Ci-joint les résultats des 3 commandes
cat /var/log/Xorg.0.log | grep EE
(II) Loading extension MIT-SCREEN-SAVER
herve@debian-rv:~$ cat /etc/X11/xorg.conf
/etc/X11/xorg.conf (xorg X Window System server configuration file)
This file was generated by dexconf, the Debian X Configuration tool, using
values from the debconf database.
Edit this file with caution, and see the /etc/X11/xorg.conf manual page.
(Type “man /etc/X11/xorg.conf” at the shell prompt.)
This file is automatically updated on xserver-xorg package upgrades only
if it has not been modified since the last upgrade of the xserver-xorg
package.
If you have edited this file but would like it to be automatically updated
again, run the following command:
sudo dpkg-reconfigure -phigh xserver-xorg
Section "Files"
FontPath "/usr/share/fonts/X11/misc"
FontPath "/usr/X11R6/lib/X11/fonts/misc"
FontPath "/usr/share/fonts/X11/cyrillic"
FontPath "/usr/X11R6/lib/X11/fonts/cyrillic"
FontPath "/usr/share/fonts/X11/100dpi/:unscaled"
FontPath "/usr/X11R6/lib/X11/fonts/100dpi/:unscaled"
FontPath "/usr/share/fonts/X11/75dpi/:unscaled"
FontPath "/usr/X11R6/lib/X11/fonts/75dpi/:unscaled"
FontPath "/usr/share/fonts/X11/Type1"
FontPath "/usr/X11R6/lib/X11/fonts/Type1"
FontPath "/usr/share/fonts/X11/100dpi"
FontPath "/usr/X11R6/lib/X11/fonts/100dpi"
FontPath "/usr/share/fonts/X11/75dpi"
FontPath “/usr/X11R6/lib/X11/fonts/75dpi”
# path to defoma fonts
FontPath "/var/lib/defoma/x-ttcidfont-conf.d/dirs/TrueType"
EndSection
Section "Module"
Load "bitmap"
Load "dbe"
Load "ddc"
Load "extmod"
Load "freetype"
Load "glx"
Load "int10"
Load "vbe"
EndSection
Section "InputDevice"
Identifier "Generic Keyboard"
Driver "kbd"
Option "CoreKeyboard"
Option “XkbRules” "xorg"
Option “XkbModel” "pc105"
Option “XkbLayout” "fr"
Option “XkbVariant” "latin9"
EndSection
Identifier "Configured Mouse"
Driver "mouse"
Option "CorePointer"
Option “Device” "/dev/input/mice"
Option “Protocol” "ImPS/2"
Option “Emulate3Buttons” "true"
EndSection
Section "Device"
Identifier "nVidia Corporation GeForce 7300 LE"
Driver "nvidia"
BusID "PCI:6:0:0"
VideoRam 256000
EndSection
Section "Monitor"
Identifier "Écran générique"
Option "DPMS"
HorizSync 28-49
VertRefresh 43-72
EndSection
Section "Screen"
Identifier "Default Screen"
Device "nVidia Corporation GeForce 7300 LE"
Monitor "Écran générique"
DefaultDepth 24
SubSection "Display"
Depth 1
Modes “1024x768” “800x600” "640x480"
EndSubSection
Depth 4
EndSubSection
Depth 8
EndSubSection
Depth 15
EndSubSection
Depth 16
EndSubSection
Depth 24
EndSubSection
EndSection
Section "ServerLayout"
Identifier "Default Layout"
Screen "Default Screen"
InputDevice "Generic Keyboard"
InputDevice "Configured Mouse"
EndSection
Section "DRI"
Mode 0666
EndSection
dpkg -l | grep nvidia
ii nvidia-glx 1.0.8776-4 NVIDIA binary XFree86 4.x driver
rc nvidia-glx-dev 1.0.8776-4 NVIDIA binary XFree86 4.x / Xorg driver deve
rc nvidia-glx-legacy 1.0.7184-3 NVIDIA binary Xorg driver (legacy version)
ii nvidia-kernel-2.6.18-6-686 1.0.8776-4+2.6.18.dfsg.1-18etch6 NVIDIA binary kernel module for Linux 2.6.18
ii nvidia-kernel-common 20051028+1 NVIDIA binary kernel module common files
ii nvidia-kernel-source 1.0.8776-4 NVIDIA binary kernel module source
Encore merci et à plus
