Execution en mode de rendu logiciel debian 8.1 x64 cinnamon
Je suis un petit nouveau dans le monde de gnu/linux et j’ai quelque soucis sur l’installation de debian 8.1 x64 avec cinnamon pour GUI sur une machine (pc portable acer aspire 8530g).
Je vous poste le “lspci” (je suppose que cela vous sera utile) et je vous résume mes divers tentatives.
[ul]
00:00.0 Host bridge: Advanced Micro Devices, Inc. [AMD] RS780 Host Bridge
00:01.0 PCI bridge: Acer Incorporated [ALI] AMD RS780/RS880 PCI to PCI bridge (int gfx)
00:02.0 PCI bridge: Advanced Micro Devices, Inc. [AMD] RS780 PCI to PCI bridge (ext gfx port 0)
00:04.0 PCI bridge: Advanced Micro Devices, Inc. [AMD] RS780/RS880 PCI to PCI bridge (PCIE port 0)
00:05.0 PCI bridge: Advanced Micro Devices, Inc. [AMD] RS780/RS880 PCI to PCI bridge (PCIE port 1)
00:07.0 PCI bridge: Advanced Micro Devices, Inc. [AMD] RS780/RS880 PCI to PCI bridge (PCIE port 3)
00:11.0 SATA controller: Advanced Micro Devices, Inc. [AMD/ATI] SB7x0/SB8x0/SB9x0 SATA Controller [AHCI mode]
00:12.0 USB controller: Advanced Micro Devices, Inc. [AMD/ATI] SB7x0/SB8x0/SB9x0 USB OHCI0 Controller
00:12.1 USB controller: Advanced Micro Devices, Inc. [AMD/ATI] SB7x0 USB OHCI1 Controller
00:12.2 USB controller: Advanced Micro Devices, Inc. [AMD/ATI] SB7x0/SB8x0/SB9x0 USB EHCI Controller
00:13.0 USB controller: Advanced Micro Devices, Inc. [AMD/ATI] SB7x0/SB8x0/SB9x0 USB OHCI0 Controller
00:13.1 USB controller: Advanced Micro Devices, Inc. [AMD/ATI] SB7x0 USB OHCI1 Controller
00:13.2 USB controller: Advanced Micro Devices, Inc. [AMD/ATI] SB7x0/SB8x0/SB9x0 USB EHCI Controller
00:14.0 SMBus: Advanced Micro Devices, Inc. [AMD/ATI] SBx00 SMBus Controller (rev 3a)
00:14.2 Audio device: Advanced Micro Devices, Inc. [AMD/ATI] SBx00 Azalia (Intel HDA)
00:14.3 ISA bridge: Advanced Micro Devices, Inc. [AMD/ATI] SB7x0/SB8x0/SB9x0 LPC host controller
00:14.4 PCI bridge: Advanced Micro Devices, Inc. [AMD/ATI] SBx00 PCI to PCI Bridge
00:18.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Family 11h Processor HyperTransport Configuration (rev 40)
00:18.1 Host bridge: Advanced Micro Devices, Inc. [AMD] Family 11h Processor Address Map
00:18.2 Host bridge: Advanced Micro Devices, Inc. [AMD] Family 11h Processor DRAM Controller
00:18.3 Host bridge: Advanced Micro Devices, Inc. [AMD] Family 11h Processor Miscellaneous Control
00:18.4 Host bridge: Advanced Micro Devices, Inc. [AMD] Family 11h Processor Link Control
01:05.0 VGA compatible controller: Advanced Micro Devices, Inc. [AMD/ATI] RS780M [Mobility Radeon HD 3200]
02:00.0 VGA compatible controller: Advanced Micro Devices, Inc. [AMD/ATI] RV620/M82 [Mobility Radeon HD 3450/3470]
02:00.1 Audio device: Advanced Micro Devices, Inc. [AMD/ATI] RV620 HDMI Audio [Radeon HD 3400 Series]
03:00.0 Ethernet controller: Broadcom Corporation NetXtreme BCM5764M Gigabit Ethernet PCIe (rev 10)
06:00.0 Network controller: Qualcomm Atheros AR928X Wireless Network Adapter (PCI-Express) (rev 01)[/ul]
De ce que j’ai compris jessie ne prend pas en charge les carte graphique qui sont trop vétuste, donc j’ai utiliser la procédure pour les drivers open sources (wiki.debian.org/AtiHowTo)mais cela ne fonctionne pas, au redémarrage de la machine, lors du chargement des divers information a l’écran, l’écran se redimensionne puis ensuite c’est le blackout total a l’écran (j’ai essayer le mode de récupération et c’est pareille de même pour ctrl+alt+f*).
Donc après une réinstallation j’ai tenter d’installer les drivers propriétaire (wiki.debian.org/ATIProprietary) pour un même résultat.
Une réinstallation plus tard j’ai tenter ceci elhombrequereventodeinformacion … an-jessie/
mais sans succès.
J’ai eu quelque soucis avec un autre pc portable (toujours avec debian 8.1 x64 et cinnamon) mais j’avais bien réussi a installer le drivers graphique (hd 4500) et wifi (iwlwifi ) avec les deux procédures
wiki.debian.org/iwlwifi
Je suis tomber sur certain site web en polonais ou autre langue de l’EST mais google trad n’est pas formidable pour ces dite langue donc la je suis a sec.
En attendant je vous souhaite une bonne nuit et bonne journée.
[edit]
personne n’a une idée ? ou quelque chose a proposer ?
ai-je mal poser la question ?
si oui la voila, comment puis-je installer le drivers de la carte graphique ? car cela dépasse les maigres connaissance que j’ai actuellement.
Si quelqu’un a besoin de plus d’information n’hésiter pas a demander.
[/edit]
[edit2]
jai rajouter le log xorg, syslog et bootload si cela peut aider
[/edit2]
syslog.log (753 KB)
bootload.log (103 KB)
Xorg.0.log (107 KB)
Je n’ai malheureusement pas la solution mais je viens de poster la réponse à un problème similaire
Ton Xorg.0.log contient les mêmes erreurs que moi ( avant la résolution du problème ) , à savoir :
open /dev/dri/card0: No such file or directory : résolu en supprimant l’option nomodeset du boot
AIGLX: reverting to software rendering : accélération matérielle simulée -> charge CPU importante de gnome-shell
Pour les détails regarde mon post, mais chaque problème est un cas particulier, ma carte graphique est une intel donc pilote libre ( ou propriétaire qui en l’occurence ne fonctionne pas avec cette version du noyau ).
