Je souhaite simplement que mon serveur à la maison m’envoie des notifications d’erreurs (je précise que je n’ai pas de nom de domaine et que j’ai une IP variable). Je souhaitais pour cela utiliser Gmail.
J’ai suivi attentivement le wiki ici: wiki.debian.org/GmailAndExim4
Mais pourtant tous mes emails sont refusés avec l’erreur “Unrouteable address”
En mode test cela donne:
$ exim -d -bt mon.username@gmail.com
Exim version 4.80 uid=0 gid=0 pid=13624 D=fbb95cfd
Berkeley DB: Berkeley DB 5.1.29: (October 25, 2011)
Support for: crypteq iconv() IPv6 GnuTLS move_frozen_messages DKIM
Lookups (built-in): lsearch wildlsearch nwildlsearch iplsearch cdb dbm dbmjz dbmnz dnsdb dsearch nis nis0 passwd
Authenticators: cram_md5 plaintext
Routers: accept dnslookup ipliteral manualroute queryprogram redirect
Transports: appendfile/maildir/mailstore autoreply lmtp pipe smtp
Fixed never_users: 0
Size of off_t: 8
Compiler: GCC [4.7.2]
Library version: GnuTLS: Compile: 2.12.20
Runtime: 2.12.20
Library version: PCRE: Compile: 8.31
Runtime: 8.30 2012-02-04
Total 13 lookups
WHITELIST_D_MACROS: "OUTGOING"
TRUSTED_CONFIG_LIST: "/etc/exim4/trusted_configs"
changed uid/gid: forcing real = effective
auxiliary group list: <none>
changed uid/gid: calling tls_validate_require_cipher
uid=104 gid=110 pid=13625
tls_validate_require_cipher child 13625 ended: status=0x0
configuration file is /etc/exim4/exim4.conf
log selectors = 00000000 00000000
trusted user
admin user
originator: uid=0 gid=0 login=root name=root
sender address = root@mamachine
Address testing: uid=0 gid=110 euid=0 egid=110
Testing mon.username@gmail.com
Considering mon.username@gmail.com
routing mon.username@gmail.com
no more routers
mon.username@gmail.com is undeliverable: Unrouteable address
search_tidyup called
>>>>>>>>>>>>>>>> Exim pid=13624 terminating with rc=2 >>>>>>>>>>>>>>>>
Voici mon /etc/exim4/update-exim4.conf.conf
dc_eximconfig_configtype='smarthost'
dc_other_hostnames=''
dc_local_interfaces='127.0.0.1 ; ::1'
dc_readhost='localhost'
dc_relay_domains=''
dc_minimaldns='false'
dc_relay_nets=''
dc_smarthost='smtp.gmail.com::587'
CFILEMODE='644'
dc_use_split_config='false'
dc_hide_mailname='false'
dc_mailname_in_oh='true'
dc_localdelivery='mail_spool'
Mon /etc/exim4/passwd.client:
*.google.com:mon.username@gmail.com:monpassword
Ainsi que mon /etc/email-addresses:
user: mon.username@gmail.com
user@localhost: mon.username@gmail.com
user@mamachine: mon.username@gmail.com
root: mon.username@gmail.com
root@localhost: mon.username@gmail.com
root@mamachine: mon.username@gmail.com
J’avoue que j’en perds mon latin. Est-ce que quelqu’un pourrait me donner un coup de main ?
Merci d’avance !
