Mar 14 23:21:16 mercure /usr/lib/gdm3/gdm-x-session[24150]: (II) AIGLX: GLX_EXT_texture_from_pixmap backed by buffer objects
Mar 14 23:21:16 mercure /usr/lib/gdm3/gdm-x-session[24150]: (II) AIGLX: Loaded and initialized nouveau
Mar 14 23:21:16 mercure /usr/lib/gdm3/gdm-x-session[24150]: (II) GLX: Initialized DRI2 GL provider for screen 0
Mar 14 23:21:16 mercure /usr/lib/gdm3/gdm-x-session[24150]: (II) NOUVEAU(0): NVEnterVT is called.
Mar 14 23:21:16 mercure /usr/lib/gdm3/gdm-x-session[24150]: (II) NOUVEAU(0): Setting screen physical size to 1016 x 285
Mar 14 23:21:16 mercure /usr/lib/gdm3/gdm-x-session[24150]: resize called 3840 1080
Mar 14 23:21:16 mercure /usr/lib/gdm3/gdm-x-session[24150]: (II) config/udev: Adding input device Power Button (/dev/input/event1)
Mar 14 23:21:16 mercure /usr/lib/gdm3/gdm-x-session[24150]: (**) Power Button: Applying InputClass "libinput keyboard catchall"
Mar 14 23:21:16 mercure /usr/lib/gdm3/gdm-x-session[24150]: (II) LoadModule: "libinput"
Mar 14 23:21:16 mercure /usr/lib/gdm3/gdm-x-session[24150]: (II) Loading /usr/lib/xorg/modules/input/libinput_drv.so
Mar 14 23:21:16 mercure /usr/lib/gdm3/gdm-x-session[24150]: (II) Module libinput: vendor="X.Org Foundation"
Mar 14 23:21:16 mercure /usr/lib/gdm3/gdm-x-session[24150]: #011compiled for 1.19.0, module version = 0.23.0
Mar 14 23:21:16 mercure /usr/lib/gdm3/gdm-x-session[24150]: #011Module class: X.Org XInput Driver
Mar 14 23:21:16 mercure /usr/lib/gdm3/gdm-x-session[24150]: #011ABI class: X.Org XInput driver, version 24.1
Mar 14 23:21:16 mercure /usr/lib/gdm3/gdm-x-session[24150]: (II) Using input driver 'libinput' for 'Power Button'
Mar 14 23:21:16 mercure /usr/lib/gdm3/gdm-x-session[24150]: (II) systemd-logind: got fd for /dev/input/event1 13:65 fd 23 paused 0
Mar 14 23:21:16 mercure /usr/lib/gdm3/gdm-x-session[24150]: (**) Power Button: always reports core events
Mar 14 23:21:16 mercure /usr/lib/gdm3/gdm-x-session[24150]: (**) Option "Device" "/dev/input/event1"
Mar 14 23:21:16 mercure /usr/lib/gdm3/gdm-x-session[24150]: (**) Option "_source" "server/udev"
Mar 14 23:21:16 mercure /usr/lib/gdm3/gdm-x-session[24150]: (II) input device 'Power Button', /dev/input/event1 is tagged by udev as: Keyboard
Mar 14 23:21:16 mercure /usr/lib/gdm3/gdm-x-session[24150]: (II) input device 'Power Button', /dev/input/event1 is a keyboard
Mar 14 23:21:16 mercure /usr/lib/gdm3/gdm-x-session[24150]: (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXPWRBN:00/input/input1/event1"
Mar 14 23:21:16 mercure /usr/lib/gdm3/gdm-x-session[24150]: (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 6)
Mar 14 23:21:16 mercure /usr/lib/gdm3/gdm-x-session[24150]: (**) Option "xkb_model" "pc105"
Mar 14 23:21:16 mercure /usr/lib/gdm3/gdm-x-session[24150]: (**) Option "xkb_layout" "fr,us"
Mar 14 23:21:16 mercure /usr/lib/gdm3/gdm-x-session[24150]: (**) Option "xkb_variant" ",alt-intl"
Mar 14 23:21:16 mercure /usr/lib/gdm3/gdm-x-session[24150]: (**) Option "xkb_options" "grp:alt_shift_toggle,terminate:ctrl_alt_bksp,grp_led:scroll"
Mar 14 23:21:16 mercure /usr/lib/gdm3/gdm-x-session[24150]: (II) config/udev: Adding input device Power Button (/dev/input/event0)
Mar 14 23:21:16 mercure /usr/lib/gdm3/gdm-x-session[24150]: (II) systemd-logind: got fd for /dev/input/event0 13:64 fd 26 paused 0
Mar 14 23:21:16 mercure /usr/lib/gdm3/gdm-x-session[24150]: (**) Option "Device" "/dev/input/event0"
Mar 14 23:21:16 mercure /usr/lib/gdm3/gdm-x-session[24150]: (II) input device 'Power Button', /dev/input/event0 is tagged by udev as: Keyboard
Mar 14 23:21:16 mercure /usr/lib/gdm3/gdm-x-session[24150]: (II) input device 'Power Button', /dev/input/event0 is a keyboard
Mar 14 23:21:16 mercure /usr/lib/gdm3/gdm-x-session[24150]: (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input0/event0"
Mar 14 23:21:16 mercure /usr/lib/gdm3/gdm-x-session[24150]: (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 7)
Mar 14 23:21:16 mercure /usr/lib/gdm3/gdm-x-session[24150]: (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=3 (/dev/input/event11)
Mar 14 23:21:16 mercure /usr/lib/gdm3/gdm-x-session[24150]: (II) No input driver specified, ignoring this device.
Mar 14 23:21:16 mercure /usr/lib/gdm3/gdm-x-session[24150]: (II) This device may have been added with another device file.
Mar 14 23:21:16 mercure /usr/lib/gdm3/gdm-x-session[24150]: (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=7 (/dev/input/event12)
Mar 14 23:21:16 mercure /usr/lib/gdm3/gdm-x-session[24150]: (II) config/udev: Adding input device Logitech USB Receiver (/dev/input/event13)
Mar 14 23:21:16 mercure /usr/lib/gdm3/gdm-x-session[24150]: (**) Logitech USB Receiver: Applying InputClass "libinput keyboard catchall"
Mar 14 23:21:16 mercure /usr/lib/gdm3/gdm-x-session[24150]: (II) Using input driver 'libinput' for 'Logitech USB Receiver'
Mar 14 23:21:16 mercure /usr/lib/gdm3/gdm-x-session[24150]: (II) systemd-logind: got fd for /dev/input/event13 13:77 fd 27 paused 0
Mar 14 23:21:16 mercure /usr/lib/gdm3/gdm-x-session[24150]: (**) Logitech USB Receiver: always reports core events
Mar 14 23:21:16 mercure /usr/lib/gdm3/gdm-x-session[24150]: (**) Option "Device" "/dev/input/event13"
Mar 14 23:21:16 mercure /usr/lib/gdm3/gdm-x-session[24150]: (II) input device 'Logitech USB Receiver', /dev/input/event13 is tagged by udev as: Keyboard
Mar 14 23:21:16 mercure /usr/lib/gdm3/gdm-x-session[24150]: (II) input device 'Logitech USB Receiver', /dev/input/event13 is a keyboard
Mar 14 23:21:16 mercure /usr/lib/gdm3/gdm-x-session[24150]: (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb2/2-11/2-11:1.0/0003:046D:C517.0001/input/input13/event13"
Mar 14 23:21:16 mercure /usr/lib/gdm3/gdm-x-session[24150]: (II) XINPUT: Adding extended input device "Logitech USB Receiver" (type: KEYBOARD, id 8)
Mar 14 23:21:16 mercure /usr/lib/gdm3/gdm-x-session[24150]: (II) config/udev: Adding input device Logitech USB Receiver (/dev/input/event14)
Mar 14 23:21:16 mercure /usr/lib/gdm3/gdm-x-session[24150]: (**) Logitech USB Receiver: Applying InputClass "libinput pointer catchall"
Mar 14 23:21:16 mercure /usr/lib/gdm3/gdm-x-session[24150]: (II) systemd-logind: got fd for /dev/input/event14 13:78 fd 28 paused 0
Mar 14 23:21:16 mercure /usr/lib/gdm3/gdm-x-session[24150]: (**) Option "Device" "/dev/input/event14"
Mar 14 23:21:16 mercure /usr/lib/gdm3/gdm-x-session[24150]: (II) input device 'Logitech USB Receiver', /dev/input/event14 is tagged by udev as: Keyboard Mouse
Mar 14 23:21:16 mercure /usr/lib/gdm3/gdm-x-session[24150]: (II) Device 'Logitech USB Receiver' set to 950 DPI
Mar 14 23:21:16 mercure /usr/lib/gdm3/gdm-x-session[24150]: (II) input device 'Logitech USB Receiver', /dev/input/event14 is a pointer caps
Mar 14 23:21:16 mercure /usr/lib/gdm3/gdm-x-session[24150]: (II) input device 'Logitech USB Receiver', /dev/input/event14 is a keyboard
Mar 14 23:21:16 mercure /usr/lib/gdm3/gdm-x-session[24150]: (II) libinput: Logitech USB Receiver: needs a virtual subdevice
Mar 14 23:21:16 mercure /usr/lib/gdm3/gdm-x-session[24150]: (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb2/2-11/2-11:1.1/0003:046D:C517.0002/input/input14/event14"
Mar 14 23:21:16 mercure /usr/lib/gdm3/gdm-x-session[24150]: (II) XINPUT: Adding extended input device "Logitech USB Receiver" (type: MOUSE, id 9)
Mar 14 23:21:16 mercure /usr/lib/gdm3/gdm-x-session[24150]: (**) Option "AccelerationScheme" "none"
Mar 14 23:21:16 mercure /usr/lib/gdm3/gdm-x-session[24150]: (**) Logitech USB Receiver: (accel) selected scheme none/0
Mar 14 23:21:16 mercure /usr/lib/gdm3/gdm-x-session[24150]: (**) Logitech USB Receiver: (accel) acceleration factor: 2.000
Mar 14 23:21:16 mercure /usr/lib/gdm3/gdm-x-session[24150]: (**) Logitech USB Receiver: (accel) acceleration threshold: 4
Mar 14 23:21:16 mercure /usr/lib/gdm3/gdm-x-session[24150]: (II) config/udev: Adding input device Logitech USB Receiver (/dev/input/mouse0)
Mar 14 23:21:16 mercure /usr/lib/gdm3/gdm-x-session[24150]: (II) config/udev: Adding input device HD Pro Webcam C920 (/dev/input/event15)
Mar 14 23:21:16 mercure /usr/lib/gdm3/gdm-x-session[24150]: (**) HD Pro Webcam C920: Applying InputClass "libinput keyboard catchall"
Mar 14 23:21:16 mercure /usr/lib/gdm3/gdm-x-session[24150]: (II) Using input driver 'libinput' for 'HD Pro Webcam C920'
Mar 14 23:21:16 mercure /usr/lib/gdm3/gdm-x-session[24150]: (II) systemd-logind: got fd for /dev/input/event15 13:79 fd 29 paused 0
Mar 14 23:21:16 mercure /usr/lib/gdm3/gdm-x-session[24150]: (**) HD Pro Webcam C920: always reports core events
Mar 14 23:21:16 mercure /usr/lib/gdm3/gdm-x-session[24150]: (**) Option "Device" "/dev/input/event15"
Mar 14 23:21:16 mercure /usr/lib/gdm3/gdm-x-session[24150]: (II) input device 'HD Pro Webcam C920', /dev/input/event15 is tagged by udev as: Keyboard
Mar 14 23:21:16 mercure /usr/lib/gdm3/gdm-x-session[24150]: (II) input device 'HD Pro Webcam C920', /dev/input/event15 is a keyboard
Mar 14 23:21:16 mercure /usr/lib/gdm3/gdm-x-session[24150]: (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb2/2-3/2-3:1.0/input/input15/event15"
Mar 14 23:21:16 mercure /usr/lib/gdm3/gdm-x-session[24150]: (II) XINPUT: Adding extended input device "HD Pro Webcam C920" (type: KEYBOARD, id 10)
Mar 14 23:21:16 mercure /usr/lib/gdm3/gdm-x-session[24150]: (II) config/udev: Adding input device HDA Intel PCH Front Headphone (/dev/input/event10)
Mar 14 23:21:16 mercure /usr/lib/gdm3/gdm-x-session[24150]: (II) config/udev: Adding input device HDA Digital PCBeep (/dev/input/event3)
Mar 14 23:21:16 mercure /usr/lib/gdm3/gdm-x-session[24150]: (II) config/udev: Adding input device HDA Intel PCH Front Mic (/dev/input/event4)
Mar 14 23:21:16 mercure /usr/lib/gdm3/gdm-x-session[24150]: (II) config/udev: Adding input device HDA Intel PCH Rear Mic (/dev/input/event5)
Mar 14 23:21:16 mercure /usr/lib/gdm3/gdm-x-session[24150]: (II) config/udev: Adding input device HDA Intel PCH Line (/dev/input/event6)
Mar 14 23:21:16 mercure /usr/lib/gdm3/gdm-x-session[24150]: (II) config/udev: Adding input device HDA Intel PCH Line Out Front (/dev/input/event7)
Mar 14 23:21:16 mercure /usr/lib/gdm3/gdm-x-session[24150]: (II) config/udev: Adding input device HDA Intel PCH Line Out Surround (/dev/input/event8)
Mar 14 23:21:16 mercure /usr/lib/gdm3/gdm-x-session[24150]: (II) config/udev: Adding input device HDA Intel PCH Line Out CLFE (/dev/input/event9)
Mar 14 23:21:16 mercure /usr/lib/gdm3/gdm-x-session[24150]: (II) config/udev: Adding input device PC Speaker (/dev/input/event2)
Mar 14 23:21:16 mercure /usr/lib/gdm3/gdm-x-session[24150]: (II) systemd-logind: returning pre-existing fd for /dev/input/event14 13:78
Mar 14 23:21:16 mercure /usr/lib/gdm3/gdm-x-session[24150]: (**) Option "_source" "_driver/libinput"
Mar 14 23:21:16 mercure /usr/lib/gdm3/gdm-x-session[24150]: (II) libinput: Logitech USB Receiver: is a virtual subdevice
Mar 14 23:21:16 mercure /usr/lib/gdm3/gdm-x-session[24150]: (II) XINPUT: Adding extended input device "Logitech USB Receiver" (type: KEYBOARD, id 11)
Mar 14 23:21:16 mercure /usr/lib/gdm3/gdm-x-session[24150]: /etc/gdm3/Xsession: Beginning session setup...
Mar 14 23:21:16 mercure /usr/lib/gdm3/gdm-x-session[24150]: dbus-update-activation-environment: setting DBUS_SESSION_BUS_ADDRESS=unix:path=/run/user/1000/bus
Mar 14 23:21:16 mercure /usr/lib/gdm3/gdm-x-session[24150]: dbus-update-activation-environment: setting DISPLAY=:1
Mar 14 23:21:16 mercure /usr/lib/gdm3/gdm-x-session[24150]: dbus-update-activation-environment: setting XAUTHORITY=/run/user/1000/gdm/Xauthority
Mar 14 23:21:16 mercure /usr/lib/gdm3/gdm-x-session[24150]: localuser:mj being added to access control list
Mar 14 23:21:16 mercure /usr/lib/gdm3/gdm-x-session[24150]: dbus-update-activation-environment: setting GTK_MODULES=gail:atk-bridge
Mar 14 23:21:16 mercure /usr/lib/gdm3/gdm-x-session[24150]: OpenGL version: 3.
Mar 14 23:21:16 mercure /usr/lib/gdm3/gdm-x-session[24150]: dbus-update-activation-environment: setting QT_ACCESSIBILITY=1
Mar 14 23:21:16 mercure /usr/lib/gdm3/gdm-x-session[24150]: dbus-update-activation-environment: setting QT_LINUX_ACCESSIBILITY_ALWAYS_ON=1
Mar 14 23:21:16 mercure /usr/lib/gdm3/gdm-x-session[24150]: dbus-update-activation-environment: setting USER=mj
Mar 14 23:21:16 mercure /usr/lib/gdm3/gdm-x-session[24150]: dbus-update-activation-environment: setting XDG_SESSION_TYPE=x11
Mar 14 23:21:16 mercure /usr/lib/gdm3/gdm-x-session[24150]: dbus-update-activation-environment: setting SSH_AGENT_PID=1625
Mar 14 23:21:16 mercure /usr/lib/gdm3/gdm-x-session[24150]: dbus-update-activation-environment: setting HOME=/home/mj
Mar 14 23:21:16 mercure /usr/lib/gdm3/gdm-x-session[24150]: dbus-update-activation-environment: setting QT4_IM_MODULE=xim
Mar 14 23:21:16 mercure /usr/lib/gdm3/gdm-x-session[24150]: dbus-update-activation-environment: setting DESKTOP_SESSION=default
Mar 14 23:21:16 mercure /usr/lib/gdm3/gdm-x-session[24150]: dbus-update-activation-environment: setting IM_CONFIG_PHASE=1
Mar 14 23:21:16 mercure /usr/lib/gdm3/gdm-x-session[24150]: dbus-update-activation-environment: setting QT_QPA_PLATFORMTHEME=qgnomeplatform
Mar 14 23:21:16 mercure /usr/lib/gdm3/gdm-x-session[24150]: dbus-update-activation-environment: setting LOGNAME=mj
Mar 14 23:21:16 mercure /usr/lib/gdm3/gdm-x-session[24150]: dbus-update-activation-environment: setting GTK_IM_MODULE=ibus
Mar 14 23:21:16 mercure /usr/lib/gdm3/gdm-x-session[24150]: dbus-update-activation-environment: setting JOURNAL_STREAM=9:25022
Mar 14 23:21:16 mercure /usr/lib/gdm3/gdm-x-session[24150]: dbus-update-activation-environment: setting USERNAME=mj
Mar 14 23:21:16 mercure /usr/lib/gdm3/gdm-x-session[24150]: dbus-update-activation-environment: setting GNOME_DESKTOP_SESSION_ID=this-is-deprecated
Mar 14 23:21:16 mercure /usr/lib/gdm3/gdm-x-session[24150]: dbus-update-activation-environment: setting WINDOWPATH=2
Mar 14 23:21:16 mercure /usr/lib/gdm3/gdm-x-session[24150]: dbus-update-activation-environment: setting PATH=/home/mj/bin:/usr/local/bin:/usr/bin:/bin:/usr/local/games:/usr/games
Mar 14 23:21:16 mercure /usr/lib/gdm3/gdm-x-session[24150]: dbus-update-activation-environment: setting GDM_LANG=fr_FR.UTF-8
Mar 14 23:21:16 mercure /usr/lib/gdm3/gdm-x-session[24150]: dbus-update-activation-environment: setting SESSION_MANAGER=local/mercure:@/tmp/.ICE-unix/23615,unix/mercure:/tmp/.ICE-unix/23615
Mar 14 23:21:16 mercure /usr/lib/gdm3/gdm-x-session[24150]: dbus-update-activation-environment: setting XDG_RUNTIME_DIR=/run/user/1000
Mar 14 23:21:16 mercure /usr/lib/gdm3/gdm-x-session[24150]: dbus-update-activation-environment: setting XDG_MENU_PREFIX=gnome-
Mar 14 23:21:16 mercure /usr/lib/gdm3/gdm-x-session[24150]: dbus-update-activation-environment: setting LANG=fr_FR.UTF-8
Mar 14 23:21:16 mercure /usr/lib/gdm3/gdm-x-session[24150]: dbus-update-activation-environment: setting XDG_CURRENT_DESKTOP=GNOME
Mar 14 23:21:16 mercure /usr/lib/gdm3/gdm-x-session[24150]: dbus-update-activation-environment: setting XDG_SESSION_DESKTOP=default
Mar 14 23:21:16 mercure /usr/lib/gdm3/gdm-x-session[24150]: dbus-update-activation-environment: setting XMODIFIERS=@im=ibus
Mar 14 23:21:16 mercure /usr/lib/gdm3/gdm-x-session[24150]: dbus-update-activation-environment: setting SSH_AUTH_SOCK=/run/user/1000/keyring/ssh
Mar 14 23:21:16 mercure /usr/lib/gdm3/gdm-x-session[24150]: dbus-update-activation-environment: setting SHELL=/bin/bash
Mar 14 23:21:16 mercure /usr/lib/gdm3/gdm-x-session[24150]: dbus-update-activation-environment: setting GDMSESSION=default
Mar 14 23:21:16 mercure /usr/lib/gdm3/gdm-x-session[24150]: dbus-update-activation-environment: setting GPG_AGENT_INFO=/run/user/1000/gnupg/S.gpg-agent:0:1
Mar 14 23:21:16 mercure /usr/lib/gdm3/gdm-x-session[24150]: dbus-update-activation-environment: setting QT_IM_MODULE=ibus
Mar 14 23:21:16 mercure /usr/lib/gdm3/gdm-x-session[24150]: dbus-update-activation-environment: setting PWD=/home/mj
Mar 14 23:21:16 mercure /usr/lib/gdm3/gdm-x-session[24150]: dbus-update-activation-environment: setting CLUTTER_IM_MODULE=xim
Mar 14 23:21:16 mercure /usr/lib/gdm3/gdm-x-session[24150]: dbus-update-activation-environment: setting XDG_DATA_DIRS=/usr/share/gnome:/usr/share/gnome:/usr/share/gnome:/usr/local/share/:/usr/share/
Mar 14 23:21:41 mercure gnome-session[24159]: gnome-session-binary[24159]: CRITICAL: gsm_manager_set_phase: assertion 'GSM_IS_MANAGER (manager)' failed
Mar 14 23:21:41 mercure gnome-session-binary[24159]: CRITICAL: gsm_manager_set_phase: assertion 'GSM_IS_MANAGER (manager)' failed
Mar 14 23:21:41 mercure /usr/lib/gdm3/gdm-x-session[24150]: (**) Option "fd" "23"
Mar 14 23:21:41 mercure /usr/lib/gdm3/gdm-x-session[24150]: (**) Option "fd" "26"
Mar 14 23:21:41 mercure /usr/lib/gdm3/gdm-x-session[24150]: (**) Option "fd" "27"
Mar 14 23:21:41 mercure /usr/lib/gdm3/gdm-x-session[24150]: (**) Option "fd" "28"
Mar 14 23:21:41 mercure /usr/lib/gdm3/gdm-x-session[24150]: (**) Option "fd" "29"
Mar 14 23:21:41 mercure /usr/lib/gdm3/gdm-x-session[24150]: (II) UnloadModule: "libinput"
Mar 14 23:21:41 mercure /usr/lib/gdm3/gdm-x-session[24150]: (II) systemd-logind: not releasing fd for 13:78, still in use
Mar 14 23:21:41 mercure /usr/lib/gdm3/gdm-x-session[24150]: (II) systemd-logind: releasing fd for 13:79
Mar 14 23:21:42 mercure /usr/lib/gdm3/gdm-x-session[24150]: (II) UnloadModule: "libinput"
Mar 14 23:21:42 mercure /usr/lib/gdm3/gdm-x-session[24150]: (II) systemd-logind: releasing fd for 13:78
Mar 14 23:21:42 mercure gnome-keyring-ssh.desktop[24260]: SSH_AUTH_SOCK=/run/user/1000/keyring/ssh
Mar 14 23:21:42 mercure gnome-keyring-pkcs11.desktop[24262]: SSH_AUTH_SOCK=/run/user/1000/keyring/ssh
Mar 14 23:21:42 mercure /usr/lib/gdm3/gdm-x-session[24150]: (II) systemd-logind: releasing fd for 13:77
Mar 14 23:21:42 mercure /usr/lib/gdm3/gdm-x-session[24150]: (II) systemd-logind: releasing fd for 13:64
Mar 14 23:21:42 mercure /usr/lib/gdm3/gdm-x-session[24150]: (II) systemd-logind: releasing fd for 13:65
Mar 14 23:21:42 mercure /usr/lib/gdm3/gdm-x-session[24150]: (II) NOUVEAU(0): NVLeaveVT is called.
Mar 14 23:21:42 mercure /usr/lib/gdm3/gdm-x-session[24150]: (II) Server terminated successfully (0). Closing log file.
Je ne sais pas trop ou chercher le probléme, et je n’ai pas envie d’installer le module proprio pour contourner le probléme.
Des idées ?
