Evolution et gnome-control-center accessible que via ssh
Bonsoir,
Il s’agit de mon premier post, alors si je viens à commettre des erreurs, ou oublier certaines informations n’hésitez pas à me faire la remarque.
Alors voilà, impossible de lancer evolution ou gnome-control-center autrement qu’en me conectant avec ssh -X sur localhost.
Quelques informations complémentaires :
  • Version de debian : Wheezy
  • Version du noyau : 3.2.0-2-amd64
$ lspci 00:00.0 Host bridge: Intel Corporation Core Processor DRAM Controller (rev 02) 00:01.0 PCI bridge: Intel Corporation Core Processor PCI Express x16 Root Port (rev 02) 00:16.0 Communication controller: Intel Corporation 5 Series/3400 Series Chipset HECI Controller (rev 06) 00:1a.0 USB controller: Intel Corporation 5 Series/3400 Series Chipset USB2 Enhanced Host Controller (rev 05) 00:1b.0 Audio device: Intel Corporation 5 Series/3400 Series Chipset High Definition Audio (rev 05) 00:1c.0 PCI bridge: Intel Corporation 5 Series/3400 Series Chipset PCI Express Root Port 1 (rev 05) 00:1c.1 PCI bridge: Intel Corporation 5 Series/3400 Series Chipset PCI Express Root Port 2 (rev 05) 00:1c.2 PCI bridge: Intel Corporation 5 Series/3400 Series Chipset PCI Express Root Port 3 (rev 05) 00:1c.5 PCI bridge: Intel Corporation 5 Series/3400 Series Chipset PCI Express Root Port 6 (rev 05) 00:1d.0 USB controller: Intel Corporation 5 Series/3400 Series Chipset USB2 Enhanced Host Controller (rev 05) 00:1e.0 PCI bridge: Intel Corporation 82801 Mobile PCI Bridge (rev a5) 00:1f.0 ISA bridge: Intel Corporation Mobile 5 Series Chipset LPC Interface Controller (rev 05) 00:1f.2 SATA controller: Intel Corporation 5 Series/3400 Series Chipset 4 port SATA AHCI Controller (rev 05) 00:1f.3 SMBus: Intel Corporation 5 Series/3400 Series Chipset SMBus Controller (rev 05) 01:00.0 VGA compatible controller: Advanced Micro Devices [AMD] nee ATI Manhattan [Mobility Radeon HD 5400 Series] 01:00.1 Audio device: Advanced Micro Devices [AMD] nee ATI Cedar HDMI Audio [Radeon HD 5400/6300 Series] 02:00.0 Network controller: Atheros Communications Inc. AR9285 Wireless Network Adapter (PCI-Express) (rev 01) 03:00.0 SD Host controller: Ricoh Co Ltd MMC/SD Host Controller 03:00.1 System peripheral: Ricoh Co Ltd Memory Stick Host Controller 03:00.4 SD Host controller: Ricoh Co Ltd MMC/SD Host Controller 04:00.0 Ethernet controller: Marvell Technology Group Ltd. Yukon Optima 88E8059 [PCIe Gigabit Ethernet Controller with AVB] (rev 11) 3f:00.0 Host bridge: Intel Corporation Core Processor QuickPath Architecture Generic Non-core Registers (rev 02) 3f:00.1 Host bridge: Intel Corporation Core Processor QuickPath Architecture System Address Decoder (rev 02) 3f:02.0 Host bridge: Intel Corporation Core Processor QPI Link 0 (rev 02) 3f:02.1 Host bridge: Intel Corporation Core Processor QPI Physical 0 (rev 02) 3f:02.2 Host bridge: Intel Corporation Core Processor Reserved (rev 02) 3f:02.3 Host bridge: Intel Corporation Core Processor Reserved (rev 02)
  • $ lsusb Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub Bus 001 Device 002: ID 8087:0020 Intel Corp. Integrated Rate Matching Hub Bus 002 Device 002: ID 8087:0020 Intel Corp. Integrated Rate Matching Hub Bus 001 Device 003: ID 0c45:6409 Microdia Webcam Bus 001 Device 004: ID 0489:e00f Foxconn / Hon Hai Foxconn T77H114 BCM2070 [Single-Chip Bluetooth 2.1 + EDR Adapter]
  • [code] # dmidecode
    SMBIOS 2.6 present.
    17 structures occupying 728 bytes.
    Table at 0x000EBE70.
Handle 0x0000, DMI type 0, 24 bytes
BIOS Information
Vendor: American Megatrends Inc.
Version: R1140Y8
Release Date: 10/06/2010
Address: 0xF0000
Runtime Size: 64 kB
ROM Size: 4096 kB
Characteristics:
PCI is supported
PNP is supported
BIOS is upgradeable
BIOS shadowing is allowed
ESCD support is available
Boot from CD is supported
Selectable boot is supported
EDD is supported
8042 keyboard services are supported (int 9h)
CGA/mono video services are supported (int 10h)
ACPI is supported
USB legacy is supported
AGP is supported
Smart battery is supported
BIOS boot specification is supported
Function key-initiated network boot is supported
Targeted content distribution is supported
BIOS Revision: 11.40
Firmware Revision: 11.40
Handle 0x0001, DMI type 1, 27 bytes
System Information
Manufacturer: Sony Corporation
Product Name: VPCEA3S1E
Version: C6089UX1
Serial Number: 27531350-5005266
UUID: DA73A820-D74B-11DD-8799-F0BF970FBD86
Wake-up Type: Power Switch
SKU Number: N/A
Family: VAIO
Handle 0x0002, DMI type 2, 10 bytes
Base Board Information
Product Name: VAIO
Version: N/A
Serial Number: N/A
Asset Tag: N/A
Features:
Board is a hosting board
Handle 0x0003, DMI type 3, 17 bytes
Chassis Information
Type: Notebook
Lock: Not Present
Version: N/A
Serial Number: N/A
Asset Tag: N/A
Boot-up State: Safe
Power Supply State: Safe
Thermal State: Safe
Security Status: None
OEM Information: 0x00000000
Handle 0x0004, DMI type 4, 35 bytes
Processor Information
Socket Designation: N/A
Type: Central Processor
Family: Core i3
Manufacturer: GenuineIntel
ID: 55 06 02 00 FF FB EB BF
Signature: Type 0, Family 6, Model 37, Stepping 5
Flags:
FPU (Floating-point unit on-chip)
VME (Virtual mode extension)
DE (Debugging extension)
PSE (Page size extension)
TSC (Time stamp counter)
MSR (Model specific registers)
PAE (Physical address extension)
MCE (Machine check exception)
CX8 (CMPXCHG8 instruction supported)
APIC (On-chip APIC hardware supported)
SEP (Fast system call)
MTRR (Memory type range registers)
PGE (Page global enable)
MCA (Machine check architecture)
CMOV (Conditional move instruction supported)
PAT (Page attribute table)
PSE-36 (36-bit page size extension)
CLFSH (CLFLUSH instruction supported)
DS (Debug store)
ACPI (ACPI supported)
MMX (MMX technology supported)
FXSR (FXSAVE and FXSTOR instructions supported)
SSE (Streaming SIMD extensions)
SSE2 (Streaming SIMD extensions 2)
SS (Self-snoop)
HTT (Multi-threading)
TM (Thermal monitor supported)
PBE (Pending break enabled)
Version: Intel® Core™ i3 CPU M 370 @ 2.40GHz
Voltage: 1.4 V
External Clock: 133 MHz
Max Speed: 2399 MHz
Current Speed: 2399 MHz
Status: Populated, Enabled
Upgrade: None
L1 Cache Handle: 0x0005
L2 Cache Handle: 0x0006
L3 Cache Handle: 0x0007
Serial Number: N/A
Asset Tag: N/A
Part Number: N/A
Handle 0x0005, DMI type 7, 19 bytes
Cache Information
Socket Designation: L1 Cache
Configuration: Enabled, Socketed, Level 1
Operational Mode: Write Through
Installed Size: 128 kB
Maximum Size: 128 kB
Supported SRAM Types:
Unknown
Installed SRAM Type: Unknown
Speed: Unknown
Error Correction Type: Single-bit ECC
System Type: Other
Associativity: 4-way Set-associative
Handle 0x0006, DMI type 7, 19 bytes
Cache Information
Socket Designation: L2 Cache
Configuration: Enabled, Socketed, Level 2
Installed Size: 512 kB
Maximum Size: 512 kB
Unknown
Speed: Unknown
System Type: Unified
Associativity: 8-way Set-associative
Handle 0x0007, DMI type 7, 19 bytes
Cache Information
Socket Designation: L3 Cache
Configuration: Enabled, Socketed, Level 3
Operational Mode: Write Back
Installed Size: 3072 kB
Maximum Size: 3072 kB
Unknown
Speed: Unknown
Associativity: 12-way Set-associative
Handle 0x0008, DMI type 11, 5 bytes
OEM Strings
String 1: 0000070948F
String 2: FNC-EXTB
String 3: 9LZ536NXWyFlPU6XYsfbpsg902WUzbuOF3xsNXeOFlPUNXW@zl
String 4: Reserved
String 5: 6.0.31.1208
Handle 0x000F, DMI type 32, 20 bytes
System Boot Information
Status: No errors detected
Handle 0x0009, DMI type 16, 15 bytes
Physical Memory Array
Use: System Memory
Error Correction Type: None
Maximum Capacity: Unknown
Error Information Handle: Not Provided
Number Of Devices: 2
Handle 0x000A, DMI type 17, 21 bytes
Memory Device
Array Handle: 0x0009
Total Width: 64 bits
Data Width: 64 bits
Form Factor: SODIMM
Set: None
Locator: SODIMM1
Bank Locator: Bank 0
Type: DDR3
Type Detail: Unknown
Handle 0x000B, DMI type 20, 19 bytes
Memory Device Mapped Address
Starting Address: 0x00000000000
Ending Address: 0x0007FFFFFFF
Range Size: 2 GB
Physical Device Handle: 0x000A
Memory Array Mapped Address Handle: 0x000E
Partition Row Position: Unknown
Interleave Position: Unknown
Interleaved Data Depth: Unknown
Handle 0x000C, DMI type 17, 21 bytes
Memory Device
Data Width: 64 bits
Form Factor: SODIMM
Set: None
Locator: SODIMM2
Bank Locator: Bank 1
Type: DDR3
Handle 0x000D, DMI type 20, 19 bytes
Starting Address: 0x00080000000
Ending Address: 0x000FFFFFFFF
Range Size: 2 GB
Physical Device Handle: 0x000C
Handle 0x000E, DMI type 19, 15 bytes
Range Size: 4 GB
Physical Array Handle: 0x0009
Partition Width: 2
Handle 0x0010, DMI type 127, 4 bytes
End Of Table
Dans un premier temps j’ai essayé d’exécuter evolution avec gdb, afin d’avoir des informations sur le crash. Voici le retour de la commande :
[code]gdb evolution
#0 0x00007fffef4707d5 in ?? () from /lib/x86_64-linux-gnu/libc.so.6
#1 0x00007fffe6d6fafb in ?? () from /usr/lib/x86_64-linux-gnu/libGL.so.1
#2 0x00007ffff1a95cb7 in ?? () from /usr/lib/x86_64-linux-gnu/libcogl.so.9
#3 0x00007ffff1a9414c in ?? () from /usr/lib/x86_64-linux-gnu/libcogl.so.9
#4 0x00007ffff1a6f818 in cogl_context_new () from /usr/lib/x86_64-linux-gnu/libcogl.so.9
#5 0x00007ffff2821333 in ?? () from /usr/lib/x86_64-linux-gnu/libclutter-1.0.so.0
#6 0x00007ffff28382b3 in ?? () from /usr/lib/x86_64-linux-gnu/libclutter-1.0.so.0
#7 0x00007ffff2843c8a in ?? () from /usr/lib/x86_64-linux-gnu/libclutter-1.0.so.0
#8 0x00007ffff317fb3d in post_parse_hook (context=, group=, data=, error=0x7fffffffe0f0) at ./gtk-clutter-util.c:107
#9 0x00007fffef92d458 in g_option_context_parse (context=, argc=, argv=, error=) at /tmp/buildd/glib2.0-2.32.3/./glib/goption.c:1995
#10 0x00007ffff317fd56 in gtk_clutter_init_with_args (argc=argc@entry=0x7fffffffe0dc, argv=argv@entry=0x7fffffffe0d0, parameter_string=, entries=entries@entry=0x604220,
translation_domain=, translation_domain@entry=0x402ade evolution-3.2, error=error@entry=0x7fffffffe0f0) at ./gtk-clutter-util.c:271
#11 0x0000000000402214 in main (argc=1, argv=0x7fffffffe218) at main.c:510
Alors naturellement j’ai purgé libcogl, et je l’ai réinstallé, sans succès.
Donc j’ai essayé de le lancer avec strace, des fois que les retours me donnent quelques informations, mais je vous avoue que pour moi, il s’agit là de choses incompréhensibles, peut être que ces dernières le seront moins pour vous :
$ strace evolution
En raison de la limite du nombre de caractères j’ai mis le retour de la commande en pièce jointe.
Voilà.
Je reste à votre disposition pour toute information supplémentaire et merci d’avance pour votre aide.
Après quelques tests, je me suis rendu compte que je pouvais aussi les lancer en tant que root. Je ne sais pas si ça fait avancer le schmilblick…
un probléme de droit d’accés à un répertoire peut étre.
As tu essayé de purger et réinstaller ?
C’est aussi ce que je me suis dit au début, donc j’ai purgé et réinstallé, mais rien n’y fait.
Ce qui est bizare, c’est qu’en lançant evolution depuis la session squeeze, impossible de le lancer, mais je peux le lancer depuis une session ssh.
ne fontionne pas pas mais
squeeze@patator $ ssh squeeze@localhost squeeze@patator $ evolution
fonctionne, même si les droits sont les mêmes…
As-tu par hasard testé en créant un nouvel utilisateur ?
Non mais ça peut se faire, j’essaye ça dans la semaine. Je vous tiens au courant.
Au passage, merci de prendre le temps de m’aider.
