Formatage avec Gparted et erreur "unable to resolv..."
Bonsoir,
J’ai formater un de mes DD avec gparted en le mettant en ext4,j’ai changé son etiquette et son type de system dans /etc/fstab comme suit :
# /virtual_HDD was on /dev/sda1 during installation UUID=9cfee4ad-49e4-4a18-a2bb-16afa65407e7 /Save ext4 defaults 0 2
et au boot je me retrouve avec cette erreur :
un Sep 25 17:24:49 2011: Setting parameters of disc: (none). Sun Sep 25 17:24:49 2011: Setting preliminary keymap...done. Sun Sep 25 17:24:49 2011: Activating swap...done. Sun Sep 25 17:24:49 2011: Checking root file system...fsck from util-linux-ng 2.17.2 Sun Sep 25 17:24:49 2011: /dev/sda3: clean, 172084/4702208 files, 1426904/18804992 blocks (check in 4 mounts) Sun Sep 25 17:24:49 2011: done. Sun Sep 25 17:24:49 2011: Cleaning up ifupdown.... Sun Sep 25 17:24:49 2011: Loading kernel modules...done. Sun Sep 25 17:24:49 2011: Activating lvm and md swap...done. Sun Sep 25 17:24:49 2011: Checking file systems...fsck from util-linux-ng 2.17.2 Sun Sep 25 17:24:49 2011: /dev/sda1: clean, 223/61056 files, 11756/243968 blocks Sun Sep 25 17:24:49 2011: data: clean, 145470/30531584 files, 105770117/122096384 blocks Sun Sep 25 17:24:49 2011: /dev/sdb1: clean, 249609/19537920 files, 33342699/78142160 blocks Sun Sep 25 17:24:49 2011: fsck.ext4: Unable to resolve 'UUID=9cfee4ad-49e4-4a18-a2bb-16afa65407e7' Sun Sep 25 17:24:50 2011: fsck died with exit status 8 Sun Sep 25 17:24:50 2011: failed (code 8). Sun Sep 25 17:24:50 2011: File system check failed. A log is being saved in /var/log/fsck/checkfs if that location is writable. Please repair the file system manually. ... ^[[31mfailed!^[[39;49m Sun Sep 25 17:24:50 2011: A maintenance shell will now be started. CONTROL-D will terminate this shell and resume system boot. ... (warning). Sun Sep 25 17:24:50 2011: Give root password for maintenance Sun Sep 25 17:24:50 2011: (or type Control-D to continue): Sun Sep 25 17:24:58 2011: Setting up networking.... Sun Sep 25 17:24:58 2011: Mounting local filesystems...mount: special device UUID=9cfee4ad-49e4-4a18-a2bb-16afa65407e7 does not exist Sun Sep 25 17:24:59 2011: failed. Sun Sep 25 17:24:59 2011: Activating swapfile swap...done.
Qqun a une idée ? Merci
Il semblerait que l’étiquette ne soit pas bonne. Pourquoi ne mets-tu pas plutôt le /dev/sdXX qui va bien à la place ?
ps: n’y a t-il pas une incohérence entre tes dirent …
[quote]# /virtual_HDD was on /dev/sda1 during installation
UUID=9cfee4ad-49e4-4a18-a2bb-16afa65407e7 /Save ext4 defaults 0 2[/quote]
…et le message d’erreur … hormis l’appellation. Bref ! c’est un détail.
[quote]Sun Sep 25 17:24:49 2011: /dev/sdb1: clean, 249609/19537920 files, 33342699/78142160 blocks
Sun Sep 25 17:24:49 2011: fsck.ext4: Unable to resolve 'UUID=9cfee4ad-49e4-4a18-a2bb-16afa65407e7’
Sun Sep 25 17:24:50 2011: failed (code8).[/quote]
On présumera que tu as porté tes modifications sur ton fstab en fonction du retour donné par “blkid”.
On présumera que tu as lancé un # update-grub.
On présumera, si j’ai bien compris, que tu souhaite avoir la possibilité de booter sur /dev/sda1.
[quote]
Sun Sep 25 17:24:50 2011: File system check failed. A log is being saved in /var/log/fsck/checkfs if that location is writable. Please repair the file system manually. … ^[[31mfailed!^[[39;49m
Sun Sep 25 17:24:58 2011: Mounting local filesystems…mount: special device UUID=9cfee4ad-49e4-4a18-a2bb-16afa65407e7 does not exist
Sun Sep 25 17:24:59 2011: failed.[/quote]
et que les log soient plus parlant.
On présumera donc, que tu as booté sur un live-cd, que tu as chrooté /dev/sda1 et que tu as installé grub sur celui-ci.
grub-install /dev/sdb1 … d’après le message d’erreurs !!!
le wiki >> Réinstaller Grub2
Et on supposera, que j’ai bien interprétais ta question … :083
