hello
j’ai un problème plutôt dans Eterm quand je veux taper un é,à etc sa donne.un truc bizzard que n’arrive pas a reproduire ici
voila quelque info:
<Eterm-0.9.5>
# Eterm Configuration File
# Automatically generated by Eterm-0.9.5 on 2009/02/15 at 18:43:48
begin color
foreground #aaaaaa
background black
cursor #ffff00
cursor_text #880000
pointer white
video normal
color 0 rgb:0/0/0
color 1 rgb:cc/00/00
color 2 rgb:00/cc/00
color 3 rgb:cc/cc/00
color 4 rgb:00/00/cc
color 5 rgb:cc/00/cc
color 6 rgb:00/cc/cc
color 7 rgb:aa/aa/aa
color 8 rgb:33/33/33
color 9 rgb:ff/00/00
color 10 rgb:00/ff/00
color 11 rgb:ff/ff/00
color 12 rgb:00/00/ff
color 13 rgb:ff/00/ff
color 14 rgb:00/ff/ff
color 15 rgb:ff/ff/ff
end color
begin attributes
scrollbar_type motif
scrollbar_width 10
font default 4
font proportional 0
font 0 5x7
font 1 6x10
font 2 fixed
font 3 8x13
font 4 9x15
font effects bottom_right 0x00000000
end attributes
begin actions
bind ctrl shift button3 to string '^[]6;14^G'
bind ctrl button3 to menu "Eterm"
bind ctrl button2 to string '^[[?30t'
bind ctrl button1 to string '^[]5;^G'
end actions
begin multichar
encoding iso-10646
font 0 -misc-fixed-medium-r-normal--7-*-*-*-c-*-iso10646-1
font 1 -misc-fixed-medium-r-normal--10-*-*-*-c-*-iso10646-1
font 2 -misc-fixed-medium-r-semicondensed--13-*-*-*-c-*-iso10646-1
font 3 -misc-fixed-medium-r-normal--14-*-*-*-c-*-iso10646-1
font 4 -misc-fixed-medium-r-normal--15-*-*-*-c-*-iso10646-1
end multichar
begin xim
end xim
begin toggles
map_alert 1
urg_alert 0
visual_bell 0
login_shell 1
scrollbar 1
utmp_logging 1
meta8 0
iconic 0
home_on_output 1
home_on_input 1
no_input 0
scrollbar_floating 0
scrollbar_right 1
scrollbar_popup 0
borderless 0
double_buffer 0
no_cursor 0
pause 0
xterm_select 0
select_line 0
select_trailing_spaces 1
report_as_keysyms 0
itrans 0
buttonbar 1
resize_gravity 0
sticky 0
end toggles
begin keyboard
smallfont_key less
bigfont_key greater
app_keypad 0
app_cursor 0
end keyboard
begin misc
print_pipe 'lp'
save_lines 1024
min_anchor_size 0
border_width 5
term_name Eterm
beep_command ""
debug 0
cut_chars "\\\`\\"'&() *,;<=>?@[]{|}"
end misc
locale
LANG=fr_CH.UTF-8
LC_CTYPE="fr_CH.UTF-8"
LC_NUMERIC="fr_CH.UTF-8"
LC_TIME="fr_CH.UTF-8"
LC_COLLATE="fr_CH.UTF-8"
LC_MONETARY="fr_CH.UTF-8"
LC_MESSAGES="fr_CH.UTF-8"
LC_PAPER="fr_CH.UTF-8"
LC_NAME="fr_CH.UTF-8"
LC_ADDRESS="fr_CH.UTF-8"
LC_TELEPHONE="fr_CH.UTF-8"
LC_MEASUREMENT="fr_CH.UTF-8"
LC_IDENTIFICATION="fr_CH.UTF-8"
LC_ALL=
Merci d’avance
