Hello,
J’essaye d’installer le deriver fglrx dispos sous sid sur ma squeeze 32bits.
Je pense que l’installation s’est bien déroulée :
benjamin@laptop:~$ aptitude search fglrx
p fglrx-amdcccle
i A fglrx-atieventsd
p fglrx-control
v fglrx-control-qt3
i A fglrx-driver
i A fglrx-glx
p fglrx-kernel-src
v fglrx-modules
p fglrx-modules-2.6-486
i fglrx-modules-2.6-686
p fglrx-modules-2.6-686-bigmem
p fglrx-modules-2.6-openvz-686
p fglrx-modules-2.6-vserver-686
p fglrx-modules-2.6-vserver-686-bigmem
p fglrx-modules-2.6-xen-686
p fglrx-modules-2.6.26-2-486
p fglrx-modules-2.6.26-2-686
p fglrx-modules-2.6.26-2-686-bigmem
p fglrx-modules-2.6.26-2-openvz-686
p fglrx-modules-2.6.26-2-vserver-686
p fglrx-modules-2.6.26-2-vserver-686-bigmem
p fglrx-modules-2.6.26-2-xen-686
p fglrx-modules-2.6.30-1-486
i fglrx-modules-2.6.30-1-686
p fglrx-modules-2.6.30-1-686-bigmem
i fglrx-source
Mais dans les log de xorg
benjamin@laptop:~$ cat /var/log/Xorg.0.log | grep EE
(II) Loading extension MIT-SCREEN-SAVER
(EE) fglrx(0): incompatible kernel module detected - HW accelerated OpenGL will not work
(EE) fglrx(0): XMM failed to open CMMQS connection.
benjamin@laptop:~$ cat /var/log/Xorg.0.log | grep WW
(WW) The directory "/usr/share/fonts/X11/cyrillic" does not exist.
(WW) Falling back to old probe method for fglrx
(WW) This ATI Proprietary Linux Driver does not guarantee support of video driver ABI higher than 2.0
(WW) Video driver ABI version of the X server is 5.0
(WW) fglrx: No matching Device section for instance (BusID PCI:0@1:0:1) found
(WW) fglrx(0): board is an unknown third party board, chipset is supported
(WW) fglrx(0): Unknown vendor-specific block 0
(WW) fglrx(0): could not detect X server version (query_status=-1)
(WW) fglrx(0): Kernel Module version does *not* match driver.
(WW) fglrx(0): ***********************************************
(WW) fglrx(0): * DRI initialization failed! *
(WW) fglrx(0): * (maybe driver kernel module missing or bad) *
(WW) fglrx(0): * 2D acceleraton available (MMIO) *
(WW) fglrx(0): * no 3D acceleration available *
(WW) fglrx(0): ********************************************* *
(WW) fglrx(0): Textured Video not supported without DRI enabled.
(WW) fglrx(0): Option "VendorName" is not used
(WW) fglrx(0): Option "ModelName" is not used
Une idée ?
