#!/bin/sh
This script builds a self-contained installed tree of
Berkeley DB XML and its dependent libraries.
By default, this script builds this configuration:
o no debug or diagnostics
o no Java
o no Tcl or testing config
The default installation directory is:
o ./install
Assumptions (configurable):
CDPATH gets in the way
unset CDPATH
DBXML_DIR_DEFAULT=dbxml
XERCES_DIR_DEFAULT=xerces-c-src
PATHAN_DIR_DEFAULT=pathan
XQUERY_DIR_DEFAULT=xquery-1.2.0
DB_DIR_DEFAULT=db-4.3.29
XERCES_DEPDOM=“libxerces-depdom.“
XERCES_TO_REMOVE=”$XERCES_DEPDOM libxerces-c.”
DBXML_INSTALL_DEFAULT=./install
DB_INSTALL_DEFAULT=./install
XERCES_INSTALL_DEFAULT=./install
PATHAN_INSTALL_DEFAULT=./install
XQUERY_INSTALL_DEFAULT=./install
There is no dependency checking in this script, so if it is called more than
once, the configure steps are performed unconditionally.
usage() {
cat <<EOF
Usage: $0 [options]
–help print this help message
-p platform type as understood by
runConfigure in Xerces-C++ [guessed]
-c [gcc]
-x <C++ compiler name> [g++]
-m [make]
-b <bits to build: 32 or 64> [32]
–no-configure: do not re-run configure steps. Assumes
configuration has been run previously
–clean: perform ‘make clean’ on all libraries
–distclean: perform ‘make distclean’ on all
libraries
–prefix=: set common installation prefix
[./install]
–enable-debug: debug build
–enable-java: Java support
–with-tcl=: Tcl support
–enable-test: Test suite support
forces --enable-debug and requires
–with-tcl
–enable-dependencies: Build include file dependencies for
Pathan, xquery, and dbxml. May only
work for g++.
–enable-perl: Perl support. Requires all
libraries built and installed
–with-dbxml=: use Berkeley DB XML sources in
–with-dbxml-conf=: pass flags to DB XML configure
–with-dbxml-prefix=: installation prefix for DB XML
[$DBXML_INSTALL_DEFAULT]
–with-berkeleydb=: use Berkeley DB sources in
–with-berkeleydb-conf=: pass flags to DB configure
–with-berkeleydb-prefix=: installation prefix for DB
[$DB_INSTALL_DEFAULT]
–with-pathan=: use Pathan sources in
–with-pathan-conf=: pass flags to Pathan configure
–with-pathan-prefix=: installation prefix for Pathan
[$PATHAN_INSTALL_DEFAULT]
–with-xerces=: use Xerces-C++ sources in
–with-xerces-conf=: pass flags to Xerces-C++ runConfigure
–with-xerces-prefix=: installation prefix for Xerces
[$XERCES_INSTALL_DEFAULT]
–with-xquery=: use XQuery sources in
–with-xquery-conf=: pass flags to Xquery configure
–with-xquery-prefix=: installation prefix for Xquery
[$XQUERY_INSTALL_DEFAULT]
–build-one= build only the specified library,
which is one of berkeleydb, xerces,
pathan, xquery, dbxml, or perl
EOF
HOST_OS=uname -s
Defaults (PLATFORM is for Xerces build)
case $HOST_OS in
Darwin*) PLATFORM=macosx
MACOSX_DEPLOYMENT_TARGET=10.3
export MACOSX_DEPLOYMENT_TARGET
SunOS) PLATFORM=solaris ;;
CYGWIN*) PLATFORM=cygwin ;;
HP-UX) OS_REL=uname -r
case $OS_REL in
11) PLATFORM=hp-11 ;;
10) PLATFORM=hp-10 ;;
esac
*) PLATFORM=echo $HOST_OS | tr A-Z a-z ;;
esac
Don’t override user’s settings for these common environment variables.
CC=${CC-gcc}
CXX=${CXX-g++}
MAKE=${MAKE-make}
BITS=32
DBXML_DIR=$DBXML_DIR_DEFAULT
XERCES_DIR=$XERCES_DIR_DEFAULT
PATHAN_DIR=$PATHAN_DIR_DEFAULT
XQUERY_DIR=$XQUERY_DIR_DEFAULT
DB_DIR=$DB_DIR_DEFAULT
DBXML_INSTALL_DIR=$DBXML_INSTALL_DEFAULT
DB_INSTALL_DIR=$DB_INSTALL_DEFAULT
XERCES_INSTALL_DIR=$XERCES_INSTALL_DEFAULT
PATHAN_INSTALL_DIR=$PATHAN_INSTALL_DEFAULT
XQUERY_INSTALL_DIR=$XQUERY_INSTALL_DEFAULT
DBXML_CONF_ARGS=
DB_CONF_ARGS=
PATHAN_CONF_ARGS=
XERCES_CONF_ARGS=
XQUERY_CONF_ARGS=
DBXML_CONF_XARGS=
DB_CONF_XARGS=
PATHAN_CONF_XARGS=
XERCES_CONF_XARGS=
XQUERY_CONF_XARGS=
DO_CONFIGURE=“yes”
Note: a --no-install flag might make sense, except that
it would cause builds to fail. E.g. Pathan, XQuery, and DB XML
build against the installed location of Xerces, not source.
DO_INSTALL="yes"
DO_CLEAN="no"
DEBUG_ENABLED="no"
TCL_ENABLED="no"
TEST_ENABLED="no"
BUILD_ONE="no"
BUILD_PERL="no"
PERL=“perl”
Parse arguments
for option
do
# If the previous option needs an argument, assign it.
if test -n “$prev” ; then
eval "$prev=$option"
prev=
continue
fi
case "$option" in
-*=*) optarg=`echo "$option" | sed 's/[-_a-zA-Z0-9]*=//'` ;;
*) optarg= ;;
esac
case "$option" in
-p) prev=PLATFORM ;;
-c) prev=CC ;;
-x) prev=CXX ;;
-m) prev=MAKE ;;
-b) prev=BITS ;;
--no-configure)
DO_CONFIGURE="no"
--clean)
DO_CLEAN="clean"
--distclean)
DO_CLEAN="distclean"
--prefix=*)
DBXML_INSTALL_DIR="$optarg"
DB_INSTALL_DIR="$optarg"
PATHAN_INSTALL_DIR="$optarg"
XERCES_INSTALL_DIR="$optarg"
XQUERY_INSTALL_DIR="$optarg"
--enable-test)
DB_CONF_ARGS="$DB_CONF_ARGS $option"
DBXML_CONF_ARGS="$DBXML_CONF_ARGS $option"
TEST_ENABLED="yes"
if [ "$DEBUG_ENABLED" = "no" ]; then
DB_CONF_ARGS="$DB_CONF_ARGS --enable-debug"
DBXML_CONF_ARGS="$DBXML_CONF_ARGS --enable-debug"
XERCES_CONF_ARGS="$XERCES_CONF_ARGS -d"
PATHAN_CONF_ARGS="$PATHAN_CONF_ARGS --enable-debug"
XQUERY_CONF_ARGS="$XQUERY_CONF_ARGS --enable-debug"
DEBUG_ENABLED="yes"
fi
--enable-debug)
DEBUG_ENABLED="yes"
--enable-dependencies)
DBXML_CONF_ARGS="$DBXML_CONF_ARGS --enable-dependencies"
PATHAN_CONF_ARGS="$PATHAN_CONF_ARGS --enable-dependencies"
XQUERY_CONF_ARGS="$XQUERY_CONF_ARGS --enable-dependencies"
--enable-java)
--with-tcl=*)
TCL_ENABLED="yes"
--enable-perl) BUILD_PERL="yes" ;;
--with-dbxml=*) DBXML_DIR="$optarg" ;;
--with-berkeleydb=*) DB_DIR="$optarg" ;;
--with-pathan=*) PATHAN_DIR="$optarg" ;;
--with-xerces=*) XERCES_DIR="$optarg" ;;
--with-xquery=*) XQUERY_DIR="$optarg" ;;
--with-dbxml-conf=*) DBXML_CONF_XARGS="$optarg" ;;
--with-berkeleydb-conf=*) DB_CONF_XARGS="$optarg" ;;
--with-pathan-conf=*) PATHAN_CONF_XARGS="$optarg" ;;
--with-xerces-conf=*) XERCES_CONF_XARGS="$optarg" ;;
--with-xquery-conf=*) XQUERY_CONF_XARGS="$optarg" ;;
--with-dbxml-prefix=*) DBXML_INSTALL_DIR="$optarg" ;;
--with-berkeleydb-prefix=*) DB_INSTALL_DIR="$optarg" ;;
--with-pathan-prefix=*) PATHAN_INSTALL_DIR="$optarg" ;;
--with-xerces-prefix=*) XERCES_INSTALL_DIR="$optarg" ;;
--with-xquery-prefix=*) XQUERY_INSTALL_DIR="$optarg" ;;
--build-one=*)
if [ $BUILD_ONE = "no" ]; then
BUILD_ONE="$optarg"
case $BUILD_ONE in
berkeleydb|xerces|pathan|xquery|dbxml|perl) ;;
echo "$0: error: $BUILD_ONE is not a valid"
echo "library name for --build-one." 1>&2
exit 1
esac
else
echo "$O: error: --build-one already specified" 1>&2
exit 1
fi
-h|--help|-?) usage ; exit 0 ;;
*) echo "$0: error: $option invalid option." 1>&2
echo "Run with --help to see usage." 1>&2
exit 1
esac
done
validate configuration state
if [ $TEST_ENABLED = “yes” ]; then
if [ $TCL_ENABLED = “no” ]; then
echo “$0: error: --enable-test requires --with-tcl” 1>&2
exit 1
fi
if [ $DEBUG_ENABLED = “no” ]; then
echo “$0: error: --enable-test requires --enable-debug” 1>&2
exit 1
fi
fi
Fix directories to be absolute
TOP=pwd
mkdir -p "$DBXML_INSTALL_DIR"
DBXML_INSTALL_DIR=cd $DBXML_INSTALL_DIR && pwd || exit $?
mkdir -p "$DB_INSTALL_DIR"
DB_INSTALL_DIR=cd $DB_INSTALL_DIR && pwd || exit $?
mkdir -p "$PATHAN_INSTALL_DIR"
PATHAN_INSTALL_DIR=cd $PATHAN_INSTALL_DIR && pwd || exit $?
mkdir -p "$XERCES_INSTALL_DIR"
XERCES_INSTALL_DIR=cd $XERCES_INSTALL_DIR && pwd || exit $?
mkdir -p "$XQUERY_INSTALL_DIR"
XQUERY_INSTALL_DIR=cd $XQUERY_INSTALL_DIR && pwd || exit $?
export CC
export CXX
export MAKE
quiet down HP’s aCC compiler for Xerces build
if [ $CXX = “aCC” ]; then
XERCES_CONF_XARGS="$XERCES_CONF_XARGS -z +W930"
fi
use native net accessor for Xerces on OS X
if [ $HOST_OS = “Darwin” ]; then
XERCES_CONF_XARGS="$XERCES_CONF_XARGS -nnative"
fi
Do the work. Order matters:
Berkeley DB
Xerces
Pathan
Xquery
Berkeley DB XML
deal with clean targets first
if [ $DO_CLEAN != “no” ]; then
echo “Performing clean: $DO_CLEAN”
# DB
if [ $BUILD_ONE = “no” -o $BUILD_ONE = “berkeleydb” ]; then
cd $DB_DIR/build_unix
$MAKE $DO_CLEAN
cd $TOP
fi
# Xerces
if [ $BUILD_ONE = “no” -o $BUILD_ONE = “xerces” ]; then
cd $XERCES_DIR/src/xercesc
$MAKE $DO_CLEAN
cd $TOP
fi
# Pathan
if [ $BUILD_ONE = “no” -o $BUILD_ONE = “pathan” ]; then
cd $PATHAN_DIR
$MAKE $DO_CLEAN
cd $TOP
fi
# XQuery
if [ $BUILD_ONE = “no” -o $BUILD_ONE = “xquery” ]; then
cd $XQUERY_DIR/build_unix
$MAKE $DO_CLEAN
cd $TOP
fi
# DBXML
if [ $BUILD_ONE = “no” -o $BUILD_ONE = “dbxml” ]; then
cd $DBXML_DIR/build_unix
$MAKE $DO_CLEAN
fi
# Perl
if [ $BUILD_ONE = “no” -o $BUILD_ONE = “perl” ]; then
cd $DBXML_DIR/src/perl
$MAKE $DO_CLEAN
fi
exit 0
fi
Berkeley DB
echo Start DB build: date
if [ $DO_CONFIGURE = “yes” ]; then
echo Configuring Berkeley DB
…/dist/configure --prefix=$DB_INSTALL_DIR --enable-cxx
$DB_CONF_ARGS $DB_CONF_XARGS || exit $?
fi
echo Building Berkeley DB
$MAKE || exit $?
if [ $DO_INSTALL = "yes" ]; then
echo Installing Berkeley DB
# this conditional code is to avoid make install failures for
# Berkeley DB when the distribution does not have documentation.
# DB documentation is included in DB XML documentation.
DOCLIST="api_c api_cxx api_tcl collections gsg images java ref sleepycat utility index.html"
if [ -d ../docs ]; then
rmdocs="no"
else
mkdir ../docs
cd ../docs
touch $DOCLIST
rmdocs="yes"
cd ../build_unix
fi
$MAKE install || exit $?
if [ $rmdocs = "yes" ]; then
rm -rf ../docs
rm -rf $DB_INSTALL_DIR/docs
fi
fi
cd $TOP
echo End DB build: `date`
fi
echo “"
echo "”
XERCESCROOT=cd $XERCES_DIR && pwd
export XERCESCROOT
Xerces
change args, depending on platform
echo Start Xerces build: date
echo Configuring Xerces
./runConfigure -p$PLATFORM -c$CC -x$CXX -b$BITS -P$XERCES_INSTALL_DIR
$XERCES_CONF_ARGS $XERCES_CONF_XARGS || exit $?
fi
echo Building Xerces
$MAKE || exit $?
echo Installing Xerces
# remove symlinks that cause make install to fail if re-run
for i in $XERCES_TO_REMOVE
do
rm -f $XERCES_INSTALL_DIR/lib/$i
done
# remove unused xerces library. Cannot suppress build, but can remove it.
for i in $XERCES_DEPDOM
do
done
fi
cd $TOP
echo End Xerces build: `date`
fi
echo “"
echo "”
Pathan
change args, depending on platform/config
Pathan depends on header files internal to Xerces, and
requires --with-xerces to point to the source, rather
than an install tree.
echo Start Pathan build: date
cd $PATHAN_DIR
echo Configuring Pathan
./configure --prefix=$PATHAN_INSTALL_DIR
–with-xerces=$XERCESCROOT
$PATHAN_CONF_ARGS $PATHAN_CONF_XARGS || exit $?
fi
echo Building Pathan
$MAKE || exit $?
echo Installing Pathan
fi
cd $TOP
echo End Pathan build: `date`
fi
echo “"
echo "”
Xquery
echo Start XQuery build: date
echo Configuring XQuery
…/dist/configure --prefix=$XQUERY_INSTALL_DIR
–with-pathan=$PATHAN_INSTALL_DIR
–with-xerces=$XERCES_INSTALL_DIR
$XQUERY_CONF_ARGS $XQUERY_CONF_XARGS || exit $?
Just in case dates are skewed, which triggers calls to bison/flex,
touch a few files…
touch ../src/Grammar.cpp ../src/Grammar.hpp ../src/Scanner.hpp \
../src/Scanner.cpp
fi
echo Building XQuery
$MAKE || exit $?
echo Installing XQuery
fi
cd $TOP
echo End Xquery build: `date`
fi
echo “"
echo "”
DB XML
echo Start DB XML build: date
# Note: passing …/…/$DB_DIR for --with-dbbuild will not work
# if DB_DIR is absolute. This is only used for test configuration,
# and failure to find the directory is not fatal.
echo Configuring DB XML
…/dist/configure --prefix=$DBXML_INSTALL_DIR
–with-berkeleydb=$DB_INSTALL_DIR
–with-xquery=$XQUERY_INSTALL_DIR
–with-dbbuild=…/…/$DB_DIR $DBXML_CONF_ARGS
$DBXML_CONF_XARGS || exit $?
fi
echo Building DB XML
$MAKE || exit $?
if [ $DO_INSTALL = “yes” ]; then
echo Installing BDB XML
fi
cd $TOP
echo End DB XML build: `date`
fi
Perl
if [ $BUILD_PERL = “yes” ]; then
echo Start Perl build: date
echo "If Perl build fails, see $DBXML_DIR/src/perl/README"
echo "for configuration and build instructions"
$PERL Makefile.PL
fi
echo Building Perl
$MAKE || exit $?
echo Testing Perl
$MAKE test || exit $?
echo Installing Perl
fi
cd $TOP
echo End Perl build: `date`
fi
fi
