Salut à tous,
J’ai installé fail2ban et j’essai de le faire fonctionner. J’ai paramétré les fichiers /etc/fail2ban/fail2ban.conf et /etc/fail2ban/jail.conf.local
J’ai un petit problème avec SSH. J’ai fait plusieurs tentative de login erroné, dans le fichier /var/log/fail2ban.log j’ai bien les infos suivantes :
Si je liste les infos de mon firewall :
[code](root - 0) iptables -L
Chain INPUT (policy DROP)
target prot opt source destination
fail2ban-ssh tcp – anywhere anywhere tcp dpt:ssh
fail2ban-ssh tcp – anywhere anywhere tcp dpt:22
ACCEPT 0 – anywhere anywhere state RELATED,ESTABLISHED
ACCEPT icmp – 88.191.254.0/24 anywhere
ACCEPT tcp – anywhere anywhere tcp dpt:4242
ACCEPT tcp – anywhere anywhere tcp dpt:www
ACCEPT tcp – anywhere anywhere tcp dpt:https
ACCEPT tcp – anywhere anywhere tcp dpts:ftp-data:ftp
ACCEPT tcp – anywhere anywhere tcp dpt:ssmtp
ACCEPT tcp – anywhere anywhere tcp dpt:imaps
ACCEPT tcp – anywhere anywhere tcp dpt:pop3s
ACCEPT tcp – 88.191.254.0/24 anywhere tcp dpt:snmp state NEW,ESTABLISHED
ACCEPT udp – 88.191.254.0/24 anywhere udp dpt:snmp state NEW,ESTABLISHED
Chain FORWARD (policy DROP)
ACCEPT tcp – anywhere anywhere tcp flags:FIN,SYN,RST,ACK/SYN limit: avg 1/sec burst 5
ACCEPT udp – anywhere anywhere limit: avg 1/sec burst 5
Chain OUTPUT (policy DROP)
ACCEPT icmp – anywhere 88.191.254.0/24
ACCEPT tcp – anywhere anywhere tcp dpt:domain
ACCEPT udp – anywhere anywhere udp dpt:domain
ACCEPT udp – anywhere anywhere udp dpt:ntp
ACCEPT tcp – anywhere anywhere tcp dpt:smtp
ACCEPT tcp – anywhere 88.191.254.0/24 tcp spt:snmp state ESTABLISHED
ACCEPT udp – anywhere 88.191.254.0/24 udp spt:snmp state ESTABLISHED
Chain SPOOFED (0 references)
DROP 0 – loopback/8 anywhere
DROP 0 – 169.240.0.0/12 anywhere
DROP 0 – 172.16.0.0/12 anywhere
DROP 0 – 192.168.0.0/16 anywhere
DROP 0 – 10.0.0.0/8 anywhere
Chain fail2ban-ssh (2 references)
DROP 0 – {MYIP} anywhere
RETURN 0 – anywhere anywhere[/code]
A première vue je devrait etre bloqué et bien non, je peut continuer à m’identifier…
J’ai essayer de tester la regexp pour voir mais cella ne fonctionne pas non plus :
[code](root - 0) fail2ban-regex /etc/fail2ban/filter.d/sshd.conf /var/log/auth.log
Sorry, no match
Je ne sais plus quoi faire là.
Merci d’avance pour vos réponses.
