Faire fonctionner le micro intégré a ma webcam
J’ai un petit soucis, je possède un ordi portable et comme sur beaucoup d’entre eux, le micro est intégré a ma webcam.
Bien que ma webcam fonctionne, le micro ne capture aucun son.
Dans alsa tout est activé dans la partir capture (F4).
Et voici ce que me donne lspci:
$ lspci -nn 00:00.0 Host bridge [0600]: Intel Corporation Sandy Bridge DRAM Controller [8086:0104] (rev 09) 00:01.0 PCI bridge [0604]: Intel Corporation Sandy Bridge PCI Express Root Port [8086:0101] (rev 09) 00:1a.0 USB Controller [0c03]: Intel Corporation Cougar Point USB Enhanced Host Controller #2 [8086:1c2d] (rev 05) 00:1b.0 Audio device [0403]: Intel Corporation Cougar Point High Definition Audio Controller [8086:1c20] (rev 05) 00:1c.0 PCI bridge [0604]: Intel Corporation Cougar Point PCI Express Root Port 1 [8086:1c10] (rev b5) 00:1c.1 PCI bridge [0604]: Intel Corporation Cougar Point PCI Express Root Port 2 [8086:1c12] (rev b5) 00:1c.5 PCI bridge [0604]: Intel Corporation Cougar Point PCI Express Root Port 6 [8086:1c1a] (rev b5) 00:1c.6 PCI bridge [0604]: Intel Corporation Cougar Point PCI Express Root Port 7 [8086:1c1c] (rev b5) 00:1d.0 USB Controller [0c03]: Intel Corporation Cougar Point USB Enhanced Host Controller #1 [8086:1c26] (rev 05) 00:1f.0 ISA bridge [0601]: Intel Corporation Cougar Point LPC Controller [8086:1c49] (rev 05) 00:1f.2 SATA controller [0106]: Intel Corporation Cougar Point 6 port SATA AHCI Controller [8086:1c03] (rev 05) 00:1f.3 SMBus [0c05]: Intel Corporation Cougar Point SMBus Controller [8086:1c22] (rev 05) 01:00.0 VGA compatible controller [0300]: nVidia Corporation Device [10de:0dec] (rev a1) 01:00.1 Audio device [0403]: nVidia Corporation Device [10de:0bea] (rev a1) 03:00.0 Network controller [0280]: Realtek Semiconductor Co., Ltd. RTL8188CE 802.11b/g/n WiFi Adapter [10ec:8176] (rev 01) 04:00.0 Ethernet controller [0200]: Realtek Semiconductor Co., Ltd. RTL8101E/RTL8102E PCI Express Fast Ethernet controller [10ec:8136] (rev 05
Chez moi j’ai réglé ce problème en installant pulseaudio.
donne aussi le résultat d’un lsmod pour voir quels modules sont chargés
$ lsmod Module Size Used by aes_x86_64 16843 1 aes_generic 33026 1 aes_x86_64 ext2 59231 1 usb_storage 43870 1 nvidia 9090627 40 rfcomm 33700 0 parport_pc 22364 0 ppdev 12763 0 lp 17149 0 parport 31858 3 lp,ppdev,parport_pc bnep 17567 2 bluetooth 119455 10 bnep,rfcomm crc16 12343 1 bluetooth cpufreq_powersave 12454 0 cpufreq_userspace 12576 0 cpufreq_conservative 13147 0 cpufreq_stats 12866 0 uinput 17440 1 nfsd 216029 2 nfs 312283 0 nfs_acl 12511 2 nfs,nfsd auth_rpcgss 37143 2 nfs,nfsd fscache 36739 1 nfs lockd 67306 2 nfs,nfsd sunrpc 173774 6 lockd,auth_rpcgss,nfs_acl,nfs,nfsd loop 22641 0 uvcvideo 57744 0 videodev 70889 1 uvcvideo v4l2_compat_ioctl32 16655 1 videodev media 18148 2 videodev,uvcvideo snd_hda_codec_hdmi 30824 4 joydev 17266 0 arc4 12458 2 sg 25874 0 rtl8192ce 60740 0 rtlwifi 81393 1 rtl8192ce r8169 46972 0 sr_mod 21899 0 rtl8192c_common 52602 1 rtl8192ce coretemp 12898 0 snd_hda_codec_realtek 188858 1 crc32c_intel 12747 0 ghash_clmulni_intel 13173 0 ac 12624 0 cdrom 35401 1 sr_mod cryptd 14517 1 ghash_clmulni_intel mii 12675 1 r8169 mac80211 192806 3 rtl8192c_common,rtlwifi,rtl8192ce battery 13109 0 power_supply 13475 2 ac,battery cfg80211 137243 2 mac80211,rtlwifi toshiba_acpi 17649 0 sparse_keymap 12760 1 toshiba_acpi rfkill 19012 5 toshiba_acpi,cfg80211,bluetooth snd_hda_intel 26345 0 snd_hda_codec 78031 3 snd_hda_intel,snd_hda_codec_realtek,snd_hda_codec_hdmi snd_hwdep 13186 1 snd_hda_codec snd_pcm 68083 3 snd_hda_codec,snd_hda_intel,snd_hda_codec_hdmi ehci_hcd 40215 0 snd_page_alloc 13003 2 snd_pcm,snd_hda_intel snd_timer 22917 1 snd_pcm snd 52889 7 snd_timer,snd_pcm,snd_hwdep,snd_hda_codec,snd_hda_intel,snd_hda_codec_realtek,snd_hda_codec_hdmi acpi_cpufreq 12935 1 iTCO_wdt 17081 0 usbcore 128681 5 usb_storage,ehci_hcd,rtlwifi,uvcvideo mperf 12453 1 acpi_cpufreq iTCO_vendor_support 12704 1 iTCO_wdt soundcore 13065 1 snd psmouse 64497 0 i2c_i801 16870 0 pcspkr 12579 0 usb_common 12354 1 usbcore serio_raw 12931 0 i2c_core 23876 3 nvidia,i2c_i801,videodev evdev 17562 14 processor 28157 1 acpi_cpufreq ext3 161867 2 mbcache 13114 2 ext3,ext2 jbd 56902 1 ext3 sd_mod 36136 5 crc_t10dif 12348 1 sd_mod ahci 24997 2 libahci 22860 1 ahci libata 140630 2 libahci,ahci scsi_mod 162269 5 libata,sd_mod,usb_storage,sr_mod,sg thermal 17383 0 thermal_sys 18040 2 thermal,processor
Concernant l’installation de pulseaudio : c’est un paquet que je ne connait pas. Peut-il installe en parallèle de alsamixer? Ces deux paquets ne font-ils pas la même chose? Ne vont-ils pas rentrer en conflit?
on avance, on sait que ta cam utilise les modules:
[quote]uvcvideo 57744 0
media 18148 2 videodev,uvcvideo[/quote]
La liste des modèles de cam supportée est ici
ideasonboard.org/uvc/
Je te laisse regarder si ta cam est dans la liste, et si le son est supporté.
Donne aussi la version de ton kernel.Tu peux installer pulseaudio et alsa, ils ne font pas la même chose. de toute façon, si é paquets sont incompatibles, le gestionnaire apt te le dira.
J’ai installé pulseaudio mais rien n’a changé, mon problème de micro est toujours la.
Quand au site que tu me donnes, je ne vois pas ou ils parlent de modules? Il est question de marque de webcam et de modèle. Mais moi la mienne est intégré au PC portable je ne sais donc pas de quel marque/modèle il s’agit.
Pour la version du kernel, la voici : 3.2.0-4-amd64
Tu n’es pas obligé de connaitre la marque. Utilise le device ID pour identifier ton matériel.
Je pense qu’un lsusb te le donnera, je ne vois pas de cam dans ton lspci
[quote=“snake57”]J’ai installé pulseaudio mais rien n’a changé, mon problème de micro est toujours la.
Oui mais l’as tu sélectionné comme périphérique d’entrée dans les préférence du son?
La cam fonctionne, c’est juste le micro qui y est intégré qui ne marche pas. Enfin je suppose qu’il y est intégré puisque il sont au même endroit sur le PC portable.
$ lsusb Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub Bus 001 Device 002: ID 8087:0024 Intel Corp. Integrated Rate Matching Hub Bus 002 Device 002: ID 8087:0024 Intel Corp. Integrated Rate Matching Hub Bus 001 Device 003: ID 04f2:b1d6 Chicony Electronics Co., Ltd
Oui je l’ai séléctionné dans alsamixer et j’ai vérifié qu’il ne soit pas en muet. Mais ça ne fonctionne toujours pas.
ton device ID semble étre le 04f2:b1d6
est ce que ton ordi est listé dans: thinkwiki.org/wiki/CX20585
Tu peux aussi essayé de bricoler d’après ce fil: ubuntuforums.org/showthread.php?t=1568213
Il y a a quelques config qui ont fonctionné, mais sans explications.
[quote=“piratebab”]
est ce que ton ordi est listé dans: thinkwiki.org/wiki/CX20585[/quote]
Non mon PC n’est pas dans la liste, j’ai toshiba satellite L775-11N.
[quote=“piratebab”]Tu peux aussi essayé de bricoler d’après ce fil: ubuntuforums.org/showthread.php?t=1568213
Il y a a quelques config qui ont fonctionné, mais sans explications.[/quote]
Je vais voir ça.
