Bonsoir,
ayant fait un upgrade de Etch vers Lenny, j’ai eu quelques problèmes avec le udevtrigger, que j’ai résolu. Maintenant j’arrive jusqu’au mode console, et je voudrais passer en mode graphique mais startx me sert les messages d’erreurs que voilà:
Fatal: Module mach64 not found
(EE) [drm] drmOpen failed
(EE) MACH64(0):[dri] DRIscreenInit Failed
Voici mon /etc/X11/xorg.conf
sudo dpkg-reconfigure -phigh xserver-xorg
Section "Files"
FontPath "/usr/share/fonts/X11/misc"
FontPath "/usr/share/fonts/X11/100dpi/:unscaled"
FontPath "/usr/share/fonts/X11/75dpi/:unscaled"
FontPath "/usr/share/fonts/X11/Type1"
FontPath "/usr/share/fonts/X11/100dpi"
FontPath “/usr/share/fonts/X11/75dpi”
# path to defoma fonts
FontPath “/var/lib/defoma/x-ttcidfont-conf.d/dirs/TrueType”
EndSection
Section "Module"
Load "i2c"
Load "bitmap"
Load "ddc"
Load "dri"
Load "extmod"
Load "freetype"
Load "glx"
Load "int10"
Load "vbe"
EndSection
Section "InputDevice"
Identifier "Generic Keyboard"
Driver "kbd"
Option "CoreKeyboard"
Option “XkbRules” "xorg"
Option “XkbModel” "pc105"
Option “XkbLayout” "fr"
Option “XkbVariant” "latin9"
EndSection
Identifier "Configured Mouse"
Driver "mouse"
Option "CorePointer"
Option “Device” "/dev/input/mice"
Option “Protocol” "ImPS/2"
Option “Emulate3Buttons” "true"
EndSection
Section "Device"
Identifier "ATI Technologies Inc 3D Rage LT Pro AGP-133"
Driver "ati"
BusID "PCI:1:0:0"
EndSection
Section "Monitor"
Identifier "Écran générique"
Option "DPMS"
HorizSync 58-62
VertRefresh 75-117
EndSection
Section "Screen"
Identifier "Default Screen"
Device "ATI Technologies Inc 3D Rage LT Pro AGP-133"
Monitor "Écran générique"
DefaultDepth 24
SubSection "Display"
Depth 1
Modes “1024x768” “800x600” "640x480"
EndSubSection
Depth 4
EndSubSection
Depth 8
EndSubSection
Depth 15
EndSubSection
Depth 16
EndSubSection
Depth 24
EndSubSection
EndSection
Section "ServerLayout"
Identifier "Default Layout"
Screen "Default Screen"
InputDevice "Generic Keyboard"
InputDevice "Configured Mouse"
EndSection
Section "DRI"
Mode 0666
EndSection
Le log /var/log/Xorg.0.log me donne les messages d’erreurs suivants:
(WW) Open ACPI failed (/var/run/acpid.socket) (No such file or directory)
drmOpenDevice: node name is /dev/dri/card0
drmOpenDevice: open result is -1, (No such device or address)
drmOpenDevice: Open failed
[drm] failed to load kernel module “mach64”
(EE) [drm] drmOpen failed.
(EE) MACH64(0): [dri] DRIScreenInit Failed
Could not init font path element /usr/share/fonts/X11/cyrillic, removing from list!
Could not init font path element /var/lib/defoma/x-ttcidfont-conf.d/dirs/TrueType, removing from list!
FreeFontPath: FPE “/usr/share/fonts/X11/misc” refcount is 2, should be 1; fixing.
J’ai essayé apt-get remove xserver-xorg, suivi de apt-get install xserver-xorg, sans résultat.
Les fichiers du paquet xserver-xorg-video-mach64 sont à leur place.
Voilà, j’espère ne pas avoir été trop long, et toute idée ser la bienvenue…
Merci d’avance
