[quote]console@MAT64LIN:/usr/src$ aptitude show nut
Paquet : nut
État: non installé
Version : 2.2.1-2
Priorité : optionnel
Section : admin
Responsable : Arnaud Quette aquette@debian.org
Taille décompressée : 3371k
Dépend: adduser, debconf (>= 0.5.00), libc6 (>= 2.7-1), libusb-0.1-4 (>= 2:0.1.12), lsb-base (>= 3.0-6), udev
Suggère: nut-cgi, nut-dev, nut-snmp
Est en conflit: nut-doc, nut-hal-drivers, nut-usb (< 2.1.0-3), ups-monitor
Remplace: nut-doc
Fournit: nut-doc, nut-usb, ups-monitor
Description : The core system of the nut - Network UPS Tools
nut is a client/server uninterruptible power supply (UPS) monitoring system that permits the sharing of one (or more) UPS
between several machines. The ‘server’ monitors the UPS and notifies the ‘clients’ when the UPS is on or has a low battery.
This package contains the core system, and the serial and USB UPS drivers. In most cases it is sufficient for a basic UPS
monitoring system.
Site :http://www.networkupstools.org
Tags: admin::monitoring, hardware::power, hardware::power:ups, interface::daemon, network::server, role::program,
scope::utility[/quote]
Bien sur, il y a plusieurs clients windows:
sourceforge.net/projects/winnutclient/
csociety.ecn.purdue.edu/~delpha/winnut/
Et des tools de monitoring dans tous les sens.
Et outre que le site networkupstools.org/ soit super documenté, tu trouveras des tutos en français partout.
