Fancontrol pas detecter ?
hello
en vacance depuis quelque jours et je m’aperçois que mon portable ventile par a-coups
c est a dire en gros:
ventile–2sec --stop ventile–3 sec --stop etc etc.
bref j’ai matter la config et je pense que c’est pas reconnu.
# lsmod |grep fan
fan                     2586  0
thermal_sys             9378  4 fan,video,processor,thermal
# sensors-detect
# sensors-detect revision 5818 (2010-01-18 17:22:07 +0100)
# System: Acer, inc. TravelMate 7730G
# Board: Acer, Inc. Monserrat
This program will help you determine which kernel modules you need
to load to use lm_sensors most effectively. It is generally safe
and recommended to accept the default answers to all questions,
unless you know what you're doing.
Some south bridges, CPUs or memory controllers contain embedded sensors.
Do you want to scan for them? This is totally safe. (YES/no): y
Silicon Integrated Systems SIS5595...                       No
VIA VT82C686 Integrated Sensors...                          No
VIA VT8231 Integrated Sensors...                            No
AMD K8 thermal sensors...                                   No
AMD Family 10h thermal sensors...                           No
AMD Family 11h thermal sensors...                           No
Intel Core family thermal sensor...                         Success!
    (driver `coretemp')
Intel Atom thermal sensor...                                No
Intel AMB FB-DIMM thermal sensor...                         No
VIA C7 thermal sensor...                                    No
VIA Nano thermal sensor...                                  No
Some Super I/O chips contain embedded sensors. We have to write to
standard I/O ports to probe them. This is usually safe.
Do you want to scan for Super I/O sensors? (YES/no): y
Probing for Super-I/O at 0x2e/0x2f
Trying family `National Semiconductor'...                   Yes
Found unknown chip with ID 0xfc11
Probing for Super-I/O at 0x4e/0x4f
Trying family `National Semiconductor'...                   No
Trying family `SMSC'...                                     No
Trying family `VIA/Winbond/Nuvoton/Fintek'...               No
Trying family `ITE'...                                      No
Some systems (mainly servers) implement IPMI, a set of common interfaces
through which system health data may be retrieved, amongst other things.
We first try to get the information from SMBIOS. If we don't find it
there, we have to read from arbitrary I/O ports to probe for such
interfaces. This is normally safe. Do you want to scan for IPMI
interfaces? (YES/no): y
Probing for `IPMI BMC KCS' at 0xca0...                      No
Probing for `IPMI BMC SMIC' at 0xca8...                     No
Some hardware monitoring chips are accessible through the ISA I/O ports.
We have to write to arbitrary I/O ports to probe them. This is usually
safe though. Yes, you do have ISA I/O ports even if you do not have any
ISA slots! Do you want to scan the ISA I/O ports? (YES/no): y
Probing for `National Semiconductor LM78' at 0x290...       No
Probing for `National Semiconductor LM79' at 0x290...       No
Probing for `Winbond W83781D' at 0x290...                   No
Probing for `Winbond W83782D' at 0x290...                   No
Lastly, we can probe the I2C/SMBus adapters for connected hardware
monitoring devices. This is the most risky part, and while it works
reasonably well on most systems, it has been reported to cause trouble
on some systems.
Do you want to probe the I2C/SMBus adapters now? (YES/no): y
Using driver `i2c-i801' for device 0000:00:1f.3: Intel ICH9
Module i2c-dev loaded successfully.
Next adapter: NVIDIA i2c adapter  (i2c-0)
Do you want to scan it? (YES/no/selectively): y
Next adapter: NVIDIA i2c adapter  (i2c-1)
Next adapter: NVIDIA i2c adapter  (i2c-2)
Client found at address 0x50
Probing for `Analog Devices ADM1033'...                     No
Probing for `Analog Devices ADM1034'...                     No
Probing for `SPD EEPROM'...                                 No
Probing for `EDID EEPROM'...                                Yes
    (confidence 8, not a hardware monitoring chip)
Next adapter: NVIDIA i2c adapter  (i2c-3)
Next adapter: NVIDIA i2c adapter  (i2c-4)
Next adapter: NVIDIA i2c adapter  (i2c-5)
Probing for `EDID EEPROM'...                                No
Client found at address 0x51
Client found at address 0x52
Client found at address 0x53
Now follows a summary of the probes I have just done.
Just press ENTER to continue:
Driver `coretemp':
  * Chip `Intel Core family thermal sensor' (confidence: 9)
To load everything that is needed, add this to /etc/modules:
#----cut here----
# Chip drivers
coretemp
#----cut here----
If you have some drivers built into your kernel, the list above will
contain too many modules. Skip the appropriate ones!
Do you want to add these lines automatically to /etc/modules? (yes/NO)n
j’ai répondu n parce que c’est déjà present dans /etc/modules.
# sensors
acpitz-virtual-0
Adapter: Virtual device
temp1:       +53.0°C  (crit = +106.0°C)
coretemp-isa-0000
Adapter: ISA adapter
Core 0:      +49.0°C  (high = +105.0°C, crit = +105.0°C)
coretemp-isa-0001
Core 1:      +49.0°C  (high = +105.0°C, crit = +105.0°C)
dpkg -l |grep fan
ii  fancontrol                           1:3.1.2-6                      utilities to read temperature/voltage/fan se
ii  libsensors3                          1:2.10.8-2                     library to read temperature/voltage/fan sens
ii  libsensors4                          1:3.1.2-6                      library to read temperature/voltage/fan sens
ii  lm-sensors                           1:3.1.2-6                      utilities to read temperature/voltage/fan se
uname -a Linux intel 2.6.32-4-686-bigmem #1 SMP Tue Apr 6 07:42:27 UTC 2010 i686 GNU/Linux
ii  firmware-linux-free                  2.6.32-18                      Binary firmware for various drivers in the L
ii  firmware-linux-nonfree               0.26                           Binary firmware for various drivers in the L
# pwmconfig
# pwmconfig revision 5770 (2009-09-16)
This program will search your sensors for pulse width modulation (pwm)
controls, and test each one to see if it controls a fan on
your motherboard. Note that many motherboards do not have pwm
circuitry installed, even if your sensor chip supports pwm.
We will attempt to briefly stop each fan using the pwm controls.
The program will attempt to restore each fan to full speed
after testing. However, it is ** very important ** that you
physically verify that the fans have been to full speed
after the program has completed.
/usr/sbin/pwmconfig: There are no pwm-capable sensor modules installed
donc c’est un acer travelmate 7730g avec debian squeez figée depuis peux
il faut un module mai quoi ?
dmesg fourni en fichier joins histoire de pas trop alourdire le topic :confused:
merci d’avance
NOTE: le fichier join est aux format text ,et non un tar , je sai pas pourquoi on peux pas placer un fichier text ??? ricardo ?
dmesg.tar (62.3 KB)
uuuuup :005
Je n’ai aucune idée de la raison pour laquelle ton portable se mettrai à chauffer plus qu’avant…
Sur ma machine, les ventilos ne peuvent pas être contrôlés par fancontrol mais pour que la commande “sensors” soit capable d’afficher leur vitesse, il a fallu que je modifie le fichier “/etc/default/grub” comme ci-dessous:
puis évidement valider avec:
[code]# update-grub2
reboot[/code]
Pour ce que j’en ait compris: dans les kernels récents, la façon dons les logiciels et drivers peuvent interagir avec les fonctions ACPI du BIOS a été changée afin de limiter un risque de modification intempestives de voltage etc… Avec de nombreuses carte-mères, cela empêche l’OS d’utiliser les fonctions en question pour lire les données telles que les vitesses des ventilos, les voltages et les températures…
[size=150]Avertissement: la manip proposée ci-dessus réactive des fonctions qui ont été volontairement désactivées au niveau kernel et elle est donc non recommandée (puisque les-dites fonctions sont jugées dangereuses pour le hardware)[/size]
Si avec cette manip, “sensors” se met à afficher les infos des ventilos, “pwconfig” devrait être capable d’en prendre le contrôle…
tester , negatif ,j’ai même tenter une re-compilation du kernel avec tout ce qu’on peux cocher dedans pour l’acpi ,mai rien non plus je croit qu’on peux dire que c’est pas supporter par le kernel :088
Merci pour ta réponse :023
ok désolé :confused:
Bon courage…
Regarde dans le BIOS, il y a parfois des options à activer pour que l’OS prenne en charge certaines fonctions.
c’est un portable donc le bios est pourrave et verrouiller et j’ai pas mal fouiner :unamused:
bref bon je vai devoir faire avec je sens :frowning:
Merci pour votre aide :slightly_smiling:
