j ai un petit probleme plus de serveur x
Et là, ce matin lorsque j’allume mon server , le X ne veux plus se lancer ! a par quand je lance le startx
failed to module ast module does not exist
# xorg.conf (X.Org X Window System server configuration file)
This file was generated by dexconf, the Debian X Configuration tool, using
values from the debconf database.
Edit this file with caution, and see the xorg.conf manual page.
(Type “man xorg.conf” at the shell prompt.)
This file is automatically updated on xserver-xorg package upgrades only
if it has not been modified since the last upgrade of the xserver-xorg
package.
If you have edited this file but would like it to be automatically updated
again, run the following command:
sudo dpkg-reconfigure -phigh xserver-xorg
Section "InputDevice"
Identifier "Generic Keyboard"
Driver "kbd"
Option “XkbRules” "xorg"
Option “XkbModel” "pc105"
Option “XkbLayout” "fr"
Option “XkbVariant” "latin9"
EndSection
Identifier "Configured Mouse"
Driver "mouse"
EndSection
Section "Device"
Identifier "Configured Video Device"
EndSection
Section "Monitor"
Identifier "Configured Monitor"
EndSection
Section "Screen"
Identifier "Default Screen"
Monitor "Configured Monitor"
SubSection "Display
Modes “1280x1024” "1024x768"
EndSubSection
EndSection[/code]
[code]This is a pre-release version of the X server from The X.Org Foundation.
It is not supported in any way.
Bugs may be filed in the bugzilla at http://bugs.freedesktop.org/.
Select the “xorg” product for bugs you find in this release.
Before reporting bugs in pre-release versions please check the
latest version in the X.Org Foundation git repository.
See http://wiki.x.org/wiki/GitPage for git access instructions.
X.Org X Server 1.6.3.901 (1.6.4 RC 1)
Release Date: 2009-8-25
X Protocol Version 11, Revision 0
Build Operating System: Linux 2.6.30-1-amd64 x86_64 Debian
Current Operating System: Linux server1 2.6.30-1-amd64 #1 SMP Sat Aug 15 18:09:19 UTC 2009 x86_64
Build Date: 14 September 2009 01:42:52PM
xorg-server 2:1.6.3.901-1 (jcristau@debian.org)
Before reporting problems, check http://wiki.x.org
Markers: (–) probed, () from config file, (==) default setting,
(==) Log file: “/var/log/Xorg.1.log”, Time: Thu Oct 1 19:18:57 2009
(==) Using config file: “/etc/X11/xorg.conf”
(==) No Layout section. Using the first Screen section.
() |–>Screen “Default Screen” (0)
() | |–>Monitor “Configured Monitor”
(==) No device specified for screen “Default Screen”.
Using the first device section listed.
() | |–>Device “Configured Video Device”
(==) Automatically adding devices
(==) Automatically enabling devices
(WW) The directory “/usr/share/fonts/X11/cyrillic” does not exist.
Entry deleted from font path.
(==) FontPath set to:
/usr/share/fonts/X11/misc,
/usr/share/fonts/X11/Type1,
/usr/share/fonts/X11/100dpi,
/usr/share/fonts/X11/75dpi,
/var/lib/defoma/x-ttcidfont-conf.d/dirs/TrueType,
built-ins
(==) ModulePath set to “/usr/lib/xorg/modules”
(II) Cannot locate a core pointer device.
(II) Cannot locate a core keyboard device.
(II) The server relies on HAL to provide the list of input devices.
If no devices become available, reconfigure HAL or disable AllowEmptyInput.
(II) Loader magic: 0xdc0
(II) Module ABI versions:
X.Org ANSI C Emulation: 0.4
X.Org Video Driver: 5.0
X.Org XInput driver : 4.0
X.Org Server Extension : 2.0
(II) Loader running on linux
(++) using VT number 8
(–) PCI:*(0:1:0:0) 1a03:2000:1a03:2000 ASPEED Technology, Inc. ASPEED Graphics Family rev 16, Mem @ 0xfb000000/8388608, 0xfbce0000/131072, I/O @ 0x0000cc00/128
(II) Open ACPI successful (/var/run/acpid.socket)
(II) System resource ranges:
[0] -1 0 0xffffffff - 0xffffffff (0x1) MX[B]
[1] -1 0 0x000f0000 - 0x000fffff (0x10000) MX[B]
[2] -1 0 0x000c0000 - 0x000effff (0x30000) MX[B]
[3] -1 0 0x00000000 - 0x0009ffff (0xa0000) MX[B]
[4] -1 0 0x0000ffff - 0x0000ffff (0x1) IX[B]
[5] -1 0 0x00000000 - 0x00000000 (0x1) IX[B]
(II) LoadModule: “extmod”
(II) Loading /usr/lib/xorg/modules/extensions//libextmod.so
(II) Module extmod: vendor="X.Org Foundation"
compiled for 1.6.3.901, module version = 1.0.0
Module class: X.Org Server Extension
ABI class: X.Org Server Extension, version 2.0
(II) Loading extension SELinux
(II) Loading extension MIT-SCREEN-SAVER
(II) Loading extension XFree86-VidModeExtension
(II) Loading extension XFree86-DGA
(II) Loading extension DPMS
(II) Loading extension XVideo
(II) Loading extension XVideo-MotionCompensation
(II) Loading extension X-Resource
(II) LoadModule: “dbe”
(II) Loading /usr/lib/xorg/modules/extensions//libdbe.so
(II) Module dbe: vendor="X.Org Foundation"
(II) Loading extension DOUBLE-BUFFER
(II) LoadModule: “glx”
(II) Loading /usr/lib/xorg/modules/extensions//libglx.so
(II) Module glx: vendor="X.Org Foundation"
(==) AIGLX enabled
(II) Loading extension GLX
(II) LoadModule: “record”
(II) Loading /usr/lib/xorg/modules/extensions//librecord.so
(II) Module record: vendor="X.Org Foundation"
compiled for 1.6.3.901, module version = 1.13.0
(II) Loading extension RECORD
(II) LoadModule: “dri”
(II) Loading /usr/lib/xorg/modules/extensions//libdri.so
(II) Module dri: vendor="X.Org Foundation"
(II) Loading extension XFree86-DRI
(II) LoadModule: “dri2”
(II) Loading /usr/lib/xorg/modules/extensions//libdri2.so
(II) Module dri2: vendor="X.Org Foundation"
compiled for 1.6.3.901, module version = 1.1.0
(II) Loading extension DRI2
(==) Matched ast for the autoconfigured driver
(==) Assigned the driver to the xf86ConfigLayout
(II) LoadModule: “ast”
(WW) Warning, couldn’t open module ast
(II) UnloadModule: “ast”
(EE) Failed to load module “ast” (module does not exist, 0)
(EE) No drivers available.
Fatal server error:
no screens found
Please consult the The X.Org Foundation support
at http://wiki.x.org
for help.
Please also check the log file at “/var/log/Xorg.1.log” for additional information.
merci
