable
(II) RADEON(0): Sync: Separate
(II) RADEON(0): Max H-Image Size [cm]: horiz.: 36 vert.: 27
(II) RADEON(0): Gamma: 2.76
(II) RADEON(0): DPMS capabilities: StandBy Suspend Off; RGB/Color Display
(II) RADEON(0): First detailed timing not preferred mode in violation of standard!(II) RADEON(0): redX: 0.638 redY: 0.326 greenX: 0.279 greenY: 0.602
(II) RADEON(0): blueX: 0.142 blueY: 0.062 whiteX: 0.282 whiteY: 0.298
(II) RADEON(0): Supported VESA Video Modes:
(II) RADEON(0): 720x400@70Hz
(II) RADEON(0): 720x400@88Hz
(II) RADEON(0): 640x480@60Hz
(II) RADEON(0): 640x480@67Hz
(II) RADEON(0): 640x480@72Hz
(II) RADEON(0): 640x480@75Hz
(II) RADEON(0): 800x600@56Hz
(II) RADEON(0): 800x600@60Hz
(II) RADEON(0): 800x600@72Hz
(II) RADEON(0): 800x600@75Hz
(II) RADEON(0): 832x624@75Hz
(II) RADEON(0): 1024x768@87Hz (interlaced)
(II) RADEON(0): 1024x768@60Hz
(II) RADEON(0): 1024x768@70Hz
(II) RADEON(0): 1024x768@75Hz
(II) RADEON(0): 1280x1024@75Hz
(II) RADEON(0): 1152x870@75Hz
(II) RADEON(0): Manufacturer’s mask: 0
(II) RADEON(0): Supported Future Video Modes:
(II) RADEON(0): #0: hsize: 640 vsize 480 refresh: 85 vid: 22833
(II) RADEON(0): #1: hsize: 800 vsize 600 refresh: 85 vid: 22853
(II) RADEON(0): #2: hsize: 1024 vsize 768 refresh: 85 vid: 22881
(II) RADEON(0): #3: hsize: 1280 vsize 1024 refresh: 60 vid: 32897
(II) RADEON(0): #4: hsize: 1600 vsize 1200 refresh: 60 vid: 16553
(II) RADEON(0): #5: hsize: 1600 vsize 1200 refresh: 65 vid: 17833
(II) RADEON(0): #6: hsize: 1600 vsize 1200 refresh: 70 vid: 19113
(II) RADEON(0): #7: hsize: 1600 vsize 1200 refresh: 75 vid: 20393
(II) RADEON(0): Supported additional Video Mode:
(II) RADEON(0): clock: 157.5 MHz Image Size: 350 x 262 mm
(II) RADEON(0): h_active: 1280 h_sync: 1344 h_sync_end 1504 h_blank_end 1728 h_border: 0
(II) RADEON(0): v_active: 1024 v_sync: 1025 v_sync_end 1028 v_blanking: 1072 v_border: 0
(II) RADEON(0): Ranges: V min: 50 V max: 160 Hz, H min: 30 H max: 96 kHz, PixClock max 200 MHz
(II) RADEON(0): Monitor name: 99G
(II) RADEON(0):
(II) RADEON(0): Primary:
Monitor – CRT
Connector – VGA
DAC Type – Primary
TMDS Type – NONE
DDC Type – VGA_DDC
(II) RADEON(0): Secondary:
Monitor – NONE
Connector – VGA
DAC Type – TVDAC/ExtDAC
TMDS Type – NONE
DDC Type – DVI_DDC
(II) RADEON(0): PLL parameters: rf=2700 rd=12 min=20000 max=40000; xclk=33800
(WW) RADEON(0): Failed to detect secondary monitor, MergedFB/Clone mode disabled
(==) RADEON(0): Using gamma correction (1.0, 1.0, 1.0)
(II) RADEON(0): Validating modes on Primary head ---------
(II) RADEON(0): 99G: Using hsync range of 30.00-96.00 kHz
(II) RADEON(0): 99G: Using vrefresh range of 50.00-160.00 Hz
(II) RADEON(0): Clock range: 20.00 to 400.00 MHz
(II) RADEON(0): Not using default mode “320x175” (bad mode clock/interlace/doublescan)
(II) RADEON(0): Not using default mode “320x200” (bad mode clock/interlace/doublescan)
(II) RADEON(0): Not using default mode “360x200” (bad mode clock/interlace/doublescan)
(II) RADEON(0): Not using default mode “320x240” (bad mode clock/interlace/doublescan)
(II) RADEON(0): Not using default mode “400x300” (bad mode clock/interlace/doublescan)
(II) RADEON(0): Not using default mode “512x384” (bad mode clock/interlace/doublescan)
(II) RADEON(0): Not using default mode “576x432” (bad mode clock/interlace/doublescan)
(II) RADEON(0): Not using default mode “640x480” (bad mode clock/interlace/doublescan)
(II) RADEON(0): Not using default mode “640x512” (bad mode clock/interlace/doublescan)
(II) RADEON(0): Not using default mode “800x600” (bad mode clock/interlace/doublescan)
(WW) (1600x1200,99G) mode clock 202.5MHz exceeds DDC maximum 200MHz
(WW) (1600x1200,99G) mode clock 229.5MHz exceeds DDC maximum 200MHz
(II) RADEON(0): Not using default mode “1600x1200” (hsync out of range)
(WW) (1792x1344,99G) mode clock 204.8MHz exceeds DDC maximum 200MHz
(II) RADEON(0): Not using default mode “896x672” (bad mode clock/interlace/doublescan)
(WW) (1792x1344,99G) mode clock 261MHz exceeds DDC maximum 200MHz
(II) RADEON(0): Not using default mode “1792x1344” (hsync out of range)
(WW) (1856x1392,99G) mode clock 218.3MHz exceeds DDC maximum 200MHz
(II) RADEON(0): Not using default mode “928x696” (bad mode clock/interlace/doublescan)
(WW) (1856x1392,99G) mode clock 288MHz exceeds DDC maximum 200MHz
(II) RADEON(0): Not using default mode “1856x1392” (hsync out of range)
(WW) (1920x1440,99G) mode clock 234MHz exceeds DDC maximum 200MHz
(II) RADEON(0): Not using default mode “960x720” (bad mode clock/interlace/doublescan)
(WW) (1920x1440,99G) mode clock 297MHz exceeds DDC maximum 200MHz
(II) RADEON(0): Not using default mode “1920x1440” (hsync out of range)
(II) RADEON(0): Not using default mode “640x384” (bad mode clock/interlace/doublescan)
(II) RADEON(0): Not using default mode “640x400” (bad mode clock/interlace/doublescan)
(II) RADEON(0): Not using default mode “576x384” (bad mode clock/interlace/doublescan)
(II) RADEON(0): Not using default mode “700x525” (bad mode clock/interlace/doublescan)
(II) RADEON(0): Not using default mode “720x450” (bad mode clock/interlace/doublescan)
(II) RADEON(0): Not using default mode “800x512” (bad mode clock/interlace/doublescan)
(II) RADEON(0): Not using default mode “840x525” (bad mode clock/interlace/doublescan)
(II) RADEON(0): Not using default mode “960x600” (bad mode clock/interlace/doublescan)
(WW) (1920x1200,99G) mode clock 230MHz exceeds DDC maximum 200MHz
(WW) (1920x1440,99G) mode clock 341.35MHz exceeds DDC maximum 200MHz
(WW) (2048x1536,99G) mode clock 266.95MHz exceeds DDC maximum 200MHz
(II) RADEON(0): Not using default mode “1024x768” (bad mode clock/interlace/doublescan)
(WW) (2048x1536,99G) mode clock 340.48MHz exceeds DDC maximum 200MHz
(II) RADEON(0): Not using default mode “2048x1536” (hsync out of range)
(WW) (2048x1536,99G) mode clock 388.04MHz exceeds DDC maximum 200MHz
(II) RADEON(0): Not using default mode “2048x1536” (width too large for virtual size)
(II) RADEON(0): Not using default mode “1920x1440” (width too large for virtual size)
(II) RADEON(0): Not using default mode “1856x1392” (width too large for virtual size)
(II) RADEON(0): Not using default mode “1792x1344” (width too large for virtual size)
(II) RADEON(0): Not using default mode “1920x1200” (width too large for virtual size)
(II) RADEON(0): Not using default mode “1680x1050” (width too large for virtual size)
(–) RADEON(0): Virtual size is 1600x1200 (pitch 1600)
() RADEON(0): *Default mode “1600x1200”: 202.5 MHz, 93.8 kHz, 75.0 Hz
(II) RADEON(0): Modeline “1600x1200” 202.50 1600 1664 1856 2160 1200 1201 1204 1250 +hsync +vsync
() RADEON(0): *Default mode “1400x1050”: 184.0 MHz, 93.9 kHz, 85.3 Hz
(II) RADEON(0): Modeline “1400x1050” 184.00 1400 1464 1656 1960 1050 1051 1054 1100 +hsync +vsync
() RADEON(0): *Default mode “1280x1024”: 157.5 MHz, 91.1 kHz, 85.0 Hz
(II) RADEON(0): Modeline “1280x1024” 157.50 1280 1344 1504 1728 1024 1025 1028 1072 +hsync +vsync
() RADEON(0): *Default mode “1152x864”: 121.5 MHz, 77.5 kHz, 85.1 Hz
(II) RADEON(0): Modeline “1152x864” 121.50 1152 1216 1344 1568 864 865 868 911 +hsync -vsync
() RADEON(0): *Default mode “1024x768”: 94.5 MHz, 68.7 kHz, 85.0 Hz
(II) RADEON(0): Modeline “1024x768” 94.50 1024 1072 1168 1376 768 769 772 808 +hsync +vsync
() RADEON(0): *Default mode “800x600”: 56.3 MHz, 53.7 kHz, 85.1 Hz
(II) RADEON(0): Modeline “800x600” 56.30 800 832 896 1048 600 601 604 631 +hsync +vsync
() RADEON(0): *Default mode “640x480”: 36.0 MHz, 43.3 kHz, 85.0 Hz
(II) RADEON(0): Modeline “640x480” 36.00 640 696 752 832 480 481 484 509 -hsync -vsync
() RADEON(0): Default mode “1600x1200”: 189.0 MHz, 87.5 kHz, 70.0 Hz
(II) RADEON(0): Modeline “1600x1200” 189.00 1600 1664 1856 2160 1200 1201 1204 1250 +hsync +vsync
() RADEON(0): Default mode “1600x1200”: 175.5 MHz, 81.2 kHz, 65.0 Hz
(II) RADEON(0): Modeline “1600x1200” 175.50 1600 1664 1856 2160 1200 1201 1204 1250 +hsync +vsync
() RADEON(0): Default mode “1600x1200”: 162.0 MHz, 75.0 kHz, 60.0 Hz
(II) RADEON(0): Modeline “1600x1200” 162.00 1600 1664 1856 2160 1200 1201 1204 1250 +hsync +vsync
() RADEON(0): Default mode “1400x1050”: 155.8 MHz, 81.5 kHz, 74.8 Hz
(II) RADEON(0): Modeline “1400x1050” 155.80 1400 1464 1784 1912 1050 1052 1064 1090 +hsync +vsync
() RADEON(0): Default mode “1400x1050”: 151.0 MHz, 77.0 kHz, 70.0 Hz
(II) RADEON(0): Modeline “1400x1050” 151.00 1400 1464 1656 1960 1050 1051 1054 1100 +hsync +vsync
() RADEON(0): Default mode “1400x1050”: 122.0 MHz, 64.9 kHz, 60.0 Hz
(II) RADEON(0): Modeline “1400x1050” 122.00 1400 1488 1640 1880 1050 1052 1064 1082 +hsync +vsync
() RADEON(0): Default mode “1280x1024”: 135.0 MHz, 80.0 kHz, 75.0 Hz
(II) RADEON(0): Modeline “1280x1024” 135.00 1280 1296 1440 1688 1024 1025 1028 1066 +hsync +vsync
() RADEON(0): Default mode “1280x1024”: 108.0 MHz, 64.0 kHz, 60.0 Hz
(II) RADEON(0): Modeline “1280x1024” 108.00 1280 1328 1440 1688 1024 1025 1028 1066 +hsync +vsync
() RADEON(0): Default mode “1440x900”: 108.8 MHz, 56.9 kHz, 60.2 Hz
(II) RADEON(0): Modeline “1440x900” 108.84 1440 1472 1880 1912 900 918 927 946 +hsync +vsync
() RADEON(0): Default mode “1280x960”: 148.5 MHz, 85.9 kHz, 85.0 Hz
(II) RADEON(0): Modeline “1280x960” 148.50 1280 1344 1504 1728 960 961 964 1011 +hsync +vsync
() RADEON(0): Default mode “1280x960”: 108.0 MHz, 60.0 kHz, 60.0 Hz
(II) RADEON(0): Modeline “1280x960” 108.00 1280 1376 1488 1800 960 961 964 1000 +hsync +vsync
() RADEON(0): Default mode “1280x800”: 83.5 MHz, 49.7 kHz, 60.0 Hz
(II) RADEON(0): Modeline “1280x800” 83.46 1280 1344 1480 1680 800 801 804 828
() RADEON(0): Default mode “1152x864”: 108.0 MHz, 67.5 kHz, 75.0 Hz
(II) RADEON(0): Modeline “1152x864” 108.00 1152 1216 1344 1600 864 865 868 900 +hsync +vsync
() RADEON(0): Default mode “1280x768”: 80.1 MHz, 47.7 kHz, 60.0 Hz
(II) RADEON(0): Modeline “1280x768” 80.14 1280 1344 1480 1680 768 769 772 795
() RADEON(0): Default mode “1152x768”: 65.0 MHz, 44.2 kHz, 54.8 Hz
(II) RADEON(0): Modeline “1152x768” 65.00 1152 1178 1314 1472 768 771 777 806 +hsync +vsync
() RADEON(0): Default mode “1024x768”: 78.8 MHz, 60.1 kHz, 75.1 Hz
(II) RADEON(0): Modeline “1024x768” 78.80 1024 1040 1136 1312 768 769 772 800 +hsync +vsync
() RADEON(0): Default mode “1024x768”: 75.0 MHz, 56.5 kHz, 70.1 Hz
(II) RADEON(0): Modeline “1024x768” 75.00 1024 1048 1184 1328 768 771 777 806 -hsync -vsync
() RADEON(0): Default mode “1024x768”: 65.0 MHz, 48.4 kHz, 60.0 Hz
(II) RADEON(0): Modeline “1024x768” 65.00 1024 1048 1184 1344 768 771 777 806 -hsync -vsync
() RADEON(0): Default mode “1024x768”: 44.9 MHz, 35.5 kHz, 86.9 Hz (I)
(II) RADEON(0): Modeline “1024x768” 44.90 1024 1032 1208 1264 768 768 776 817 interlace +hsync +vsync
() RADEON(0): Default mode “832x624”: 57.3 MHz, 49.7 kHz, 74.6 Hz
(II) RADEON(0): Modeline “832x624” 57.28 832 864 928 1152 624 625 628 667 -hsync -vsync
() RADEON(0): Default mode “800x600”: 49.5 MHz, 46.9 kHz, 75.0 Hz
(II) RADEON(0): Modeline “800x600” 49.50 800 816 896 1056 600 601 604 625 +hsync +vsync
() RADEON(0): Default mode “800x600”: 50.0 MHz, 48.1 kHz, 72.2 Hz
(II) RADEON(0): Modeline “800x600” 50.00 800 856 976 1040 600 637 643 666 +hsync +vsync
() RADEON(0): Default mode “800x600”: 40.0 MHz, 37.9 kHz, 60.3 Hz
(II) RADEON(0): Modeline “800x600” 40.00 800 840 968 1056 600 601 605 628 +hsync +vsync
() RADEON(0): Default mode “800x600”: 36.0 MHz, 35.2 kHz, 56.2 Hz
(II) RADEON(0): Modeline “800x600” 36.00 800 824 896 1024 600 601 603 625 +hsync +vsync
() RADEON(0): Default mode “640x480”: 31.5 MHz, 37.5 kHz, 75.0 Hz
(II) RADEON(0): Modeline “640x480” 31.50 640 656 720 840 480 481 484 500 -hsync -vsync
() RADEON(0): Default mode “640x480”: 31.5 MHz, 37.9 kHz, 72.8 Hz
(II) RADEON(0): Modeline “640x480” 31.50 640 664 704 832 480 489 491 520 -hsync -vsync
() RADEON(0): Default mode “640x480”: 25.2 MHz, 31.5 kHz, 60.0 Hz
(II) RADEON(0): Modeline “640x480” 25.20 640 656 752 800 480 490 492 525 -hsync -vsync
() RADEON(0): Default mode “720x400”: 35.5 MHz, 37.9 kHz, 85.0 Hz
(II) RADEON(0): Modeline “720x400” 35.50 720 756 828 936 400 401 404 446 -hsync +vsync
() RADEON(0): Default mode “640x400”: 31.5 MHz, 37.9 kHz, 85.1 Hz
(II) RADEON(0): Modeline “640x400” 31.50 640 672 736 832 400 401 404 445 -hsync +vsync
() RADEON(0): Default mode “640x350”: 31.5 MHz, 37.9 kHz, 85.1 Hz
(II) RADEON(0): Modeline “640x350” 31.50 640 672 736 832 350 382 385 445 +hsync -vsync
() RADEON(0): Default mode “512x384”: 22.4 MHz, 35.5 kHz, 86.6 Hz (D)
(II) RADEON(0): Modeline “512x384” 22.45 512 516 604 632 384 384 388 409 interlace doublescan +hsync +vsync
() RADEON(0): Default mode “416x312”: 28.6 MHz, 49.7 kHz, 74.7 Hz (D)
(II) RADEON(0): Modeline “416x312” 28.64 416 432 464 576 312 312 314 333 doublescan -hsync -vsync
() RADEON(0): Default mode “400x300”: 28.1 MHz, 53.7 kHz, 85.3 Hz (D)
(II) RADEON(0): Modeline “400x300” 28.15 400 416 448 524 300 300 302 315 doublescan +hsync +vsync
() RADEON(0): Default mode “400x300”: 24.8 MHz, 46.9 kHz, 75.1 Hz (D)
(II) RADEON(0): Modeline “400x300” 24.75 400 408 448 528 300 300 302 312 doublescan +hsync +vsync
() RADEON(0): Default mode “400x300”: 25.0 MHz, 48.1 kHz, 72.2 Hz (D)
(II) RADEON(0): Modeline “400x300” 25.00 400 428 488 520 300 318 321 333 doublescan +hsync +vsync
(**) RADEON(0): Default mode “400x300”: 20.0 MHz, 37.9 kHz, 60.3 Hz (D)
(II) RADEON(0): Modeline “400x300” 20.00 400 420 484 528 300 300 302 314 doublescan +hsync +vsync
(++) RADEON(0): DPI set to (96, 96)
(II) Loading sub module “fb”
(II) LoadModule: “fb”
(II) Loading /usr/X11R6/lib/modules/libfb.so
(II) Module fb: vendor="X.Org Foundation"
ABI class: X.Org ANSI C Emulation, version 0.2
(II) Loading sub module “ramdac”
(II) LoadModule: “ramdac”
(II) Loading /usr/X11R6/lib/modules/libramdac.so
(II) Module ramdac: vendor="X.Org Foundation"
(==) RADEON(0): Using XAA acceleration architecture
(II) Loading sub module “xaa”
(II) LoadModule: “xaa”
(II) Loading /usr/X11R6/lib/modules/libxaa.so
(II) Module xaa: vendor="X.Org Foundation"
(II) RADEON(0): AGP Fast Write disabled by default
(II) Loading sub module “shadowfb”
(II) LoadModule: “shadowfb”
(II) Loading /usr/X11R6/lib/modules/libshadowfb.so
(II) M
