~$ lspci
00:00.0 Host bridge: Intel Corporation Sandy Bridge DRAM Controller (rev 09)
00:01.0 PCI bridge: Intel Corporation Sandy Bridge PCI Express Root Port (rev 09)
00:1a.0 USB Controller: Intel Corporation Cougar Point USB Enhanced Host Controller #2 (rev 05)
00:1b.0 Audio device: Intel Corporation Cougar Point High Definition Audio Controller (rev 05)
00:1c.0 PCI bridge: Intel Corporation Cougar Point PCI Express Root Port 1 (rev b5)
00:1c.1 PCI bridge: Intel Corporation Cougar Point PCI Express Root Port 2 (rev b5)
00:1c.5 PCI bridge: Intel Corporation Cougar Point PCI Express Root Port 6 (rev b5)
00:1c.6 PCI bridge: Intel Corporation Cougar Point PCI Express Root Port 7 (rev b5)
00:1d.0 USB Controller: Intel Corporation Cougar Point USB Enhanced Host Controller #1 (rev 05)
00:1f.0 ISA bridge: Intel Corporation Cougar Point LPC Controller (rev 05)
00:1f.2 SATA controller: Intel Corporation Cougar Point 6 port SATA AHCI Controller (rev 05)
00:1f.3 SMBus: Intel Corporation Cougar Point SMBus Controller (rev 05)
01:00.0 VGA compatible controller: nVidia Corporation Device 0dec (rev a1)
01:00.1 Audio device: nVidia Corporation Device 0bea (rev a1)
03:00.0 Network controller: Realtek Semiconductor Co., Ltd. RTL8188CE 802.11b/g/n WiFi Adapter (rev 01)
04:00.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL8101E/RTL8102E PCI Express Fast Ethernet controller (rev 05)
~$ lsusb
Bus 002 Device 005: ID 04e8:6860 Samsung Electronics Co., Ltd
Bus 002 Device 002: ID 8087:0024 Intel Corp. Integrated Rate Matching Hub
Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 001 Device 003: ID 04f2:b1d6 Chicony Electronics Co., Ltd
Bus 001 Device 002: ID 8087:0024 Intel Corp. Integrated Rate Matching Hub
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Pour dmesg, je ne peux pas te poster le retour de cette commande car le forum limite les réponses a 60226 caractères et que la commande me renvoie une longue tartine qui dépasse ce nombre de caractère.
Pour répondre à ton autre question, le PC est un TOSHIBA Satellite L775-11N.
